brownnova Posted November 5, 2023 Posted November 5, 2023 I love a 480, such a great design! Always fancied one. Floatylight 1
beko1987 Posted November 5, 2023 Posted November 5, 2023 51 minutes ago, brownnova said: I love a 480, such a great design! Always fancied one. When I was at college there was a K plate one I walked past several times a day and I went through a stage of really wanting one! Did lust after a 440 too... Probably should have done it back then rather than buying a 206 as their probably not as cheap as they were in 2009/10 😂
Six-cylinder Posted November 5, 2023 Author Posted November 5, 2023 Today was a yellow day, a drive out in the MG TF to Milton Keynes Classic breakfast gathering. A wide range of cars and dry weather made it a very pleasant trip. A good showing of Vauxhalls with 2x Cavalier MK3, 2x Calibra, Monaro and a MK1 Astra, plus an Opel Manta. The car I most wanted to drive home apart from mine was the MK1 Astra. wuvvum, adw1977, Shep Shepherd and 5 others 8
AnthonyG Posted November 5, 2023 Posted November 5, 2023 On 18/10/2023 at 00:24, wuvvum said: I once took an elderly primer grey Peugeot to a car meet in the depths of winter with little to no heating. That was a 304 estate and the meeting was at the Ace Café - I was a bit* cold by the time I got home... God I remember that! Must be at least 15 years now. I remember thinking at the time it was pretty hardcore of you! In the late noughties/early teens there was still some really ropey 70s chod still knocking about, I remember one of the founders of this forum (Electric Leyland) turning up to a Stondon car museum c.2010 in an early Maxi which had no reverse gear, thus needing pushing into parking spaces so he could escape forwards. wuvvum 1
AnthonyG Posted November 5, 2023 Posted November 5, 2023 Re 480s, this was the first car I went to the dealer launch of, as a 12 year in 1986, courtesy of the Worcester Volvo dealer and my dad agreeing to take me! My landlord at Aberystwyth university had a N reg ‘Celebration’ model which was a run-out model I think? Looked very smart with full leather. I assume these shared a lot in common with the 440/460? always thought it a little strange that the coupe was launched two years before the hatch/saloon.
Six-cylinder Posted November 5, 2023 Author Posted November 5, 2023 31 minutes ago, AnthonyG said: I assume these shared a lot in common with the 440/460? always thought it a little strange that the coupe was launched two years before the hatch/saloon. My guess was they were testing the platform and factory on the low volume coupe before the lower cost high volume 440. I had my first 440 in Sep 1989 a June 1989 peppermint green 440 GLEi, dull and poor quality. Luckily I did not have it long before I got a new 440 Turbo which was a bit more enjoyable with more go and the slightly lowered suspension. High Jetter, mk2_craig, brownnova and 1 other 4
Floatylight Posted November 6, 2023 Posted November 6, 2023 8 hours ago, Six-cylinder said: Today was a yellow day, a drive out in the MG TF to Milton Keynes Classic breakfast gathering. A wide range of cars and dry weather made it a very pleasant trip. A good showing of Vauxhalls with 2x Cavalier MK3, 2x Calibra, Monaro and a MK1 Astra, plus an Opel Manta. The car I most wanted to drive home apart from mine was the MK1 Astra. The Mk1 Astra looks great, always loved the look of the Exp and the Celebrity as a kid, one was two tone black and silver the other black and gold. Mum had a three door 1200s which I learnt to drive in and out of the garage aged about 12.. Halcyon days (until I caught the rear arch on the door frame!) Six-cylinder 1
Talbot Posted November 6, 2023 Posted November 6, 2023 Been meaning to put some pics up of the Mishibishi, and here seems like the right place to do it. There's other stuff earlier in the thread, but after recovering it from where it had been parked for several years after clutch failure, it went off to be sorted, at the same garage as has been used before near me: Irritatingly it snapped a front spring while being recovered.: That would have to wait for another day, as the failed clutch was the first thing to be addressed. Lots of subframe to be removed: While up in the air, I was able to see the "small bit of welding" it needed. More on this later: Anyway. Box off: Clutch doesn't look too bad does it? Unfortunately the release bearing came out looking like this and completely siezed: Which had done something I've never seen before. As it hadn't been turning, it had friction heated the fingers of the clutch and made them go all weak. With this result: Yep. All fingers had been heat-weakened and then folded over so that the release bearing just punched through the pressure plate... Out of focus, but you can see clearly: Ah well, no time to wonder. New clutch in: Box back on: Subframe pieces back on, and all buttoned up: While in the air there was also a couple of other items noticed. Radiator is "past it's best" But it has had a front-to-rear re-pipe: Which is nice. So... it was shoved outside, as it couldn't really be driven any distance with the front spring rubbing the bodywork really badly. Springs were ordered from Aus, and collected from @Six-cylinder for fitting. mat_the_cat, Dyslexic Viking, brownnova and 13 others 16
