Lacquer Peel Posted June 24, 2022 Author Posted June 24, 2022 Some nice scenery behind the MOT place. sdkrc, privatewire, Zelandeth and 6 others 9
Lacquer Peel Posted June 24, 2022 Author Posted June 24, 2022 Yasss! Tenmil Socket, puddlethumper, Stanky and 25 others 27 1
hairnet Posted June 24, 2022 Posted June 24, 2022 'despite' lmfao is @Frogchod jealous of the peugeot now sort the brakes out and itll be airport runs noo? Lacquer Peel 1
Lacquer Peel Posted June 25, 2022 Author Posted June 25, 2022 It camps well. AnnoyingPentium, Flat4, privatewire and 15 others 17 1
Lacquer Peel Posted June 25, 2022 Author Posted June 25, 2022 TurboD sdkrc, juular, privatewire and 6 others 9
Lacquer Peel Posted June 25, 2022 Author Posted June 25, 2022 Veg station shot for @Datsuncog Dave_Q, Tenmil Socket, juular and 5 others 6 1 1
Lacquer Peel Posted June 25, 2022 Author Posted June 25, 2022 Oil companies HATE this engine! Scruffy Bodger, Jim Bell, Stinkwheel and 8 others 8 1 1 1
jaypee Posted June 28, 2022 Posted June 28, 2022 On 6/25/2022 at 1:22 PM, Lacquer Peel said: Oil companies HATE this engine! You WON'T believe what happens next! CHIPS loserone, Lacquer Peel, Fumbler and 8 others 11
Lacquer Peel Posted June 28, 2022 Author Posted June 28, 2022 4 minutes ago, jaypee said: You WON'T believe what happens next! CHIPS Well, yes. jaypee, 320touring, juular and 5 others 4 4
Jim Bell Posted June 28, 2022 Posted June 28, 2022 As they say in Italy, BELLA VEGERTAL! privatewire, Lacquer Peel, juular and 1 other 2 2
Lacquer Peel Posted June 28, 2022 Author Posted June 28, 2022 Bonne vegertal! Jim Bell, sdkrc, 320touring and 4 others 6 1
aldo135 Posted June 28, 2022 Posted June 28, 2022 Great purchase with the camper, loving the Volvo write up too I think I’ll just stick with diesel for now… I don’t do a massive mileage to be fair! 320touring, Lacquer Peel and juular 3
alcyonecorporation Posted June 29, 2022 Posted June 29, 2022 Ya should have said - I'm not that far from where it was! Lacquer Peel and juular 2
Lacquer Peel Posted June 29, 2022 Author Posted June 29, 2022 14 minutes ago, alcyonecorporation said: Ya should have said - I'm not that far from where it was! I did think that but we were tight for time!
Lacquer Peel Posted July 10, 2022 Author Posted July 10, 2022 200k achieved. I have been using this almost daily and it's been great. It has a soft ride with chunky tyres so soaks up all of the cratered roads, the engine is smooth and runs on many % veg. Great van. Tickman, CreepingJesus, Scruffy Bodger and 10 others 13
Lacquer Peel Posted July 10, 2022 Author Posted July 10, 2022 Just now, Supernaut said: Could do with a thermostat! Aye maybe! It does settle at 70-80 while cruising.
artdjones Posted July 10, 2022 Posted July 10, 2022 1 hour ago, Lacquer Peel said: 200k achieved. I have been using this almost daily and it's been great. It has a soft ride with chunky tyres so soaks up all of the cratered roads, the engine is smooth and runs on many % veg. Great van. They just float along in a very French way. The only reason I've never bought one is the roof is too high to take ladders on and off. Lacquer Peel 1
scorchio69 Posted July 10, 2022 Posted July 10, 2022 On 6/24/2022 at 12:48 PM, Lacquer Peel said: Yasss! Quite a fitting number plate to boot Lacquer Peel 1
Zelandeth Posted July 11, 2022 Posted July 11, 2022 9 hours ago, artdjones said: They just float along in a very French way. The only reason I've never bought one is the roof is too high to take ladders on and off. Really wish the Caddy floated along. The ride is the single thing about it which bugs me the most. It really is bloody harsh.
Lacquer Peel Posted July 11, 2022 Author Posted July 11, 2022 4 hours ago, Zelandeth said: Really wish the Caddy floated along. The ride is the single thing about it which bugs me the most. It really is bloody harsh. They have quite a harsh ride but I found my Caddy handled really well to make up for it.
