Station Posted September 30, 2014 Posted September 30, 2014 I wish my Justy was as appreciative of all the help I've put on it. Ungrateful heap! KruJoe 1
dugong Posted September 30, 2014 Posted September 30, 2014 Wat Yes? HillmanImp, loserone and KruJoe 3
hairnet Posted September 30, 2014 Posted September 30, 2014 did the boss get a licence yet did she beat you up for making her use that KruJoe 1
KruJoe Posted September 30, 2014 Author Posted September 30, 2014 Thanks for the comments guys. The boss has been insured on the Rover for on-the-road practice, and a few proper lessons too. She's doing well. This was the only bent bit that mattered. It straightened up ok with some gentle persuasion. Wire brushed off, lashed with phosphoric acid... ...and left to go crusty... ...then plastered with underseal. Still mobile and useful! The bloody thing has never failed to start, it goes and stops well despite the bollocksed discs. It looks like crap but doesn't want to die. Skizzer, Lacquer Peel, Coprolalia and 3 others 6
Station Posted October 1, 2014 Posted October 1, 2014 Is phosporic acid from drain cleaner? I heard it can be nasty, I was going to flush my tank with it, about 1 part to 50 parts water I think, but it actually boils the water so you have to be careful.
Danblez Posted October 1, 2014 Posted October 1, 2014 I use brick cleaner for phosphoric acid to remove rust, it's ace and cheap. alf892 1
KruJoe Posted October 1, 2014 Author Posted October 1, 2014 I've been playing* with phosphoric acid a little bit on this project. (More later on that.) It converts rust into a crusty, inert, blue-black protective layer, which can be undersealed over, or washed (or wire-brushed) off, and re-painted properly. DS20 and SambaS 2
DS20 Posted October 1, 2014 Posted October 1, 2014 That's useful to know. Is phosphoric acid sold under that name? I could do with some, to turn half the Citroen a nice blue-black colour.
KruJoe Posted October 1, 2014 Author Posted October 1, 2014 Yes, I bought mine off ebay. Arrived like this: £12 or £15, for this fairly strong percentage. I diluted this 85% acid 50:50 with water for my tests. Craig the Princess and DS20 2
Matt Posted October 2, 2014 Posted October 2, 2014 What's the process for removing the front bumper on these and are they in two pieces (upper and a lower)? The bottom half of my front one is fecked and it's hanging at a jaunty angle. Thankfully though mine seems to have escaped the tinworm, the only rust I know of is a miniscule bit on the ends of the sills where they meet the wheel arch and a tiny bit along that seam on the bulkhead.
KruJoe Posted October 2, 2014 Author Posted October 2, 2014 It's fairly easy to separate the two parts once the bumper's off. The top part may be screwed to the slam panel, but the main fixings are the nuts (12mm/14mm?) on the captive studs which point backwards from the steel bumper re-reinforcer. The studs poke through the holes in the rectangular plated on the end of the chassis legs, two each side. The wheel-arch liners may be screwed on too.The bumper should just slide forward. Once off, the top bit should simply pull off the lower part. If your car is a face-lifted one, it may have a couple screws as well.
KruJoe Posted October 11, 2014 Author Posted October 11, 2014 Behold: The Kru-Joe Mingebag Steel Wheel Refurbishment Tutorial I have 12 of these wheels knocking about, mostly in this sort of state: Five of them didn't hold air, so I wrestled the tyres off, and started with this: Not fun. So all four corners off the ground, second gear ticking over... (That looks faster than is was due to slow shutter speed.) I held an old file to the rims as they turned. Five minutes later: WARNING: Bucket shot. I brushed on the Phosphoric, at about 50% concentration, and left to dry. This is what it does: Due to the crustiness, they needed brushing off again, but it was much easier than getting rid of scaly brown rust. I didn't go hard down to shiny metal again, I left the grey staining on - apparently it inhibits the grot. I hate spraying. It's wasteful, and I dislike runs in the paint and the over-spray. I use sections of old sponge scourers, laundered, cut to size, folded and stapled to make a nice shape. I like the control of my technique, I can do it in a draughty shed on the bonnet of a Lada Niva, and it's cheap! The finish of one or two coats of this Hammerite