1980 Austin Princess
Interior is back together again and, because of UV damage to the crochet rainbow seat covers, a different rear seat blanket is installed.  All the tops of the seat covers had fading and, in some places, degradation of the yarn itself.  The new blanket shouldn't be as badly affected since it's a different yarn that seems to be more UV stable, but I will be replacing it with something in a better colour for the interior at some point, maybe orange or tiger print...  Rear seat cover is actually essential, Princesses really suffer from bad UV damage to the top of the rear bench and while this one isn't too bad, the top of it is faded and I don't want it to get any worse.  Refitting the centre console was an absolute chore, the screw holes seemed to keep moving, but it's all in now and tidier as a result.  I need to give everything a proper deep clean at some point, I've noticed the handbrake in particular is a bit grubby.
26543046907_5802c0904c_b.jpg20180412-01 by Angyl Roper, on Flickr
41371699402_5f32749472_b.jpg20180412-02 by Angyl Roper, on Flickr
26543046597_4137f80088_b.jpg20180412-03 by Angyl Roper, on Flickr
Had a go at sorting out the very annoying driver's door today which has been sagging since I bought the car.  Sometimes the sag seems to be caused by the hinge pin moving too much, sometimes it doesn't, I've never really got to the bottom of it.  However, Des suggested I try jacking the door up with a block of wood which may reset things that might just have drooped with age and use.  On the passenger side that worked moderately well and the door frame no longer contacts the B pillar at the top, the panel gap is a bit more even, and it shuts a bit better.  It's not perfect by any means, but it's okay.
27583970218_8f7d8fa9bf_b.jpg20180414-01 by Angyl Roper, on Flickr
The driver's side was more problematic.  I repeated what I did on the passenger side and got some small improvement on fitment, but it was still catching on the B pillar at the top because of the door sagging.
40561673125_2b356c8696_b.jpg20180414-02 by Angyl Roper, on Flickr
27583969018_ffb2bfd428_z.jpg20180414-03 by Angyl Roper, on Flickr
The bottom of this door is a bit tender, has been all the while I've owned it, and when I moved the jack and wood for a better place to lift it, the block of wood vanished inside the door.  Looks like the tender bit is actually rotten now and it needs a repair to the frame and door skin.  I've got a spare door and some steel so it's repairable, but it made the realignment a little more difficult.
40561672205_7154247b70_b.jpg20180414-04 by Angyl Roper, on Flickr
Not quite as effective having the block to the front of the door as I can't really lift and bend things to counteract the sag as effectively.
40740784364_98f13399c5_b.jpg20180414-05 by Angyl Roper, on Flickr
I got the door close to shutting without catching the B-pillar and then resorted to moving the latch on the door and the pin on the B pillar to help me out.
40740783764_5ea676d956_b.jpg20180414-06 by Angyl Roper, on Flickr
The door gap is at least even now but the whole door seems to be pushed back about 2mm or so too far.
40740792674_eb7f6130ab_b.jpg20180414-07 by Angyl Roper, on Flickr
I'm going to drop the door off, knock the hinges forwards a couple of millimetres and refit the door.  I'll pull the wing off when I do this too so that I can repair it properly, a job I've been putting off for ages.  I don't think this issue is from the damage it got in my care because the door was like this when I got it, I think this is a more historic problem, and a little persuasion with a large hammer should see it right again.
Door adjustment is always a pain, every adjustment you make throws out every other adjustment. Pain.
Time to focus on more important matters, like painting that B pillar black.
I don't want to paint the pillar until I'm sure the door isn't going to catch on it and rub the paint off, like it has on the passenger side.  One small job seems to lead into much larger small jobs to put this right, it's super annoying.  While fettling today I was really unhappy with the line of the replaced sill and the bottom of the repaired rear door, the panel gap is all over the place.  It's fixable, of course, just really time consuming to get right as all cosmetic jobs tend to be.  So I'm going to start on the most annoying bit, which is the driver's door, and work my way around the car from there, fixing as I go.  Seems the most sensible course.
In better news, the new windscreen seals are now approved for production - it's been a slog getting the right profile - with a lead time of 5 weeks, so hopefully I'll have that to fit to replace my leaking seal by June when I'll no doubt uncover even more things I don't know about that need fixing.
Glad to see you've adopted the British Leyland ethos, life shall now get easier.
I wonder if an engine crane and sling or ratchet strap / roof joist through the window frame of the crusty door would be better.
Getting that door to fit properly with everything else could take many lifetimes.
BL had millions of attempts at the good-panel-fit carry on, and their scientists eventually declared "it's fucking impossible".
