treehugger Posted September 30, 2024 Posted September 30, 2024 Inva sunk. warren t claim and chadders 2
warren t claim Posted September 30, 2024 Posted September 30, 2024 5 minutes ago, barefoot said: Invaboate Plans to export the amphibious Model 70 to Venice were aborted when the Venetian Institute For Canal Safety conducted test and discovered that they were prone to capsizing and speeds below 4 knots and offered poor crash protection against gondolas. barefoot, chadders, Coprolalia and 1 other 4
Dobloseven Posted September 30, 2024 Posted September 30, 2024 I'm getting thoughts of a lightweight boat trailer sort of idea,with the Invacar rear wheels over the trailer axle.Perhsps come in at under 750kg,so no need for brakes.
warren t claim Posted September 30, 2024 Posted September 30, 2024 37 minutes ago, warren t claim said: <PEDANT ALERT> He's having to use a proper greased up skid pan because there's no way an auto TX2 would drift in the dry when fitted with the factory spec Dunlops. I am impressed the the wheel trims didn't fall off though. Even on a skid pan to provoke that level of lean and slide the driver will have had to lock it down into first and done a Scandi flick to provoke that amount of lean and slide. An unladen manual Nissan powered TX running on budget bespoke hackney tyres WILL drift and slide easily on a wet road. As a bonus, it's also super easy to keep drifting as the steering rack is super quick. The main handling issue with an unladen TX, either auto or manual, is that they're a nightmare to drive in the snow. @LightBulbFun I really am imploring you to pull out the stops and do all you can to find an insurance company that will cover you on a TX. You'll not just be buying a vehicle, but also somewhere to safely leave an electric wheelchair. Your quality of life will improve more than you could possibly imagine and maintenance will be cheaper than running a ten year old Focus as there's an entire infrastructure in your city based around keeping the TX on the road. I could have a Nissan powered TX parked outside your house for £1000 by Friday night. An interesting aside. When I drove the TX into Central London last year I phoned TFL in their Glasgow call centre (yes really!) to ask if I had to pay the Congestion Charge and if as an out of town cab I could use the bus lanes. The lady said yes. I asked her is there was a nationwide hackney database and she replied no, they just look at the picture and it's obvious that a TX is a licenced hackney! Jerzy Woking and LightBulbFun 2
warren t claim Posted September 30, 2024 Posted September 30, 2024 47 minutes ago, warren t claim said: <PEDANT ALERT> He's having to use a proper greased up skid pan because there's no way an auto TX2 would drift in the dry when fitted with the factory spec Dunlops. I am impressed the the wheel trims didn't fall off though. Even on a skid pan to provoke that level of lean and slide the driver will have had to lock it down into first and done a Scandi flick to provoke that amount of lean and slide. An unladen manual Nissan powered TX running on budget bespoke hackney tyres WILL drift and slide easily on a wet road. As a bonus, it's also super easy to keep drifting as the steering rack is super quick. The main handling issue with an unladen TX, either auto or manual, is that they're a nightmare to drive in the snow. @LightBulbFun I really am imploring you to pull out the stops and do all you can to find an insurance company that will cover you on a TX. You'll not just be buying a vehicle, but also somewhere to safely leave an electric wheelchair. Your quality of life will improve more than you could possibly imagine and maintenance will be cheaper than running a ten year old Focus as there's an entire infrastructure in your city based around keeping the TX on the road. I could have a Nissan powered TX parked outside your house for £1000 by Friday night. @LightBulbFun https://www.adrianflux.co.uk/taxi-insurance-social/ Christine, chadders and Noel Tidybeard 3
bub2006 Posted September 30, 2024 Posted September 30, 2024 2 hours ago, warren t claim said: <PEDANT ALERT> He's having to use a proper greased up skid pan because there's no way an auto TX2 would drift in the dry when fitted with the factory spec Dunlops. I am impressed the the wheel trims didn't fall off though. Even on a skid pan to provoke that level of lean and slide the driver will have had to lock it down into first and done a Scandi flick to provoke that amount of lean and slide. An unladen manual Nissan powered TX running on budget bespoke hackney tyres WILL drift and slide easily on a wet road. As a bonus, it's also super easy to keep drifting as the steering rack is super quick. The main handling issue with an unladen TX, either auto or manual, is that they're a nightmare to drive in the snow. @LightBulbFun I really am imploring you to pull out the stops and do all you can to find an insurance company that will cover you on a TX. You'll not just be buying a vehicle, but also somewhere to safely leave an electric wheelchair. Your quality of life will improve more than you could possibly imagine and maintenance will be cheaper than running a ten year old Focus as there's an entire infrastructure in your city based around keeping the TX on the road. I could have a Nissan powered TX parked outside your house for £1000 by Friday night. Don't suppose you know if towbars are available? Wouldn't mind one myself but am a bit concerned on the mpg side and needs to be able to tow.
