1984 Mini - Simplify and add weight
Mrs D's Mini has been used as a commuter for 20 odd miles a day in all weathers for the last 6 years, and it's now at the stage where it needs a bit more than just pre MoT fettling.
It's a one owner from new until 2014 car, bought from Wicliffe Rover in Stroud in 1984 by Miss Halford, on her retirement as a primary school teacher. 30 years later she gave up driving, and I bought Silver Susie (as she called it) for Mrs D as a birthday present. She's wanted another ever since she learned to drive in one. TBH I thought she would quickly get sick of the lousy driving position, shit brakes etc and opt for something more modern, but she loves it! Especially as I replaced all the knackered, 30 year old rubber suspension cones early on.
Last year it started jumping out of 2nd on the overrun more and more often, and syncro on 2nd and 3rd was not very special either. There was a rot hole in the rear valance, and the engine was pissing out more oil than it burned, which was quite a feat. It's done about 65k, so long in tooth for the engineering brilliance that is BL! It's always been 'maintained' by one of the local garages, who've committed acts of bodgery I'd be ashamed of, including fitting a s/h Metro van gearbox at some stage. So it's running a stupidly low diff ratio, meaning the speedo is useless and it screams like hell at anything much over 60. I limped it through another MoT by replacing the front balljoints and fettling the brakes a bit, but by the end of last summer I thought we should spare it another wet n salty Cotswold winter and sort it out properly.
The plan is:
  • rebuild / refresh the engine - head job, bottom end inspection and bearings as needed
  • fit stage 1 kit to add a few more beans
  • replace all gaskets and bring the oil leakage down to something normal
  • replace the gearbox and diff
  • clean the engine bay, treat rust and repaint
  • replace the rubber front suspension bushes, engine mounts and all that cheap stuff
  • sort the back end rust out - weld up the valance and any other bits
  • rattle can spray job on the repairs as best I can
There's probably more, but that's all I can think of for now. More later, plus pics of all the action so far!
ps If you know anything about old Minis, I will badly need some expertise. It's not a Land Rover, so I know fuck all about these.
Ask away, I have messing with these for 30 years now. I have a load of spares as well if you are short of anything. For the gearbox, buying a second  hand one will always be cheaper short term than a rebuild but it can be hard to tell how many miles are on. Minispares do a decent recon service if you want a good one. Rebuilding one yourself isn’t beyond the average DIYer but like any box, they have a few quirks that can be a pain.
I've split a mini engine and box in the kitchen,
I remember nothing about it except my late wife's  still complaining  in my head.
OK chaps - thanks for all the ideas!
I started about 2 months ago just going off the HBOL and stripping things off the engine, until by today we were nearly at this stage:
All the bits n bobs pulled off easily enough, and everything was ready for the dirty oily bits to be disconnected, because I knew that this was happening:
Bone cyst removed, bone graft and some other stuff. 6 weeks off legs, which ended just as the lock in crap began. Bollocks.
Anyway, I turned up the engine crane on FB Marketplace for £40 just round the corner - it was as new, having removed one engine. Result!
I also found a very pretty rebuilt box with a 3.11 diff on Ebay for £260:
so that should be on its way here from Retford at some stage.
Moar shortly
  • Like 16
3 hours ago, The Mighty Quinn said:
1984 is the change point from 10 to 12 inch wheels. I wonder if it has an Allegro box - now that will be seriously undergeared. The FD on those was about 4.1/4.4 due to 13 inch wheels.
Yes, an Allegro box in a mini would be pretty awful.  Final drive on Allegros:
1100 : 4.11
1300 : 3.94
1000 A+ : 4.33
1300 A+ : 3.76
This looks great. Moar pics please!!
Wow. A Mini25.
My first car was a 1985 Mayfair which had been my dad's. Only 5 years old at the time.
(the car, not me).
There was a 25 in the showroom but dad didn't like silver.
Didn't they rot at an alarming rate even for a mini?
Mine was scabby around the headlamps and ends of the sills at 5 years old but every 25 I saw was hanging. A panels, bonnet edges door bottoms, scabbing up everywhere.
Miss Haford must have got discount waxoyl from her famous uncles shop.
Change the drive shaft oil seals and fit a gearbox rod change oil seal which is like a rubber O ring.
They lurrrrrve to leak from there. As well as everywhere else.
Burning oil is possibly valve guides. Especially if smoking on the overrun.
Changing the valve stem seals can mask the problem for a while but will probably need new valve guides which will need machining and valve seats recutting.