Talbot Posted November 6, 2023 Posted November 6, 2023 So. Next thing to do is remove the borked spring and fit some replacement ones. Struts removed one at a time, the dead spring coming off very easily: The spring compressors were doing almost nothing here, noted by the fact that when I went to remove them, it all went sproing! Got that strut back together, alas with no more pics. But.. it was very clear to me that the new springs are not the same spec as the old ones, so the other side definitely needs doing before the car is driven anywhere. Other side, being complete put up more of a fight: But did come apart. I tend to use 4x spring compressors now, as if one slips or moves, there are still two diametrically opposed compressors in place. Using just two or even three is a risk too far IMO. These compressors have done a 3.5tonne van springs before now, so I'm quite happy using them on this. New spring and old spring for comparison: Ah well, hopefully it won't affect the drive too much. No pic of the new spring compressed, but they did go together OK. Shoved it all back on the car, and remarkably it doesn't appear to have affected the ride height at all. I assume these are shorter but also stiffer, so have a similar static loaded-length. Given that these cars were quite popular in Aus, and their roads can range from OK to abysmal, we have to assume that these will be fine. Time to get the car away from the garage and address the other issues. Enter the braked A-frame again. This thing is genuinely brilliant.. I can't list the number of cars I've moved with it now.. must be dozens. It's now also almost 20 years old, which is a bit worrying as I can clearly remember making it. Anyway. Lets have a look at that rust first. Doesn't look too bad: Oh. Bother. Fine. I should have known it would be worse than expected. It *ALWAYS* is. Grinder oot: I need to keep that threaded hole location, as I probably won't get it right again.. soo: From below: That's a fair hole really. Time to get weldin' Zinc based paint: And bitumen topcoat: Jobbed. Next exciting installment: The radiator. wuvvum, RayMK, chaseracer and 23 others 26
Talbot Posted November 6, 2023 Posted November 6, 2023 Can you tell which is which? Only issue is that it's a bare radiator, so everything has to be moved over: With that in, I can now put the grille back on with several cable ties, and make it look like a car again: How brave am I feeling? With a new battery on it too, time to shove it in for an MOT and see what the damage is. Thankfully I have a fairly decent MOT centre just 1.5 miles away, so shove my bike in the remarkably spacious boot, and get it down there. A white pile of utter shit. And a Mitsubishi. Predictable results: Many of these are easy and fairly trivial. The headlamp issue was worrying though.. Rack boot changed on the nearside. I didn't do the offside one, as it looked at least 6.72 times harder to do. Then, the tiniest little drop-links I've ever seen. Did both sides, as seems silly not to: Then changed the dead lamps as necessary, put a splurge of instagasket on the front bank cam cover, as that's where the leak was from, and that left only the headlamps to do. Which I simply couldn't do. They are glass lenses, which is great, but the plastic reflectors had lost most of their silvering, hence the pattern issue. I cleaned them up as best I could and ran it back to the tester to see if they were good enough. He showed me the beam pattern on the tester, and even I would not have passed it.. they were just a smoosh of light with no clear cut-off. Not good. It also needs 4 tyres, as although the MOT only identified one as a fail, they are all terrible. Annoyingly, they're a fairly old-fashioned size: 205/65r15. or at least they should be. The car had a mix of 195/60r15 and 195/55/r15 tyres fitted, which are both wrong. I had assumed that the spare (at 205/65r15) was the wrong one, but as it turned out it was the only correct one. The spare was also flat as a pancake, and held air for about 12 seconds. Turns out it was a corroded bead seal area, so that got removed from the rim, cleaned up and re-sealed. It might as well work! So that is the condition the car got A-framed up to the FoD in. Popsicle, Shite Ron, Dyslexic Viking and 11 others 14