warren t claim Posted September 30, 2024 Posted September 30, 2024 2 minutes ago, bub2006 said: Don't suppose you know if towbars are available? Wouldn't mind one myself but am a bit concerned on the mpg side and needs to be able to tow. Yes they are. One lad uses his TX to tow his daughter's horse box. The Old Bloke Next Door and bub2006 1 1
GrumpiusMaximus Posted September 30, 2024 Posted September 30, 2024 17 minutes ago, warren t claim said: Yes they are. One lad uses his TX to tow his daughter's horse box. Is that what she calls it? red5, warren t claim and Coprolalia 3
OhNoWhatHaveIDone Posted September 30, 2024 Posted September 30, 2024 On 28/09/2024 at 21:39, LightBulbFun said: this is exactly one of the things that saddens me about all this, there used to be a time when I would talk to a fellow Invacar enthusiast or new owner, or just someone who I recognise as being Autoshite "oh you daily drive an Austin Montego? I know the forum for you" and I would be like "now I have got you up to speed how about check my thread for more info and where I keep a running blog of my research and findings" but all this crap is not exactly good first impressions is it... Well said Dez, also replying to @AdgeCutler earlier, it's to the point now, when I say anything, either defending myself, or you, or calling someone out who IS IMHO bullying, or just treating someone like crap, for which the admin DO NOTHING, I get slagged off, abused, called this, that, the other, sworn at.....purely because I will not tolerate insults...... Now remind me why I don't update about the Invacar progress? I'm too busy trying to cover my arse because of all the dickheads out there... Just waiting for the next lot of smart arse comments now!I It's not worth the hassle... AnnoyingPentium, chadders, brandersnatch and 1 other 3 1
BorniteIdentity Posted September 30, 2024 Posted September 30, 2024 Just now, OhNoWhatHaveIDone said: the admin DO NOTHING Brilliant, isn’t it? And, in fairness, I did warn you. AnnoyingPentium, barefoot, Jerzy Woking and 5 others 4 4
AnnoyingPentium Posted September 30, 2024 Posted September 30, 2024 15 minutes ago, OhNoWhatHaveIDone said: Well said Dez, also replying to @AdgeCutler earlier, it's to the point now, when I say anything, either defending myself, or you, or calling someone out who IS IMHO bullying, or just treating someone like crap, for which the admin DO NOTHING, I get slagged off, abused, called this, that, the other, sworn at.....purely because I will not tolerate insults...... Now remind me why I don't update about the Invacar progress? I'm too busy trying to cover my arse because of all the dickheads out there... Just waiting for the next lot of smart arse comments now!I It's not worth the hassle... Something, something stones and glass houses. barefoot, Jerzy Woking, brandersnatch and 5 others 8
GrumpiusMaximus Posted September 30, 2024 Posted September 30, 2024 13 minutes ago, OhNoWhatHaveIDone said: Well said Dez, also replying to @AdgeCutler earlier, it's to the point now, when I say anything, either defending myself, or you, or calling someone out who IS IMHO bullying, or just treating someone like crap, for which the admin DO NOTHING, I get slagged off, abused, called this, that, the other, sworn at.....purely because I will not tolerate insults...... Now remind me why I don't update about the Invacar progress? I'm too busy trying to cover my arse because of all the dickheads out there... Just waiting for the next lot of smart arse comments now!I It's not worth the hassle... Wait? You’re still here. If you want help from the admins, it’s not a great look to insult them in the same thread where you are requesting assistance. Stop hitting yourself, etc. JJ0063, chadders, RoverFolkUs and 6 others 9
OhNoWhatHaveIDone Posted September 30, 2024 Posted September 30, 2024 34 minutes ago, BorniteIdentity said: Brilliant, isn’t it? And, in fairness, I did warn you. 35 minutes ago, BorniteIdentity said: Brilliant, isn’t it? And, in fairness, I did warn you. Well if they want to be admins, they should do their jobs
