Six Cylinders Motoring Notes - If your car collection kept breaking down would it be prudent to buy another hard to maintain additional car!
57 minutes ago, Six-cylinder said:
Yes 23 C Forecast Saturday!
Never been before to Field of Dreams, if you come what do you have to do? the answer is nothing, sit around drink tea and watch other is just fine.
If you would get bored doing nothing then you can clean/fix what you have brought with you.
What else is going on:
Looks like we can get the big toys out, we will tow start our two dumpers and as the  3 ton one has a broken decompression lever the only way is to tow start it with the 7½ ton JCB digger.
Our farm trailer is in an awkward spot and needs moving so the tractor will have to be started.
Cut grass with ride on mower
Fix Jingling idle problem
Fix cylinder bearing on Hayter ride on cylinder mower
Polythene cover up stuff
Citroen CX replacement throttle cable, refit coil and check why the hydraulics leak.
We have 10 acre to play in but no racing.
Car Camping, tents, caravans and expensive motor homes all welcome.
Children and pets welcome
Just remember we have no insurance however you hurt yourselves so safety first.
Never been before, PM me for address and map.
sounds like lots of fun :)
esp given the nice weather etc, im really hoping i can arrange something so I can make it down, but im still not sure if i can make it eyt sadly (and also if Dollywobbler will be there, id like him to get a chance to drive REV and see what his thoughts are on her :) )
it would also be nice to patch the hole in REV's fuel tank (using that stuff @Mrs6C mentioned last gathering IIRC?) and replace the fuel lines finally (assuming the fuel hose has not been robbed for other members of the fleet :mrgreen: ), it would be nice to make some good progress to getting her road legal
and also get Dolly to idle and moving :)
1 hour ago, Andyrew said:
Hope we get the weather that's forecast.
If a pipe has split on the cx suspension. I was thinking it may be worth me getting some 4mm fuel hose into through work and bringing some along as a quick fix to get it moving?
Does any green blooded Citroens fondlers know if it's the metal pipes that fail or rubber flexi parts that fail more often?
Will rubber hoses withstand Citroen suspension pressure?  I thought they just used rubber for the returns.
I suspect there might be a blow out of some kind. Fancy creating a Jackson Pollock using LHM?
As mentioned before I have the tool to flare pipes up for Citroen hydraulics.
The pipe is 3.5mm and there are Citroen specific flare tools.
I believe they have coils of metal pipe to feed the rear sub-frame and take up the movement. It could also be a component fail and it would be good to know what as broken.
We now have this enclosed stove we can set up and cut up some wood for.
It is nearly 3 foot in diameter.
How ambitious are you with woodcutting?  I have a chainsaw ?
Who else is planning to camp?
Yep, bringing our camper and stopping Friday & Sat nights.
Once again playing cars has taken priory over work!
Our VP1500 has had issues starting and then the indicators failed.
Our local auto sparks does not do home visits anymore, but last week he did visit and pronounced the problem was the neg battery lead was not tightening where it met the body. The captive nut was seized and he left me to to sort that out, I tried brute force and broke the weld on the captive nut and snapped the bolt so putting in a replacement nut and bolt was then easy. Now the starter would not turn at all, rather than only when it felt like it. I called the auto sparks back and he found I had dislodged the earth for the starter switch inhibitor relay. A 1976 manual Allegro would not normally have an inhibitor switch but this one started life as an automatic and did.
This morning he made me take it to him for the indicators and the strange ignition light and oil pressure light display that only sometimes worked. 3 problem, the flasher unit had failed, the plug on the back of the alternator was broken and one connector only make contact when it felt like it. He fixed all that for me, but did not have an oil pressure switch which has also intermittently failed.
I feel much happier that the VP is now working so it can go to the BL day at Milton Keynes museum 29th Sep.
  • Like 9
Some fuel hose is rated to 300psi. The 20p jubilee on the end however not so much.
I was just thinking if a metal pipe has rotted out if some could be used to Sleeve over the damaged area to get the car off it's arse.  Certainly not a permanent fix. I looked at work today and couldn't find any suitable hose.
Will have a look on Sunday.
We bought a retractable airline at work a few years ago.  Saw how high it was rated and wondered if it could cope with being the pressure washer hose.  Fuck me that was a loud bang ?
3 hours ago, Andyrew said:
Some fuel hose is rated to 300psi....
Aren't Citroën systems a bit higher than that?
Id imagine it's far higher
Although green blood / Lhm  is  usually measured in floor PSI ( puddle size increments)
Quick Google suggests 1200-1500 psi.
Better make it 4 jubilee clips then.
Again more tinkering in work time.
My Vitesse ran very poorly so I arranged my favourite garage to take a look at it for me, trouble is it stopped running all together! I diagnosed the fuel pump and ordered one which sat on my desk like an ornament! All of a sudden it is urgent as my favourite garage want me to take Sovereign S2 that has had a new starter motor and that gives me an opportunity to drop off the Vitesse but only if it runs. Not to bad a job on a Vitesse but I had to move 3 cars to get it out. So now I have fixed it enough to run badly.
OK, not staying over Saturday night now - I've promised to spend Sunday helping my mate Laurence with the resurrection of his 2CV racer.  I was closely involved in the original build of this car in 2002, so I've literally got blood/sweat/tears in this thing!
We're aiming to run it in next year's 24-hour race at Snetterton.
Looks like it should be a good weekend.  I'm buggering off to Scotland this weekend to try and forget that I'm turning 40 on Sunday, otherwise I'd have been tempted to trundle down.
Who else is planning on stopping on Friday Eve?
Well you are not getting refunds!
Time to think about Milton Keynes Museum BL day 29th September 2019
As it stands I have 5 cars we can take:
1984 MG Metro
1976 Vanden Plas 1500
1972 MGB GT
1973 Daimler Sovereign S1
1976 Daimler Sovereign S2
Possibly if it fixed in time
1970 Triumph Vitesse convertible
The question is who can help? I am planning to leave the house at 9.40am.
Sir, sir, Daimler please. If cold I can wear my arfur Dailey crombie coat and hat.
S1 Daimler pretty please with knobs on
Be a nice little earner,  etc.
What flat4alfa did not realise is while S1 looks better S2 drives better!
So we have drivers for the Daimler brothers now we need drivers for:
1984 MG Metro
1972 MGB GT
Is anyone planning on stopping at the FOD tonight?
I’m hoping to be there in the Mini (MK Museum that is)
It would be nice to see some new and familiar faces!
9 minutes ago, Andyrew said:
Vp please
Or the vitesse
If the Vitesse is ready you are welcome to choose, or one there a different one back if you like.
Back to this weekend, have you seen the weather Forecast for Saturday night, glorious 17 C and Dry ! If you can't make day time why not join us for a evening around the camp fire.
In that case I would love to sample the S2 !  as the older PAS boxes in 420G S-Type etc I do find - erm - woolly
