2 hours ago, lesapandre said:
What an absolute revolution those vans were on introduction. Everyone of a certain age has probably driven or been in one or had something carried in one.
I did not know they started off with 'organ pedals' - interesting fact.
Yes clutch pedal is a rod that pivots on block/bell housing like American stuff, changed with other stuff circa 1970 with first facelift.
£1,000 for a 6k miles Saxo. What the AI generated slop doesn't tell is that it failed the last test and needs tickling with the magic stick:
Spoiler
Date tested
22 September 2025
FAIL
Mileage
6,475 miles
Test location
View test location
Enter the document reference number from your vehicle log book (V5C)
This is an 11 digit number
Show test location
MOT test number
9849 9561 1174
Do not drive until repaired (dangerous defects):
  • Nearside Front Vehicle structure or chassis has excessive corrosion to the extent that overall security or stability of the body is impaired under floor (6.2.2 (d) (ii))
  • Offside Front Vehicle structure or chassis has excessive corrosion to the extent that overall security or stability of the body is impaired under floor (6.2.2 (d) (ii))
  • Supplementary restraint system warning lamp indicates a fault (7.1.6 (a))
  • Nearside Headlamp not working on dipped beam (4.1.1 (a) (ii))
  • Front Registration plate inscription illegible (0.1 (b))
  • Exhaust carbon monoxide content after 2nd fast idle exceeds default limits (8.2.1.2 (b))
  • Exhaust carbon monoxide content at idle exceeds manufacturer's specified limits (8.2.1.2 (b))
  • Service brake efficiency below requirements (1.2.2 (a) (i))
Repair as soon as possible (minor defects):
  • Offside Stop lamp(s) lens defective which has no effect on emitted light (4.3.1 (b) (i))
  • Offside Outer Drive shaft joint constant velocity boot severely deteriorated (6.1.7 (g) (i))
  • Central Exhaust has a minor leak of exhaust gases (6.1.2 (a))
  • Nearside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c))
Bradford.
Citroen Saxo Sx 1.1 6000 Miles Since New
Lord knows what is going on here, but possibly two Jags for £750 or best offer
Jaguar Cars - Picture 1 of 7
Jaguar Cars - Picture 4 of 7
Jaguar Cars | eBay UK
'Jaguar cars
is the only description.
The XK looks a little* fucked mind
Jaguar Cars - Picture 6 of 7
  Reveal hidden contents
Date tested
22 September 2025
FAIL
Mileage
6,475 miles
Test location
View test location
Show test location
MOT test number
9849 9561 1174
Bradford.
What !!! a slightly* dodgy small car in Bradford, I cannot believe it!!
14 minutes ago, angle said:
Galant! Looks like Portuguese paperwork but RHD.
Is that a Rover 200 van behind it?
Never knew those were a thing until now - I've had a very sheltered existence.
Ten minutes in the AS sin bin for you!
https://www.facebook.com/share/1CGcyBDSLu/
Probably from South Africa originally. A lot of South Africans of Portuguese origin moved to the mother country and took their cars with them.
MG Express, ZR based van. Was a thing.
I think I stopped noticing things like that after the Ford Fiesta XR van, so, kind of 1994 or so 🙂Mind you a ZR based one sounds much tastier than the earlier Ford offering👍
