They are still used in that classic car racing (a form of banger racing for millionaires) hence the vast appetite for engines.
Unlike the banger racers, the classic racing guys haven't yet figured out that you can actually crash a car with something else
installed than rated rare stuff.
Hence I also fear that engine rapage will sadly be the main motivating factor for the majority of bidders.
Sad but true - there was a 1954 Singer Hunter saloon on Ebay a couple of times - the second time without its engine as that had gone into the more valuable roadster sports. Bentley MK6's are still going the same way to manufacture 'specials'.
With the Lagonda one factor will be the condition of the interior - the Riley RM has been mentioned as a comparison -  the saving grace there is there are still a few basket cases about to break for parts and a better support network. Lagonda suffer from lack of support at an entry level as most specialists are aimed, as has been said, at millionaire owners.
Simple car to restore...just trailer it to the AML works and ask them to fix it. Just make sure you own bullion, diamonds or an oil well.
Bargain Freelander in need of new cat, £300 Ripley
Ok
Y THO... :(
TS
1991 LAND ROVER RANGE ROVER VOGUE EFI LPG AUTO
http://www.ebay.co.uk/itm/1991-LAND-ROVER-RANGE-ROVER-VOGUE-EFI-LPG-AUTO-/122712369092?hash=item1c923a27c4:g:sj4AAOSwFqVZspIs
SPARES AND REPAIRS, HAS BEEN IN STORAGE SINCE 2015
Surprise! no mention of Barn!
Also no mention at all in the page long frilly description just how frilly the old duchess is underneath - it does come with a full valet though
Date tested7 September 2017 FAIL
Mileage143,757 miles
MOT test number8321 0512 8062
Reason(s) for failure
  • Nearside Front Outer Tyre has ply or cords exposed wall cracked (4.1.D.1b)
  • Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
  • Offside Front Outer Tyre has ply or cords exposed wall cracked (4.1.D.1b)
  • Exhaust has a major leak of exhaust gases and corroded (7.1.2)
  • Rear Anti-roll bar linkage ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt both sides d bushes (2.4.G.2)
  • Nearside Rear Inner Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings door arch (6.1.B.2)
  • Nearside Front Inner Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings sill (6.1.B.2)
  • brake disc in such a condition that it is seriously weakened all round (3.5.1i)
  • Front Front position lamp(s) not working both (1.1.A.3b)
  • Nearside Front Inner Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings arch (6.1.B.2)
  • Nearside Rear Inner Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings arch (6.1.B.2)
  • Front Track rod end ball joint has excessive play both sides (2.2.B.1f)
  • Shock absorber has a serious fluid leak all round and all corroded (2.7.3)
  • Nearside Inner Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings sill (6.1.B.2)
  • Offside Inner Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings sill (6.1.B.2)
  • Front Anti-roll bar linkage ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt both sides (2.4.G.2)
  • Rear Anti-roll bar linkage ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt both sides (2.4.G.2)
  • Front Sub-frame ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt both (2.4.G.2)
  • Rear Sub-frame ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt both (2.4.G.2)
  • Offside Front Inner Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings arch (6.1.B.2)
  • Offside Rear Inner Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings arch (6.1.B.2)
  • Anti-lock braking system warning lamp indicates an ABS fault (3.4.1c)
  • Windscreen washer provides insufficient washer liquid (8.2.3)
  • Windscreen wiper does not clear the windscreen effectively (8.2.2)
  • Emissions not tested co2 too high (7.3.A.1)
  • Service brake: efficiency below requirements (3.7.C.1a)
Some amusing advisories
  • Oil leak engine () - they all do that sir
  • Offside Rear Tyre worn close to the legal limit (4.1.E.1) this is the best tyre on the car
  • Play in steering rack inner joint(s) () these dont have steering racks
  • Play in propshaft centre bearing () these dont have centre bearings on the props
Verdict - these used to flood the market at £500 and were broken for parts every single time, are there so few left now that this sort of wreck becomes viable as a project?
That thing was sat in a garden near mansfield for a lot longer than 5 years. It's utterly, utterly rotten.
Might last 20 minutes around a short oval, the best place for it.
That ZB Magnette though. They should never be bangered ever again.
Unlike the banger racers, the classic racing guys haven't yet figured out that you can crash a car just as well with something
else installed than rated rare stuff.
Unusual for me to use such an expression but .. The twats !
The Corvair looks like an NSU Prinz 1000 after consuming a few pies
It had an MOT 5 years ago!
Date tested
17 August 2011
PASS
Mileage
45,229 miles
MOT test number
7987 7952 1283
Expiry date
16 August 2012
Advisory notice item(s)
Front Brake pad(s) wearing thin (3.5.1g)
Nearside Rear Lower Shock absorber has a slightly worn bush (2.7.4)
Nearside Vehicle structure has slight corrosion (6.1.B.2)
V REG
http://www.ebay.co.uk/itm/2003-Vauxhall-vectra-DTI-spares-or-repair-/122724444172?hash=item1c92f2680c:g:oiMAAOSw6~VZyRt-
'blower only works on full easily fixed, and the turbo has gone, if your a tinkering young mechanic this can be fixed if you buy the used part for around £30 on here.'
Bloody typical. I buy a V6 Mondeo then 3 weeks later that honey shows up in my neck of the woods!
Probably a different Deeside, chief.
L8RZ!
Oi! Come back here, you bastard!
http://www.ebay.co.uk/itm/classic-mini-clubman-estate-clubvan-tv-car-airbrush-k-series-1100cc/162686756413?hash=item25e0e2e63d%3Ag%3A%7EHQAAOSwdKZZyWkp
'after a while the battery dies'
Just like a little bit of me does when I see this pile of shit.
  • Like 11
'Owned by the late John Bonham of Led Zeppelin and featured in the movie "The Song Remains The Same"'
Whoop-de-fucking-whoop, get the party hooters out.
http://www.ebay.co.uk/itm/Ford-Model-T-Hot-Rod-owned-by-John-Bonham-of-Led-Zeppelin-and-Movie-Featured/322781153257?hash=item4b274187e9%3Ag%3AvUQAAOSw0hlZNneQ
Classified Ad price: £245,000.00
GLWTO.