Am not specifically knocking BL.
Have you considered taking a skim off the upright edge of the door with a grinder? Not too much, just enough to avoid contact, and done neatly. Then black paint, as mentioned above. (Serious reply).
In the scheme of things no one's going to notice (except us, hahahahaha! :-)), and it's just part of the character of the car.
"Good panel fit on a BL car????".
- Boring, dull, dull, dull.
Means more time available to do other jobs.
Or just chop the top doorframes off and make cool pillarless doors. Although that may unintentionally also lead to windowless doors. But they'd close ok without striking at the top.
Des:  I wouldn't want to risk it, the window frame on these doors isn't that strong, even if I could get the crane or whatever high enough to actually lift it.  "It'll do" does seem the most practical approach.
Jee:  Shaving bits off the doors doesn't fix the problem.  The panel gaps aren't the annoyance so much as the frame catching on the B pillar and the door not latching properly when you try and shut it, both problems that I've fixed enough that I don't need several slamming attempts to shut the door now.
I'm digging the orange one out in a bit and swapping that on so I can repair the beige one off the car, doing the bottom edge repair is going to be lots easier with the door off the car. and I don't really want to work on the Rover today.
Setting the door-latch position can be a bit of an art. Maybe there's a body-shop procedure beyond trial & error that some of the specialist car-bods on here know about. Or something on youtube?
It's very satisfying when a door just clicks shut.
And most annoying when the one on the other side has to be slammed. Or opens on a bumpy corner (a mate had a knackered Mk4 Cortina Ghia with a rear pass door like that and he didn't always remember to tell passengers about it).
If the orange door is better, or a better fit, obv worth going plan-B and just keeping it on and repainting it in the current Vulgcess colours. Then fit the existing one into the nearest skip and see how it likes that.
Black front seats and orange carpet looking good BTW. Carpet was well worth the time and effort, these things always a little bit 'experimental.
Watched a Brewer Owld-Ahht-Yer-Aand early this morning. He had a gorgeous met blue Fiat Dino 2400 coupe with black leather seats and orange carpets. The original factory-orange carpets, in great condition. Looked fantastic.
He got Ed / Edd to swap in good quality custom-made ones. Very nice handcrafted ones. But in black.
Noooooooooooooooohhhh !!.
Owld-Ahht-Yer-Face Brewer.
- SLAP !
This job went surprisingly well.  I believe this is the first time I've taken the driver's door off.  Initially I did tape the door switch down but the tape wasn't strong enough, so I disconnected the bulb instead, didn't want a flat battery or, worse, a melted interior light.
27604782348_a846db100f_b.jpg20180415-01 by Angyl Roper, on Flickr
With the door off I could check the hinges out.  There's no play in the bottom hinge, but there is a little in the top one, so I knocked the hinge pin out.  Annoyingly, the replacement pins I've got are all bottom hinge pins which I can't really use in the top hinges and you can see on this one that there is some wear.  It's not enough to cause the sagging/alignment issues I'm having so I just cleaned it up, greased it, and put it back in after knocking the top hinge forwards a bit to counteract the sag.
27604782448_c994651c46_b.jpg20180415-02 by Angyl Roper, on Flickr
Realistically, I need to whack both hinges forwards a smidge more with a larger hammer than I had to hand today and that should sort out the alignment but I'll also have to pull the wing off because it's quite tight to the door at the moment due to it being slightly deformed.  First fit of the spare door was quite positive.  The gaps are more even all around now and the sag is much reduced.
27604782068_b381b56678_b.jpg20180415-03 by Angyl Roper, on Flickr
41433773832_3f5653603e_b.jpg20180415-04 by Angyl Roper, on Flickr
You can see here where the swage line of the wing is pushed in too far, closing up the gap.  I can sort this out when I remove the wing and repair it, the panel just needs a little massaging to sort out the clearance.  Surprisingly the door doesn't catch the wing, though it does come very close!
27604781718_eeaabb37a1_b.jpg20180415-05 by Angyl Roper, on Flickr
The spare door is probably a bit far gone to repair having looked at it with a critical eye compared to the one that came off.  There's rust in places that are going to be difficult to repair and several stress fractures in the frame and outer skin.  It's also slightly deformed on the lower edge, so it doesn't line up quite as well as it might with the car.  I can repair it if I have to, and I may well do so because having a spare panel is useful.  For now it's ideal for filling the hole while I repair my better door and with Princess doors being quite difficult to find in any condition, I do have to work with what I've got.