OhNoWhatHaveIDone Posted September 30, 2024 Posted September 30, 2024 26 minutes ago, GrumpiusMaximus said: Wait? You’re still here. If you want help from the admins, it’s not a great look to insult them in the same thread where you are requesting assistance. Stop hitting yourself, etc. Bang on cue, smart arse comment......See my previous reply, you don't do your job you get called out
OhNoWhatHaveIDone Posted September 30, 2024 Posted September 30, 2024 31 minutes ago, AnnoyingPentium said: Something, something stones and glass houses. Please elaborate,
Christine Posted September 30, 2024 Posted September 30, 2024 At Fod do you all sit round a camp fire and sing ? Here's one for Dez Dobloseven 1
Dobloseven Posted September 30, 2024 Posted September 30, 2024 40 minutes ago, OhNoWhatHaveIDone said: Well said Dez, also replying to @AdgeCutler earlier, it's to the point now, when I say anything, either defending myself, or you, or calling someone out who IS IMHO bullying, or just treating someone like crap, for which the admin DO NOTHING, I get slagged off, abused, called this, that, the other, sworn at.....purely because I will not tolerate insults...... Now remind me why I don't update about the Invacar progress? I'm too busy trying to cover my arse because of all the dickheads out there... Just waiting for the next lot of smart arse comments now!I It's not worth the hassle... Why not tell us how you're getting on with your Invacar? I ,for one,would be genuinely interested to hear about it,and I'm sure others would as well. lesapandre, LightBulbFun, IronStar and 2 others 1 1 3
LightBulbFun Posted September 30, 2024 Author Posted September 30, 2024 Just now, Christine said: At Fod do you all sit round a camp fire and sing ? Here's one for Dez Fun fact when I was at my sisters wedding (dressed in my finest @dollywobbler TWC shirt of course) my now Brother in Law who is a musician got out an instrument or 2 and asked for recommendations of songs like that to sing round the evening fire, and me being me, I suggested 3 wheels on my wagon, and he snapped back "not that one!" BorniteIdentity, Christine, GrumpiusMaximus and 1 other 1 3
Christine Posted September 30, 2024 Posted September 30, 2024 Not heard it for donkeys ...! i remember my mum singing it to me when i was pre school age .
BorniteIdentity Posted September 30, 2024 Posted September 30, 2024 16 minutes ago, OhNoWhatHaveIDone said: Well if they want to be admins, they should do their jobs They are, and they’re doing it brilliantly. My thanks to them. warren t claim, Jerzy Woking, DodgeRover and 5 others 2 6
LightBulbFun Posted September 30, 2024 Author Posted September 30, 2024 4 hours ago, warren t claim said: @LightBulbFun I really am imploring you to pull out the stops and do all you can to find an insurance company that will cover you on a TX. You'll not just be buying a vehicle, but also somewhere to safely leave an electric wheelchair. Your quality of life will improve more than you could possibly imagine and maintenance will be cheaper than running a ten year old Focus as there's an entire infrastructure in your city based around keeping the TX on the road. I could have a Nissan powered TX parked outside your house for £1000 by Friday night. 3 hours ago, warren t claim said: @LightBulbFun https://www.adrianflux.co.uk/taxi-insurance-social/ yeah I have tried them many times! even most recently when renewing REV's insurance, and I had spotted this with a long MOT for £800 https://www.ebay.co.uk/itm/296695894274 LP60CBU but despite being 25 now and having had my licence for 3 years+ there where no underwriters willing admittedly I have not tried any of the other insurance companies I tried last year, since I just want to focus on REV for the time being since I know she is round the corner, almost literally speaking now dave j 1
GrumpiusMaximus Posted September 30, 2024 Posted September 30, 2024 20 minutes ago, OhNoWhatHaveIDone said: Bang on cue, smart arse comment......See my previous reply, you don't do your job you get called out Give it up, cupcake. AnnoyingPentium, Jerzy Woking, Cavcraft and 2 others 4 1
