Volksy Posted September 23, 2017 Posted September 23, 2017 Could do with working out why the ABS sometimes triggers at walking pace, but the light stays off, and it's never showed up on the MOT, so I'm inclined not to bother. My 850 used to do the same, it's entirely normal. Aparently the ABS system does a self check once it reaches around 3/4mph, which normally you wouldn't notice, however it is easy to catch the system out, for example if I was moving around a car park, and suddenly had to stop or happened to be crawling along at just the right speed for the test to happen the ABS pump would go crazy. However a quick dab of the brakes seemed to cancel the test and it wouldn't happen again. Lacquer Peel 1
Heidel_Kakao Posted September 23, 2017 Posted September 23, 2017 Other than the drop links the only preparation I did was to take the air filter out, as I always doWhat's the thinking behind removing the air filter? Something to do with emissions?
CreepingJesus Posted September 23, 2017 Posted September 23, 2017 My 850 used to do the same, it's entirely normal. Aparently the ABS system does a self check once it reaches around 3/4mph, which normally you wouldn't notice, however it is easy to catch the system out, for example if I was moving around a car park, and suddenly had to stop or happened to be crawling along at just the right speed for the test to happen the ABS pump would go crazy. However a quick dab of the brakes seemed to cancel the test and it wouldn't happen again.This was from speed though! Self tests I understand, and both the ex-CMS T5 850 and my old V70 could be caught out like you say. I've experienced it many times at work too, it's possible to hook up to a trailer, roll forward 10' and catch it out the same. The fault in question happened when coming to a halt from speed. It made stopping at the lines at the foot of various sliproads a bit hit-and-miss! Never did get to the bottom of it, and apparently nobody else on fora etc., had ever experienced it either. May have been an iffy speed sensor. Congrats on the ticket Richard. Richard 1
SiC Posted September 23, 2017 Posted September 23, 2017 Could be the reluctor rings (if it has them) moving or slipping. Those symptoms are common on Saab 9-5.
CreepingJesus Posted September 24, 2017 Posted September 24, 2017 That was eliminated too, it was a really weird fault. Academic anyhow as it was never an MOT issue, and it's over the bridge now.
Guest Hooli Posted September 24, 2017 Posted September 24, 2017 This was from speed though! Self tests I understand, and both the ex-CMS T5 850 and my old V70 could be caught out like you say. I've experienced it many times at work too, it's possible to hook up to a trailer, roll forward 10' and catch it out the same.The fault in question happened when coming to a halt from speed. It made stopping at the lines at the foot of various sliproads a bit hit-and-miss! Never did get to the bottom of it, and apparently nobody else on fora etc., had ever experienced it either. May have been an iffy speed sensor. Congrats on the ticket Richard. I used to have a Sierra that did that, it had a bit of trapped air in the ABS module. CreepingJesus 1
garethj Posted September 25, 2017 Posted September 25, 2017 That looks exactly the same from the front as the one in my 1999 V70. Mine isn't the premium system but what it most needs is a direct mp3 input. Do you know if it's possible to use the CD changer wires?
r.welfare Posted September 25, 2017 Posted September 25, 2017 One of the best looking automotive stereos of all time, spoiled only by the godawful font "Premium Sound System" is rendered in. The only way it could look worse is if they used Comic Sans. I think we can all relate to two-minute jobs that take several hours, I had the same thing last week when changing the rear discs and pads on my wife's car. Richard 1
Supernaut Posted September 25, 2017 Posted September 25, 2017 One of the best looking automotive stereos of all time, spoiled only by the godawful font "Premium Sound System" is rendered in. That's the best part! rml2345 and Lacquer Peel 2
jonathan_dyane Posted September 25, 2017 Posted September 25, 2017 It reminds me of the font they used on the old 760 badge
Ghosty Posted September 26, 2017 Posted September 26, 2017 The early ones before the square badges? They're horrible! First time I saw one I thought it was a giffer addition. jonathan_dyane 1
