1 hour ago, Rocket88 said:
Yup. butchered by me …. We all make mistakes 😩
At least you didn't convert it to electric power!
Fair play for trying it, wouldn't be for me but it's an interesting project.
  • Agree 2
https://www.autotrader.co.uk/car-details/202509036007308?
"Having been previously cherished by just two owners, this vehicle has been maintained to a high standard, evidenced by its solid mileage of 103,000 miles. It's also reassuring to know that with its manual transmission and front-wheel drive, you'll have full control and a dependable drive."
(PJ07 FEP) ULEZ Compliant, Supplied With 2 Keys, Electric Windows, 13" Alloys.
MOT Failed - Do not drive until repaired (dangerous defects):
- Nearside Rear Axle deformed and unserviceable Axle corroded around spring pan & shocker mounting (5.1.1 (a))
- Nearside Rear Parking brake inoperative on one side (1.4.1 (a))
- Offside Front Service brake excessively binding (1.2.1 (f))
- Nearside Headlamp not working on dipped beam (4.1.1 (a) (ii))
- Nearside Rear Shock absorbers has an excessively worn bush (5.3.2 (c))
- Offside Rear Shock absorbers has a serious fluid leak (5.3.2 (b))
- Nearside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength Outer sill (5.3.6 (a) (i))
Repair as soon as possible (minor defects):
- Offside Registration plate lamp inoperative in the case of multiple lamps or light sources (4.7.1 (b) (i))
- Offside Rear outer sill corroded but not holed
- Front exhaust clamp to centre pipe needs to be repositioned
They pulled the advert shortly after I found it.
More AI drivel
ad gone already
https://www.autotrader.co.uk/car-details/202508035098434?
Please note that this car requires attention to the crankshaft, pulley and belt and requires repairs; it cannot be driven away, which is reflected in the selling price.
It's a lovely car with very few issues. I've owned it for 12 years, so it's a sad sale.
My underline.
8 minutes ago, grogee said:
Come again?
The bench seat had me close.
  • Agree 1
2 minutes ago, doug said:
Went to put a sneaky wee bid (as you do) on this today. On top of your bid the fees are £350. Jeez.
Highest bidder.
I also looked into this, was quite shocked and has put me off putting a bid in