LightBulbFun Posted September 30, 2024 Author Posted September 30, 2024 1 hour ago, bub2006 said: Don't suppose you know if towbars are available? Wouldn't mind one myself but am a bit concerned on the mpg side and needs to be able to tow. not legally on a TX Black cab sadly, as they are not type approved for it, anything from 1998 onwards needs to be type approved for it so maybe if you found a really early TX1 from 1997 you could put a Tow bar on it? but otherwise your limited to FX4's (which I personally dont see as a bad thing I would love an FX4 myself, but I dont think im really in the position for one right now, espically once my ULEZ exemption runs out in 2027, unless I can find a roadworthy 1987 FX4 with the wheelchair option they offered at the time, but I dont think those grow on trees!) The Old Bloke Next Door 1
warren t claim Posted September 30, 2024 Posted September 30, 2024 2 minutes ago, LightBulbFun said: yeah I have tried them many times! even most recently when renewing REV's insurance, and I had spotted this with a long MOT for £800 https://www.ebay.co.uk/itm/296695894274 LP60CBU but there where no underwriters willing and I have not tried any of the other insurance companies I tried last year, since I just want to focus on REV for the time being since I know she is round the corner, almost literally speaking now You're older now. Try again. High Jetter 1
warren t claim Posted September 30, 2024 Posted September 30, 2024 1 minute ago, LightBulbFun said: not legally on a TX Black cab sadly, as they are not type approved for it, anything from 1998 onwards needs to be type approved for it so maybe if you found a really early TX1 from 1997 you could put a Tow bar on it? but otherwise your limited to FX4's (which I personally dont see as a bad thing I would love an FX4 myself, but I dont think im really in the position for one right now, espically once my ULEZ exemption runs out in 2027, unless I can find a roadworthy 1987 FX4 with the wheelchair option they offered at the time, but I dont think those grow on trees!) Where did you gather this info from? Jerzy Woking 1
LightBulbFun Posted September 30, 2024 Author Posted September 30, 2024 2 minutes ago, warren t claim said: You're older now. Try again. im still the same age I was when I called 2 weeks ago, I dont think @JJ0063 would be very happy with me calling back so soon! "Hello Darling its me again!" *Click! Brrrr* RoverFolkUs, loserone, GrumpiusMaximus and 3 others 6
brownnova Posted September 30, 2024 Posted September 30, 2024 28 minutes ago, OhNoWhatHaveIDone said: Well if they want to be admins, they should do their jobs We are. Thanks. Jerzy Woking, Talbot, AnnoyingPentium and 9 others 1 4 1 6
LightBulbFun Posted September 30, 2024 Author Posted September 30, 2024 3 minutes ago, warren t claim said: Where did you gather this info from? https://autoshite.com/topic/32723-lightbulbfuns-invacar-general-ramble-thread-index-on-page-1-survivors-lists-on-pages-24134-adgecutlers-invacar-mk12-restoration-from-page-186-onwards-still-harping-on/page/366/#comment-2951605 read from that point onwards into Page 367 warren t claim 1
chadders Posted September 30, 2024 Posted September 30, 2024 1 minute ago, brownnova said: We do. Thanks. And it's much appreciated albeit somewhat unrecognised at times. High Jetter, brownnova, loserone and 5 others 5 1 2
LightBulbFun Posted September 30, 2024 Author Posted September 30, 2024 7 hours ago, BorniteIdentity said: Once more with feeling - I genuinely don't think there's any piss taking here. Jeez, @Talbotis clearly trying to help by asking about weights and measures. Others have made suggestions about how to ease the burden. Overreacting is, and I understand this, a mechanism for trying to make people feel uncomfortable and be quiet, but I only see helpful contributions here. Perhaps one of us can help get it from the Field to London for Dez? Or at least get Dez to the Field to drive it home? ok you literally had a DVLA screen shot of the word "INVACARE" as your signature for a while, im sorry I cant see how thats not taking the piss.... OhNoWhatHaveIDone, loserone and lesapandre 1 2