garethj Posted September 26, 2017 Posted September 26, 2017 It is exactly the same, just blacker. Not really worth the effort but it would bother me. I believe you can buy various boxes to plug into the changer socket to give you Bluetooth and other inputs for around £50. I think Yatour and Grom are the names to look for. I don't think there's an easy DIY way to do it. I hadn't heard of that method - thank you. Do you know if it's an HU version like this? The model year looks correct but the button on the front is wrong. Can you remember if there's that kind of round connector on the back? EDIT It seems it's an SC, like this one. And I've just seen SC is written on the front, I am such a twat http://www.ebay.co.uk/itm/Volvo-V70-S70-C70-SC805-CD-RADIO-Cassette-Player-Car-Stereo-And-Code-/112569207682?hash=item1a35a5cb82:g:e8gAAOSwvtFZwOSM Which means this one?http://www.ebay.co.uk/itm/Car-USB-MP3-AUX-CD-Changer-Interface-for-Volvo-SC-Series-V40-S60-C70-V70-V90/182641186317?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D47510%26meid%3D0df9dd9e340944dcb69b01a84381be15%26pid%3D100005%26rk%3D1%26rkt%3D6%26mehot%3Des%26sd%3D271461599583&_trksid=p2047675.c100005.m1851
warninglight Posted September 26, 2017 Posted September 26, 2017 I have done the SC-805 aux input/tape hack, it's a few years ago now but message me if I can help. I found it worked perfectly well. Tried it more recently with an SC-900 (The fancy dolby one with the external amp) but it wouldn't keep a blank 'decoy' tape in the deck to activate the aux input. I didn't bother with any resistors - some guides from memory do mention these, but I had no problems. These days I just lob a modern single DIN do-it-all head unit in. garethj 1
Lacquer Peel Posted November 19, 2017 Posted November 19, 2017 Mounted squint like a proper dealer plate. Sent from my VTR-L09 using Tapatalk Richard 1
Split_Pin Posted November 19, 2017 Posted November 19, 2017 Seems to be behaving very well this motor, all things considered. I like how you are keeping all the little jobs at bay too rather than just living with them as they mount up, one after the other! Richard 1
Tickman Posted November 19, 2017 Posted November 19, 2017 Marianne did a double take on Saturday when we turned the car around and saw Robin's car further down the road! Richard and reb 2
reb Posted November 22, 2017 Posted November 22, 2017 Marianne did a double take on Saturday when we turned the car around and saw Robin's car further down the road!Chuck tells me this one is blue and mine is green. I think they are both green. I have more than once tried to take the wrong car. Sent from my SM-G935F using Tapatalk Lacquer Peel and Richard 2
reb Posted November 22, 2017 Posted November 22, 2017 Turquoise is a green gemstone. Sent from my SM-G935F using Tapatalk
Tickman Posted November 22, 2017 Posted November 22, 2017 Green and green then! Lacquer Peel and reb 2
Supernaut Posted November 22, 2017 Posted November 22, 2017 They look more blue when they're driving towards you. cobblers and Richard 2
CreepingJesus Posted November 22, 2017 Posted November 22, 2017 And people's perceptions of colour aren't 100% the same either. I've had a few arguments with Kay over what colour a few of our cars have been (particularly the 850 which was green on its V5, but I'd have sworn was more blueish), but I usually give in...! chaseracer 1
Ghosty Posted November 23, 2017 Posted November 23, 2017 No, this is green. HTH. cpjitservices and Richard 2
Guest Hooli Posted November 23, 2017 Posted November 23, 2017 No, this is green. HTH. That's JRG but it's not very clear as someone dumped an ovlov in the way...
cpjitservices Posted November 23, 2017 Posted November 23, 2017 Ill raise you my green! Lacquer Peel 1
Split_Pin Posted November 26, 2017 Posted November 26, 2017 I remember a few years ago when I had problems with pattern radiator fan sensors leaking and by the time I bought a genuine item I had spent more on coolant than on the parts themselves. Richard 1
CreepingJesus Posted November 26, 2017 Posted November 26, 2017 I've got spare ally spouts in my collection of spares, if you or REB ever need one: they feel nice and solid when you've got them in your hand, but they do feel fragile when working with them, most 5 pot tinkerers seem to feel the same, and a few have tales of woe. I replaced the one on the T5 because the block side flange looked a bit warped once I'd got it off (it had stuck fast), but the V70's one was ok. Had a replacement stat from ECP in the V70 which fitted, but the ring and gasket were wrong, so in view of the fact that I'd an hour to get it done, get my tea and get to work, I Hermeshited it on, and it stayed that way for years, just fine. Richard 1
Durham850 Posted November 26, 2017 Posted November 26, 2017 Quite a fleet of green volvo 850s building up on here Richard and CreepingJesus 2