It is possible to mix and match A+/pre A+ engines and boxes, just more of a faff.  You need the correct end plate, idler gear and primary gear to match the choice of gearbox (primary gear also differs between 1275 and the smaller engine sizes).  My Austin 1100 has a 1300 A+ engine on top of its original gearbox (albeit with higher diff fitted).
Well, lucky I got the right box then! The guy's prepared to post it - Parcelfarce are only about £15 - as it's under 30kg.
Just hope it doesn't arrive as a smashed up lump of ally, but no real alternatives under the current shitey circs.
Guessworks reckon it would originally have had a 3.1 diff:
http://www.guess-works.com/Tech/engine.htm?P1=99H&LP2P=&P2P=&LP2=&P2=A53&LP2S=&P2S=P&LEN_NO=&EN_NO=0100646
eta Couriers are mostly not interested in gearboxes. Any suggestions / recommendations?
14 hours ago, stuboy said:
id love a mini.....
I'd like to see a mini that you'd done your magic on!
1 hour ago, The Mighty Quinn said:
Tell them it's an alloy casting. PF don't care.
Brilliant idea - thanks for that!!
OK, so next installment.
I don't lying on my back on garage floors anymore, so I'd left all the shitty dirty heavy underneath jobs til last. My 6 year old daughter reminded me the other week though that in her opinion 'I was never going to fix the Mini'. Challenge accepted.
All the suspension joints came apart easily as I'd done them last year for the MoT:
Even the driveshafts popped out easily with a bolster chisel as a lever. BL special tool my arse.
The bolt in the gearchange housing securing thingy was a PITA, but the worst were the fucking stupid engine mount bolts. They're bolted through the subframe here and here:
but instead of using captive nuts or fixed studs like any sensible manufacturer, BL use a separate nut and bolt, with fuck all access to the nut or bolt head on the inside. I think they were the only hold up, and pretty soon we were here:
Get in!!! Or out, I suppose. Leaving this lovely gap ready for a Hayabusa engine I swapped with my mate for a brokn X box and some pix of my exs fanny:
Not really.
Fit an extra oil seal in the selector rod - tap the existing one in about 5mm and fit another one on top. That pretty much eliminates that annoying drip.
You shouldn't really need 2 oil seals. The problem with these is that the rubber bellows which fits over the selector rod and should keep out the dirt and water goes stiff very quickly. When you select second, fourth or reverse gear the rod moves in to the gearbox and squashes the bellows, then when you select first or third the rod moves back out but there is nothing to stretch the bellows back out again. So it stays compressed, the rod is then exposed to all the crap flung up under the car, and the next time the rod goes in the dirt and grit on it wreck the oil seal.
Many moons ago I had numerous minis, 1100s and other A-series front wheel drive stuff which used this rod-change arrangement. I used to have to change these oil seals at least every six months as they would always leak by this time.
I finally hit on the idea of using superglue to fix both ends of the bellows. After degreasing the gearbox casing entry point and the front of the circular coupling that attaches the gearchange rod, superglue one end of the bellows to the casing, squeeze it up and slide the coupling over the rod, fit the front roll pin, then run some superglue around the back of the bellows and glue it to the front of the collar. Then the bellows will be stretched out when the rod moves out and will still protect the whole length of the rod.
After having done this mod on several vehicles, some of which I had for more than five years,  I never had to replace one again in my ownership.
When I bought our current Maxi, which uses the same system, it also predictably had a leaking gear change oil seal so one of the first jobs I did was this, and it is still oil tight after 3 years.
 Hi, The trick with the engine mount nuts and bolts is to weld the nut to the mount flange, you don't need to go mad just a good tack weld to hold it in place until you get the bolt in.
 Colin
Ah man I remember doing this a few times when my mini engine shit the bed. I was working on my nans drive, and while carrying the gearbox I walked underneath a hanging basket, banged my head on it and it fell off the hook and emptied the entire contents, soil, plants and gravel into the gearbox. I laugh now but at the time I wasn't so chipper.
I do remember the flywheel was a right sod to get off and when it finally went it nearly send my mate halfway down the drive. Good times. It's been just about long enough since that debacle that I quite fancy a mini again, but unfortunately you can't buy a solid one for £2000 like I did ten years back.
 Colin
I'll be happy to throw a few quid at a pair of these when it goes back in:
http://www.minispares.com/product/Classic/21A1902ST.aspx
Right, final update for now.