smooth silver from a one litre tin is quite acceptable. I painted front and back, and all around the beads where the tyres sit, just to keep an air-tight seal. Left for a few days in the sun(!), the surface can harden a bit. The phat rimz are off my MR2, I did those at the same time. The money shot: Four brand spanking Marangoni 4-Winter tyres at £31 each plus £5 fitted, re-valved and balanced. The white one was an experiment with an old tin of Dulux, which had an inch of gloop in the bottom. That has the best of the old tyres on, and will be the spare. JOB'S A GOOD'UN! NB: Don't touch your alloys with phosphoric acid, they'll melt! Skizzer, Rusty_Rocket, Coprolalia and 19 others 22
Craig the Princess Posted October 12, 2014 Posted October 12, 2014 Smashing wheel advice Joe, looks far more durable than my usual quck wire brush and spray techinque. KruJoe 1
catsinthewelder Posted October 12, 2014 Posted October 12, 2014 Top stuff Joe, I'll give that a go on the VW when The laziness subsides a bit. I might even out mingebag you by using some silver eco paint that I was given ten tin's of a few years back. KruJoe 1
brickwall Posted October 12, 2014 Posted October 12, 2014 I get my phosphoric acid from the farm sales. You can get it in varying strengths. Years ago I poured some in a metal dish thinking it was steel - but it was aluminium. I returned to a huge mass of bubbly white stuff on the drive and no dish. It reacts with the concrete too. mat_the_cat and KruJoe 2
Split_Pin Posted October 12, 2014 Posted October 12, 2014 That end result is thoroughly flipping satisfying to look at! KruJoe 1
Lacquer Peel Posted October 12, 2014 Posted October 12, 2014 I wonder what Marangoni winter tyres are like, I've had cars with Marangoni summer tyres and they could barely stick to dry roads.
KruJoe Posted October 12, 2014 Author Posted October 12, 2014 Thanks chaps. I am pleased with how they look just now. They're still stacked in our "tyre shed" waiting for MOT day. I find myself wandering in there aimlessly, gazing at them and caressing the deep, bobbly tread. Sad bastard. Time will tell how well the paint holds up, though I'm sure it's more robust than the standard finish on silver wheels from Japan in the 80's and 90's. It was the law back then for them to go scabby within 12 months. As you may have seen, the calipers have been on and off the hubs a few times. Finally, this happened: I did try to revive the discs, using my mingebag flapper-wheel method, but they wouldn't stay nice. So £32.66 bought me new ones with pads thrown in. I then found that these Justys came with (at least) two types of calipers... my green breaker has some jap branded ones, and this wreck has Bosch stoppers. Predictably, the pads for the Japanese calipers arrived. Normally I would have swapped the brakes over to match, but the green car has been sat in the weeds for years, and I know the silver car's ones still work well, so I sent the pads back to exchange. The right ones came by return, and were a doddle to fit. The car now stops really sharply - it's almost like a modern! Also, £11.98 won me a pair of (Suzuki Baleno) track rod ends, which sorted out the rattle. I'll have it tracked up properly on the way to see Jack_the_Test, so I can save the nice new boots Craig the Princess, DS20 and brickwall 3
KruJoe Posted October 12, 2014 Author Posted October 12, 2014 The Marangonis 4-Winters seemed to get positive reviews when I was researching a few months back, and the noise/water-clearing ratings looked comparable to good summer tyres, so look suitable for this little shit-box to wear all year 'round. Again, time will tell. I bought them from here: http://www.tyreleader.co.uk/car-tyres/marangoni/4-winter/165-70-r13-83t-59047?gclid=CjwKEAjwzeihBRCQ84bhxrz_0w8SJAAohyh11jSnvqD4-KaoGYvh9yw9gCX9GGl6zanE_Hx2zJcycBoCQxfw_wcB They have everything in every size. I bought a set of 18 inch(!) Dunlops for my mother's car in the same week. I searched quite a few sites for the best prices, and across the board they were cheapest, despite them coming from Germany. Free 48hr delivery too. "Top seller, would use again A+++" Lacquer Peel and RobT 2
RobT Posted October 12, 2014 Posted October 12, 2014 That Tyreleader is well cheap. I need atleast two for the 75 as the budgets currently on the front have shit wet grip. They do Continentals at 37 quid a pop so might give them a go!