40762430054_a8f8c17bc7_b.jpg20180415-06 by Angyl Roper, on Flickr
After a little more fettling I had the door fitted and annoyingly even though it's in worse condition than the one I'm repairing, it fits the car better!  The lock works with the key I've got which saved me swapping the more awkward linkages over, it just looks dreadful.
41475984331_8ee5a3ebb2_b.jpg20180415-07 by Angyl Roper, on Flickr
On screwing the window guides back to the door frame I was a bit confused at first as to why the window would drop happily enough but wouldn't go up evenly.  Turns out that one of the guides for the window regulator rollers has rotted away completely so the back edge of the window doesn't lift evenly and tries to drop into the door.  Because this is likely to be a chore and I don't want to go for the window out of habit, I didn't refit the window winder.  If nothing else, that'll be good motivation to get the door I removed repaired and back on the car.
27604781188_576c77e733_b.jpg20180415-08 by Angyl Roper, on Flickr
I reattached the weather strip/stainless trim and the door mirror to complete the day's work and loaded the spare door into Mike's estate.  I hope to be tackling the repairs and repainting the door I removed over the course of this week.  If I can find a new or really good pair of upper hinge pins that would be neat too as every little will help with alignment.
27604780538_b485ed2fba_b.jpg20180415-09 by Angyl Roper, on Flickr
Interesting day's progress.
(Why does that last pic look so good?).
Just a thought, but have you considered gullwing doors at all as a possible remedy?
Extra points for using a Paykan Hunter to demonstrate your gullwing suggestion there.
The doors on my Triumph Toledo close beautifully with just a gentle push. Such a nice satisfying 'clunk'.
Sorry.
If I hadn't fitted new door seals, mine would too.  Your door seals are probably knackered :P
Have you seen the retro looking stereo in the News 24 thread? Saw it and thought of what you were trying to source for the Princess.
I started reading this thread this morning.  Over a few hours, I'm about 10 pages in.  Wow.  Great stuff!
Sorry.  Now back to your scheduled programme...
I had not, but that does look ideal.
I thought a DIN unit wouldn't fit? It's why I haven't pasted the link in here too.
It's shorter and lighter so I wouldn't have the wobbly issue so much.  I also thought from the picture initially that it was smaller than standard DIN, which again would have been easier to fit, potentially in the lower centre console.  However, on looking up stats on these units most are only rated at 30W (per speaker, max 4 speakers) so it's actually a little underpowered as a complete unit for what I'm thinking of doing.  I'm looking at fitting something in the 50-60W range instead so I'm back to the drawing board a little bit on this one.
What about adding an extra external amp? A lot of these power output wattages are often meaningless. Especially stated specs on cheap Chinese gear.
I've been looking at stuff like Pyle and Bassface headunits that have better basic stats and often look nicer.  There's also an interesting update on Sweetpea's MR2 thread where he uses one of those tiny basic MP3 players hidden in an ashtray which I quite like: http://forum.retro-rides.org/post/2405483/thread
The phrase "as rough as a badger's arse" comes to mind.
It is amazing to see the evolution as time progresses, keep on keepin' on!
Nah mate, deffo superior Triumph build quality innit mate. Innit.
Sorry, can't do keyboard Cov accent.
I've got 20W speakers hooked up to the original radio in the Triumph Acclaim and anything above 1/3rd volume causes the entire interior to vibrate and rattle
Depends largely upon the sensitivity of the loudspeakers (how much volume they generate for a given power input). I have a pair of speakers in the living room that a 24 Watt amplifier makes the crockery rattle on the other side of the room. I have another set that only start to get up to a decent volume by the time they're getting about 10 Watts pushed into them.
Most car speakers tend to be fairly crappy in terms of that- and they can also turn a decent head unit into a disappointing turd. For low wattage units look for speakers with sensitivity ratings over 85dB. A lot of car speakers are down in the 65dB range, which makes their power output terrible (but they can handle a lot of wattage for the sticker on the back).
I'm ignoring the tunes situation for now and focusing on Other Things.
I was going to start dismantling and cleaning up the door I removed ready for welding and paint.  Before that, I wanted to see if I could move the wing at all so I could push the A pillar hinges forwards a smidge without the door catching the wing.  The simple solution is big hammers, but I want this to look nice when I'm done so we shan't be doing that.  Instead, I double-checked what I needed to do to remove the wing with minimal damage to it so I can repair it off the car.  I'll likely convert to bolt-on because alignment, etc. is going to be a lot easier and, if I get a really nice pair of wings in the future, it will be a lot easier to remove these old ones.