outlaw118 Posted November 6, 2023 Posted November 6, 2023 9 minutes ago, Talbot said: It also needs 4 tyres, as although the MOT only identified one as a fail, they are all terrible. Annoyingly, they're a fairly old-fashioned size: 205/65r15. or at least they should be I've just had a quick look at blackcircles, and they're available from £64.92 for "Pace" (Winglong Happyday Ditchfinders not available) to £160.69 for Michelin Thruster Turbo Viagras. https://www.blackcircles.com/tyres/205-65-15?id=10007 catsinthewelder 1
Talbot Posted November 6, 2023 Posted November 6, 2023 Indeed, but as it needs five, that would be well over £320 on tyres. I believe @Six-cylinder managed to find some part-worns somewhere for it, as certain Espace and Berlingo/Partners used this size. Most of the tyres available in this size are commercial though, so you have to be a bit careful. outlaw118 and richardmorris 2
Six-cylinder Posted November 6, 2023 Author Posted November 6, 2023 1 minute ago, Talbot said: Indeed, but as it needs five, that would be well over £320 on tyres. I believe @Six-cylinder managed to find some part-worns somewhere for it, as certain Espace and Berlingo/Partners used this size. Most of the tyres available in this size are commercial though, so you have to be a bit careful. Yes thank you so much for the large amount of work you have done to the Sigma. Yes I have tyres for it and the new headlights. The delay has been me needing to work and now it is marooned in the grass at FoD after all the rain. Talbot 1
Talbot Posted November 6, 2023 Posted November 6, 2023 Having used my Braked A-Frame for so many years, I've never seen what it looks like in action, as I'm in the towing car. I can feel it working, but not see it. So, by the power of having two phones: Possibly one of the most boring videos on here, but it shows how the car steers, and more importantly, brakes. I'm amazed by how progressive the braking is when needed. It needs a better return spring, but that seems to be the only thing "wrong" with it. Another, just of the turning in to the FoD, which highlights how much the towed car "cuts in" on corners, as it's the same as towing a long trailer with the trailer wheels at the same position as the rear axle of the towed car. A car transporter trailer is more maneuverable. But also has to be towed both ways on a journey, whereas this just packages up into the boot of the car, meaning you can drive "normally" on at least part of the journey. Plus you don't have to tow 600+KG of transporter trailer, meaning in theory I can tow a heavier car this way. I did take an even longer video... but even I can't watch 30 minutes of a car driving itself along the road. LightBulbFun, Popsicle, Shite Ron and 6 others 9
Six-cylinder Posted November 6, 2023 Author Posted November 6, 2023 25 minutes ago, Talbot said: Having used my Braked A-Frame for so many years, I've never seen what it looks like in action, as I'm in the towing car. I can feel it working, but not see it. So, by the power of having two phones: Possibly one of the most boring videos on here, but it shows how the car steers, and more importantly, brakes. I'm amazed by how progressive the braking is when needed. It needs a better return spring, but that seems to be the only thing "wrong" with it. Another, just of the turning in to the FoD, which highlights how much the towed car "cuts in" on corners, as it's the same as towing a long trailer with the trailer wheels at the same position as the rear axle of the towed car. A car transporter trailer is more maneuverable. But also has to be towed both ways on a journey, whereas this just packages up into the boot of the car, meaning you can drive "normally" on at least part of the journey. Plus you don't have to tow 600+KG of transporter trailer, meaning in theory I can tow a heavier car this way. I did take an even longer video... but even I can't watch 30 minutes of a car driving itself along the road. It just makes me want to get behind the wheel even more!
Talbot Posted November 6, 2023 Posted November 6, 2023 Sounds like I need to come up and do the tyres/headlamps and get it in for another MOT.... beko1987 1
Six-cylinder Posted November 6, 2023 Author Posted November 6, 2023 5 minutes ago, Talbot said: Sounds like I need to come up and do the tyres/headlamps and get it in for another MOT.... It would be nice to finish it off now we are so close, I will pop into the field tomorrow and see how wet it still is.
