Things you didn't expect to see on an advert, part 888.9:
Someone trying to un-stick a dildo from a Great Dane's nose.
https://www.ebay.co.uk/itm/2007-Skoda-Fabia-Ambiente-1-9-Tdi-MOT-April-2019-FSH-No-reserve/123293211944?hash=item1cb4d91d28:g:prkAAOSwvEBbZzBU
Having only seen it on my phone, I thought these were just some pillows someone has thrown in there to protect the seats. Little did I know...
With that Cutlass, how is it possible that so much win - ghastly interior, two tone paint, column shift - is available for so little?  It can't just be that the fuel choice is undesirable.  I can only assume it's terminally rotten or some sort of scam.
Some fella who talks to pigeons is selling his zx. Bosch'd up though innit,.
https://www.ebay.co.uk/itm/Citroen-zx-1-9td-xud9-with-bosch-pump-205-306-309-406-berlingo-xantia-no-reserve/163187899533?hash=item25fec1bc8d:g:jw8AAOSwgppbWsaC
Actually maybe the pigeon was trying to buy it as here he is inspecting it.
Nar there is a snake under the car just about to attack.
https://www.facebook.com/groups/GRIMSBYSWAPSSALES/permalink/1876575265758816/?sale_post_id=1876575265758816
Sunbeam rapier "barn find"
Which you probably can't see unless you're a member of the group? No idea!
Sent from my VFD 710 using Tapatalk
I am not on FartFace. However, I have to ask why have a group to buy and sell which is closed off to the  majority of the interweb? Is that not where most buyers would be?
This looks alright don't it.
https://www.ebay.co.uk/itm/1998-Cadillac-Seville-STS-4-6-V8-Petrol-Spares-or-Repairs/332748850623?hash=item4d796085bf:g:aEkAAOSwiKBbZ0jv
I bought this car at the end of December 2017
covered 72,000 miles. I have listed this car as spares or repairs with a 99p start with no reserve because the car does have issues
ABS and Traction lights as well as "SERVICE STABILITY SYS
The heater is intermittent and the coolant is well overdue a change
"SERVICE SUSPENSION SYS" message appears
The handbrake release is slightly broken, the handbrake releases as it should when shifted out of P but does not release all the way causing the Parking brake light on the dash to remain illuminated. The handbrake is also weak and probably won't pass an MOT
there may be other faults I haven't noticed
The buyer will also need to trailer the car away, and I will not release the car if the buyer does not fetch a trailer
Someone thinks these are very desirable.
This one is a bit more expensive - €30,000 more expensive.
post-17481-0-79579800-1533572326_thumb.jpegpost-17481-0-72678100-1533572337_thumb.jpeg
https://www.custojusto.pt/beja/descapotavel-coupe/outras-marcas-oldsmobile-v8-diesel-coupe-23917483
Must be the stigma of lhd that holds UK prices down.
Would this be the fabled 4 headed monster or Indenor?
VM monster. Shame Ford didn't pop for the 3.1 five cylinder as in the Jeep Grand Cherokee.
Seems an honest old Barge ......
https://www.ebay.co.uk/itm/Ford-Focus-ST170/202393480951?hash=item2f1f976ef7:g:5GUAAOSwIOtbYagq
  • Offside Front window not opening
  • Offside Front body damaged
  • Oil leak, but not excessive (8.4.1 (a) (i))
  • Front Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
  • Rear suspension components corroded
  • Front Exhaust has a minor leak of exhaust gases flexi section (6.1.2 (a))
  • Front Exhaust mounting defective (6.1.2 (a))
  • Rear fuel tank strap corroded