Craig the Princess Posted October 13, 2014 Posted October 13, 2014 Thanks chaps. I am pleased with how they look just now. They're still stacked in our "tyre shed" waiting for MOT day. I find myself wandering in there aimlessly, gazing at them and caressing the deep, bobbly tread. Sad bastard. Once again autoshite proves I am not that weird, I also love a rub of a new bobbly tyre. KruJoe 1
Skizzer Posted October 13, 2014 Posted October 13, 2014 I wonder what Marangoni winter tyres are like, I've had cars with Marangoni summer tyres and they could barely stick to dry roads. I used to run Marangoni Meteos on my Yeti and found them very good - no noticeable difference to the Conti WinterContacts that replaced them, apart from a bit more road noise. In fact, one year I never got around to changing them back to summers, which is why they eventually wore out. (Before the annual winter tyre row kicks off, I drive in Germany in the winter where they're compulsory.) KruJoe and RobT 2
KruJoe Posted October 18, 2014 Author Posted October 18, 2014 With the front end off, this job should have been a doddle. A bit of a fighter this bugger, but I won in the end. It wasn't quite as stuck as the one on my old Panda 4x4 - that had rusted through and was pissing oil out, it just crumbled and came off in bits. They always succumb when you stab them through the heart with a screwdriver and turn them with the handle. But once you've gone in, you're committed! Why could it be that the last four motors I've bought have been missing their battery clamps? This bodge (bent tent pegs and a rubber thingy) was put in place for first "testing". Then I found the right bits from the green bogie: I ought to paint that really. Which reminds me, I need to put the batt on charge, so it may get tidied up after all. There's more important things to attend to now though. Like de-face-lifting its arse. Remember this? HowTF is that an improvement? It would be rude not to rectify the situation as I have all the bits. Those were easy to get off. But this... Was a complete twat. I didn't want to wreck the newer lights just to get them off. I tried the impact driver, which turned it, but bust the welds off the captive nut on the inside. I tried to drill the head off, but it spun and melted the hole a bit bigger. I don't mind, because I could replace it with a washer if I needed to. (That looks like a masonry bit - it ain't - it's one of them Bosch all purpose efforts.) I ground the head off, and the rest fell inside. I'll need to weld in a new nut for that light. Behind the lights of the silver car, I found these. They looked a bit odd to me. I came in for a brew, and remembering an item on Radio 4, I did some googleing. They're Harlequin Ladybirds, and bad news. An invasive species from Bongo-Bongo Land. They come in several patterns. I went on a website and reported them, because they've never been seen around these parts (until I transported them from Wetherby). Hopefully they won't survive the harsher climate up here. Keep your eyes peeled folks! I bet you didn't expect to read about them today, did you? Oh, the bumpers came off too. The ironmongery behind both is poor, the green one so much so that the only way to get it off the car was to writhe it off. The plastic is stronger than any of the steel, so it's all good. I will weld up the silver car's bumper backer to go in the green bumper. Welding. Yes, I've been putting off the welding. Can you tell? There's plenty of that to come. Yes indeed. RobT, scruff, Grundig and 9 others 12
mat_the_cat Posted January 3, 2015 Posted January 3, 2015 They always succumb when you stab them through the heart with a screwdriver and turn them with the handle. You say that...I would agree with you, apart from one time on a neglected 106. I stabbed it and hammered it round with the screwdriver. I thought it was turning, but all I was doing was tearing the hole in the side of the filter until the screwdriver had cut the end off! Bother and blast said I, or words to that effect. Ended up with a hammer and chisel on the filter base to get the sodding thing off. KruJoe and steve_earwig 2
steve_earwig Posted January 3, 2015 Posted January 3, 2015 You say that...I would agree with you, apart from one time on a neglected 106. I stabbed it and hammered it round with the screwdriver. I thought it was turning, but all I was doing was tearing the hole in the side of the filter until the screwdriver had cut the end off! Bother and blast said I, or words to that effect. Ended up with a hammer and chisel on the filter base to get the sodding thing off.+1 except that it was a Mini van (the one with the pressed steel grille you can't remove). Also, once I'd got the thing off I nipped indoors to dress my (numerous) wounds and some passing urchin kicked the tray of oil everywhere. Ah, street mechanicking, thems were the days. mat_the_cat 1
HillmanImp Posted January 3, 2015 Posted January 3, 2015 You say that...I would agree with you, apart from one time on a neglected 106. I stabbed it and hammered it round with the screwdriver. I thought it was turning, but all I was doing was tearing the hole in the side of the filter until the screwdriver had cut the end off! Bother and blast said I, or words to that effect. Ended up with a hammer and chisel on the filter base to get the sodding thing off. I hammered the screwdriver through a stubborn filter on the Scirocco once which I hit a little too hard and it went straight through a live wire running right behind and caught fire. Albert Ross suggested one of these several years ago. Still to buy one, I really don't know why I haven't yet. mat_the_cat 1