Zelandeth Posted July 11, 2022 Posted July 11, 2022 3 hours ago, Lacquer Peel said: They have quite a harsh ride but I found my Caddy handled really well to make up for it. That it does. It's absolutely possible to forget there's a big box behind you. Though the damping on the rear is so stiff it tends to skip around on even vaguely uneven surfaces. I reckon the spring rates are fine, it could just do with slightly softer dampers. Lacquer Peel 1
Lacquer Peel Posted October 21, 2025 Author Posted October 21, 2025 Hey gang, I've had my time with this van sadly. It is great but the faults have got on top of me, it pressurises coolant - no oil in the water, no water in the oil, doesn't overheat, I tested for combustion gases and if I did it correctly there are none present. All a bit odd but it'd drive anywhere if you kept topping it up with water. Big exhaust blow but there is a new section without a particulate filter (yeah some 90s diesels had a primitive "cat") to go in its place. I would really like for it to live on, I've put a fair bit of work into it and it is fundamentally a good van that needs the big faults fixed and a rolling resto I would say. Message to discuss if you are interested, would like around £1000. Rust Collector 1
dean36014 Posted October 22, 2025 Posted October 22, 2025 Mine did exactly the same, made 214k then started pressuring the coolant. Ripped the head off and put a recon one on as it worked out cheaper than having one skimmed and the seized injectors removed. The bores were near mint, cross hatching still plainly visible. Goes well now. loserone and Lacquer Peel 2
vaughant Posted October 22, 2025 Posted October 22, 2025 My hdi version did exactly the same but it was just a partially blocked rad in the end and really, really easy to replace on the Partner, albeit maybe a different design to this. However mine also had A/C but was still a changed in the work carpark jobbie. Looks a great van in a great colour. I'm sure someone will give you a grand for it 🤙🏻🤙🏻🤙🏻 Lacquer Peel 1
tom13 Posted October 22, 2025 Posted October 22, 2025 21 hours ago, Lacquer Peel said: Hey gang, I've had my time with this van sadly. It is great but the faults have got on top of me, it pressurises coolant - no oil in the water, no water in the oil, doesn't overheat, I tested for combustion gases and if I did it correctly there are none present. All a bit odd but it'd drive anywhere if you kept topping it up with water. Big exhaust blow but there is a new section without a particulate filter (yeah some 90s diesels had a primitive "cat") to go in its place. I would really like for it to live on, I've put a fair bit of work into it and it is fundamentally a good van that needs the big faults fixed and a rolling resto I would say. Message to discuss if you are interested, would like around £1000. Do you have any interior pictures? Cheers
Lacquer Peel Posted October 22, 2025 Author Posted October 22, 2025 1 hour ago, tom13 said: Do you have any interior pictures? Cheers Hey, it's stored at my friend's place away from home, I'm doing a block of nightshifts then going on holiday. Will have interior pics as soon as I can but not right now. This is a shit interior shot I took when I last camped in it (May this year). It is not a coach built camper, I think it was a taxi originally, but someone's done a really good job of it with good quality kit. It is genuinely comfy for one person (I'm big and tall and can stretch out) or an intimate couple. It has a bench seat with seat belts that converts into a bed, with trimmed cushions that make up the seat. Rock and roll bed isn't it? There are 2 gas hobs, a power hook up, leisure battery, lots of power points for USBs, lots of LED lights on switches, sink with fresh water and waste tanks. I broke the tap off but have a new replacement to go in. It also has captains' chairs in the front. Oh shit I'm selling it back to myself now. It is genuinely a great wee camper that needs a fair bit of love that I don't have the capacity for just now. To add it has had the following over the last few years - Good replacement gearbox from a Peugeot 806, NOS genuine clutch kit, clutch cable, all 4 shock absorbers, front wishbones, track rod ends, brake discs and pads, reconditioned subframe (shout out to the finest welder in the Falkirk area @juular), 4x Maxxis all season tyres and various other bits and bobs. The bodywork is a bit tired, the side doors don't close well but the underside is remarkably solid and rust free. Dyslexic Viking and loserone 2
Lacquer Peel Posted October 22, 2025 Author Posted October 22, 2025 5 hours ago, dean36014 said: Mine did exactly the same, made 214k then started pressuring the coolant. Ripped the head off and put a recon one on as it worked out cheaper than having one skimmed and the seized injectors removed. The bores were near mint, cross hatching still plainly visible. Goes well now. I wish I had the capacity to sort it genuinely. If anyone is up for doing the job I have the money to pay for labour and parts. It's just finding the right person who would do a big job like that on what looks like a shit old van.
dean36014 Posted October 22, 2025 Posted October 22, 2025 18 minutes ago, Lacquer Peel said: I wish I had the capacity to sort it genuinely. If anyone is up for doing the job I have the money to pay for labour and parts. It's just finding the right person who would do a big job like that on what looks like a shit old van. I took the engine and box out when I did mine, far easier that struggling under the bonnet. Did everything whilst I had it out, clutch, hoses, driveshafts and engine mounts. Genuinely drives like new now. Tickman and Lacquer Peel 2