As you might have noticed, this engine runs the Torrey Canyon a close second in terms of oil tightness. So it's filthy with all the oil that's been puthering out of every seam for the last fuck knows how many years. I made a halfhearted attempt to trace the leaks once, and decided it must be leaking from EVERYWHERE as no bit looked any cleaner or dryer than the other.
Here it is in all its nastiness:
I brought out my biggest guns: a jar of paraffin and a stiff (fnarr) brush, and set to it with the aim of befouling my driveway with as much shite as possible. Plenty of attention all around, followed by half an hour of soaking then a blast with the pressure washer.
Then another brush and a pot of TFR or truckwash stuff, followed by another half hour soak, followed by pressure washer, and finally...
That's better.
Time to order some bits and start work on the head.
I'd be careful using these. You often need to use a screwdriver or similar to line up the mount hole and the subframe hole.
If you damage the captive thread or crossthread the bolt in the captive thread then you end up with the spinning captive nut that you cant undo. I've been there. It's fun.
My guess is that is the reason a screw and bolt was used by bl.
Happy to be corrected there though.
I agree with the above regarding thise god awful engine mounts with the captive nuts.
I tried them a couple of times and both times the captive nut came adrift part way through tightening the bolts due to the thread becoming damaged. It doesn't help that the threads are made of cheese.
I won't use them anymore and just persevere with the correct original type for 15 minutes which is far less time than it will take to try and accurately line up the mounting points of the aftermarket captive types and get the bolts started.
Love a mini 25. I have one myself that's ended up as a stalled full restoration. I spend all my time restoring them for other people nowadays.
Good luck with the box change mate.
Ben
Oil leak from front is very often the half moon seal not front crank seal.
Easy when engine out but couple of hours work when in car but if swapping the box you'll have to change it anyway.....it is the front seal on gearbox and butts up to the rear of timing case
10 hours ago, The Mighty Quinn said:
The thing about Minis is that whilst considered a bastard to work on years ago, compared to modern stuff they're a piece of piss really and mildly awkward.
This is true.
Bugger all in the way of electronics, and actually reasonable accessibility to most things compared with a lot of moderns. Even the utterly hidden (like the speedo drive) you can get at via relatively easy engine removal!
Sicko. He’s not gonna be opening his wound, just to salivate your warped mind!
  • Sad 1
Just ordered this little lot from Mini Spares:
Part code Description Quantity Unit price   Amount
AJM1250 HEAD GASKET SET 850/997/998/1100 ALL SMALL BORE INC A PLUS 1 £10.70   £10.70
GFK5185 SETSCREW 5/16 x 1 UNF 4 £0.21   £0.84
21A1902ST ENGINE MOUNTING WITH EASY FIT CAPTIVE THREADS MANUAL GEARBOX 2 £3.15   £6.30
CE1 DUAL FLYWHEEL PULLER VERTO AND PRE VERTO 1 £20.25   £20.25
C-STN17 PERFORMANCE STAGE ONE KIT 998 1 £195.24   £195.24
CRC5329 RUBBER ENGINE STABILISER BUSH (SINGLE) 4 £0.50   £2.00
AJM100MS MINI SPARES COMBINED BLOCK/GEARBOX GASKET AND SEAL KIT 1 £24.00   £24.00
MSSK050 GEARBOX ROD CHANGE ANTI OIL LEAK SEAL ! KIT 1 £4.25
£4.25
Should keep me busy for a while.
There was a big thing for the Mini's 25th birthday at (I think) Donington Park. I drove up there from the Sarf Coast in a Renner 16, alone, slept in the car (comfy!) and drove back with increasing noises from the gearbox which had me wishing I'd joined the RAC. Made it back home (just) and had to fit a s/h gearbox.
No progress in the past few days - been chopping and shifting firewood whilst the weather's good:
but something beautiful and important turned up in the post just now. Obviously this'll get a repaint whilst I'm at it:
and what could be better but to restore the original glamour* and sophistication* of its hi tech nature:
Blimey, this brings back memories as an apprentice was on the engine build/test area where I would have to build an engine and box ( A series) from scratch testing all torque/clearance/end float etc settings, then it would be taken to the test bed and run flat out for 24/48 hours, upon which I would have to strip it down and retest all parameters and inspect the components.
Advancing age would probably have erased all that knowledge, but it was good fun at the time ! ?
  • Like 6
When I saw the 'leg shot' my initial reaction  was 'FFS he's only gone and dropped the bloody gearbox on his foot'...
That engine block has come up tidy, they look good in that gold paint.
