12 hours ago, DSdriver said:
Is that one of those 'not actually that big a problem' problems? The discs are inboard on the front on the DS but the pads are massive and unlikely to need changing with the sort of mileage a classic car does.
Yeah, that's how I see it. A pain if you do need to do them, but the owners club is sufficiently big and friendly that there will always be someone experienced who is willing to assist with the job.
^ ^ ^ .... would the rear bumper be 'enhanced*', with Raptor.....
I can see why that's cheap - look at that tyre, definitely needs replacing.
There's loads of meat left on it, you're crackers!
I don't want meat on my crackers, is a nice bit of cheddar too much to ask?
7 minutes ago, J W Pepper said:
Why would you even bother, unless you are a moron who has more money than sense
I bet it has a great turning circle!
2 hours ago, wesacosa said:
Mmmm lovely, a shonky Rover 45 with an Autobox fault
That should* be an easy fix m9 😁
Proper auto 'box on those V6s though, not the rubber band setup of the lesser cars.
Ah yes, hadn't considered that (I should have though with the clue being the fact it's stuck in 5th gear 🤦 obviously that wouldn't be the case with a CVT!)
I'm not overly knowledgeable on automatic Rovers as I've never had one, or worked on one's transmission. I only knew that a rover with a malfunctioning CVT is usually bad news!
In that case maybe repairable in the hands of a bog standard autobox specialist, but then again it's a scruffy 45 with 140k miles, possibly needing the belts done too, with a few days MOT ... So only one thing for it probably
6 hours ago, New POD said:
That wants saving @CavcraftThis has your name on it.
It also needs an LET or Red top
It needs to be taken to a dark room with a bottle of Scotch and a revolver.................
1 hour ago, Rocket88 said:
It needs to be taken to a dark wood with a can of petrol and a match.................
FTFY.