grogee Posted November 7, 2023 Posted November 7, 2023 It may be buried further down the thread, but how does that braked A-frame thingummy work then mister? It looks like a shiter's wet dream - the ability to transport mot-less hulks about the country single-handed. DSdriver and LightBulbFun 2
Talbot Posted November 7, 2023 Posted November 7, 2023 It's not in this thread. In fact, although I've referenced it in various places, I don't think I've gone into detal as to how it works other than in person with people, mainly at the FoD. I shan't clog up this thread with it, but will put some information up about it at some point. The very quick version: It's an A-frame, but with an over-run mechanism at the tow-hitch, a long bowden cable into the interior and a brake-pedal-pusher that straps to the driver's seat. When the towed car pushes on the towing car, it activates it's own brakes. Exactly like any other over-run brakes, but all fitted with ratchet straps, bungee cords and cable ties. DSdriver, catsinthewelder, LightBulbFun and 3 others 6
Six-cylinder Posted November 7, 2023 Author Posted November 7, 2023 I collected our Volvo V70 T5 Auto today with a Fresh MOT, with nothing to do for a change. adw1977, LightBulbFun, catsinthewelder and 3 others 6
beko1987 Posted November 7, 2023 Posted November 7, 2023 A good friend of mine had a T plate S40 saloon t5 several years ago and it was rapid! We were younger and sillier but never unsafe, made several point to point times in that car that can't and possibly shouldn't be beaten. Was always funny to bait hot hatches too as he kept it unwashed and tatty. Remember it being very comfy too as we proceeded at speed to wherever @gnomeotbut he doesn't log in very often...
wuvvum Posted November 7, 2023 Posted November 7, 2023 A T plate S40 would have been a T4 rather than a T5. [/pedant] beko1987, outlaw118 and S2000 2 1
Wibble Posted November 7, 2023 Posted November 7, 2023 On 05/11/2023 at 17:05, Six-cylinder said: Today was a yellow day, a drive out in the MG TF to Milton Keynes Classic breakfast gathering. A wide range of cars and dry weather made it a very pleasant trip. A good showing of Vauxhalls with 2x Cavalier MK3, 2x Calibra, Monaro and a MK1 Astra, plus an Opel Manta. The car I most wanted to drive home apart from mine was the MK1 Astra. 2nd pic, a Mk5 Cortina, 1982 1.6L in Caribbean blue! Oh, the memories of my first car: N19, Popsicle, Six-cylinder and 2 others 5
Six-cylinder Posted November 7, 2023 Author Posted November 7, 2023 27 minutes ago, Wibble said: 2nd pic, a Mk5 Cortina, 1982 1.6L in Caribbean blue! Oh, the memories of my first car: The only Cortina I have owned was a 1968 MK2 1600 Super 2 door dressed up to look like a GT. Wibble 1
hairnet Posted November 8, 2023 Posted November 8, 2023 8 hours ago, Wibble said: In Caribbean blue! Enya will be kicking your arse for copyright Wibble and AnnoyingPentium 2
Six-cylinder Posted November 8, 2023 Author Posted November 8, 2023 Yesterday evening @Andyrew and I went to move his Allegro and my Sigma off the grass before it rained again at the FoD. The Sigma started well and I added petrol as I knew it was very low, but it had a flat rear tyre. I decided to drive it flat and still get it off the grass because I have new tyres for it anyway. The Allegro started without much bother but only ran for a short time and would not restart. Investigation showed the petrol pipe had been nibbled and was leaking. It seemed that they liked the braided hoses best as both had been eaten but not the plain rubber. Round two to follow if it stops raining later. Wibble, Floatylight, LightBulbFun and 5 others 8
Six-cylinder Posted November 8, 2023 Author Posted November 8, 2023 Today was a one step forward, one step backwards day. @Andyrew repaired the fuel pipe on his Allegro so it runs again and moved it to the yard. He closed his boot and one of the reversing light lens fell on the ground. I then reversed the Sigma into a post, scratched the off side rear and broke the light lens. Somebody then stole the wheels off it! Not realy Andyrew kindly took the wheels off so he could take them away fit the new tyres I have for it. I now need a replacment offside outer tail lamp. adw1977, richardmorris, Prince_of_darkness91 and 3 others 1 5
hairnet Posted November 9, 2023 Posted November 9, 2023 7 hours ago, Six-cylinder said: @Andyrew Stop doing a Mr Magoo clumsy old fart https://www.ebay.com.au/itm/123724144748 richardmorris 1
Six-cylinder Posted November 10, 2023 Author Posted November 10, 2023 Tonight with the help of @Andyrew the new lights and grill have been fitted. They all work now and I am very pleased with the way the grill looks. A minor problem with corroded wires into terminals on the car meant we had to replace them. There was also a minor problem with two grill body mounts have enlarged holes due to rust. Wheels have been refitted with replacement tyres Andyrew fitted, also new wheel centre caps and badges. Dick Cheeseburger, beko1987, CaptainBoom and 20 others 23