So, to remove the wing you have to unbolt the 4 bolts that attach it to the A pillar.  You can't get to these bolts without removing the door.  You can't remove the door without stripping the trim off it again and the door is held on with six nuts at the hinges.  Then you have to drill out the spotwelds holding the wing to the car.  There's a lot of spotwelds.  I had enough time today to remove 26 of them.
26628080217_dc09897131_b.jpg20180416-01 by Angyl Roper, on Flickr
There's another half dozen or so spotwelds at the nose end of the wing around the headlight aperture and a few more on the wing rail that I can't get to because the bonnet is in the way.  So I'm going to have to take the bonnet off too.  Added to this is the complication that this is my everyday car, so it can't really come off the road while I do this during the week.  I hate welded on wings, they're a chore to remove.
Mike has been really rather unwell lately so I've not had a helper for the next stage of wing removal.  He's on the mend, happily, but a trip to the hospital was rather more important than taking my car to bits.  As a result, with today being the first really nice day of the year and me hoarding a few supplies in preparation, I decided to make a start sprucing up the outside of the Princess much like I did the engine bay.  We're not going for super professional show quality here, just tidy and clean.
I'm focusing on the passenger side as that needs less work and I'm breaking the job down into smaller sections so I can deal with the best bits first and leave the repairs for last.  This is an odd way of doing it, I'm aware, but if I make as much of the car presentable as I can, blending in the repairs will I think give me a much bigger boost and allow me to properly draw a line under things.  Aiming for perfection with this car at this stage is silly, far better to aim for presentable.  Right, excuses out the way, here's what I got on with today.  Only tackled the beige on the passenger side doors and rear wing.
40852038774_23d7de1d9c_b.jpg20180419-01 by Angyl Roper, on Flickr
40670923235_4839e6d675_b.jpg20180419-02 by Angyl Roper, on Flickr
It's quite difficult to photograph!  I didn't mask off the lower portion because I'll be redoing all of that with fresh paint.  The purple on the lower half was fairly hastily applied for the most part so I'll be sanding back through a lot of it when I do the preparation.  There's a couple of areas that showed up as needing a little more attention once I started getting a shine on the panel, which I'll likely tackle in the future, but they're not bad enough that I feel I have to do them right away. There's a huge amount of overspray on the lower half because there was no point wasting materials masking it off since I'll be keying it all back and dealing with imperfections before putting fresh paint on.  I'll obviously take more care masking off the fresh beige when I do the lower portion though.
Here's a shot without so much exposure.  The finish is pretty reasonable.  There's a couple of spots where historic dents are visible in person from certain angles that just don't show up in photos.  So that's fine really, isn't it?  The beige is pretty flattering to panel imperfections.
40670923265_64be7fa54a_b.jpg20180419-03 by Angyl Roper, on Flickr
The boot lid was never finished either, I had to rush to get that back on.  You can see that the paint on it is far too thin, especially compared to the rear wing.  I'll wet sand and polish things once I've got everything tidied up properly like this.
40852038444_f67782c867_b.jpg20180419-04 by Angyl Roper, on Flickr
I'll put the trim on either much later tonight or tomorrow, I don't want to accidentally damage the fresh paint refitting trims since I can still use the car with them off.
Now the sun has gone down a bit I could get a better shot of the finish.  Only one bug (successfully removed without paint damage) and minimal dust issues is pretty impressive for a driveway rattlecan paintjob, if I do say so myself.
40852778034_786d929e2f_b.jpg20170419-05 by Angyl Roper, on Flickr
Job done. (Paint).
Leave it just as it is. I don't think it really needs anything else. For now.
Had any more thoughts about doing the Fairlane rocket tail-lights?
With the driver's wing, rather than fit another temporary wing then refitting this one again, - how about filing the existing trailing wing edge (or the beige door front edge) a little to create a bit of clearance so you can shunt the door-hinges forwards?
What the fuck do your neighbours think?  :shock:
Jee:  I've got another wing that's rotten in all the places the one on the car is good so I'm combining the two to make one good wing and deal with all the problems.  I can always modify the repaired final wing if needed for clearance.  The Fairlane lights will go in I think when I've dealth with the wing, doors and what paint I can do.  I'm in no rush, especially while the Princess is my sole transport, I'd rather take it off the road for a long weekend or a week and get the whole back panel done in one go.
Rev:  I don't know, they've never expressed concerns.  We have fairly decent relations with them to the point that tools can be loaned and returned safely, parcels taken in for other folks or for us, if missed.  I don't push my luck and they don't seem to complain so we've probably got a fairly healthy balance.
