3 hours ago, Peter C said:
slight noise from the flywheel when warm doesn?t effect the drive in anyway.
Probably best to give it a miss. Does look nice though.
Flywheel? What flywheel, it is an automatic.
Je présente les adventures de "Fou Max"...
Quote
"This is the famous toilet bath car", "1975 Renault Toilet Bath Car"
Uh, umm...
1944322589_ScreenShot2020-07-07at8_36_25pm.thumb.png.1c75e868c6d52783a58ebd18a58c4034.png
Ehhh...
Quote
$1000
BLOODY BARGAIN M8, would this interest @MorrisItalSLX at all?
https://www.gumtree.com.au/s-ad/adelaide-cbd/cars-vans-utes/1975-renault-toilet-bath-car/1251567827?utm_source=criteo&utm_medium=retargeting&utm_campaign=retargeting>web_LF>motors_cars_vehicles_cars&utm_content=163436-cars
3 minutes ago, Austat said:
I’m more of a shower guy to be honest.
17 hours ago, SteersWithThrottle said:
Someone (sorry icr who) posted this a few days ago.
The description is indeed a fascinating read, almost as fascinating as the MOT history.
I'd
Snog the Cherry Turbo
Marry the CX
Avoid the XM
Rotten as a pear!
W294WGSCITROEN XM
Check another vehicle
ColourRed
Fuel typeDiesel
Date registered31 March 2000
MOT expired on31 March 2011
Get an MOT reminderwhen the vehicle's MOT is near its time for renewal.(Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong, contact DVSA.
Open All
MOT history
Check mileage recorded at test, MOT expiry date, defects and advisories, and view test certificate
Date tested29 October 2019
FAIL
 View test certificate
Mileage163,822 miles
MOT test number1967 3327 5542
Test location
 View test location
Do not drive until repaired (dangerous defects):
  • Parking brake efficiency less than 50% of the required value (1.4.2 (a) (ii))
  • Nearside Rear Service brake has no recorded effort at a wheel (1.2.1 (a) (ii))
  • Offside Rear Service brake has no recorded effort at a wheel (1.2.1 (a) (ii))
  • Offside Front Seat belt webbing significantly weakened (7.1.2 (b) (ii))
  • Nearside Front Electrical wiring connectors for braking disconnected (4.11 (a) (iii))
  • Offside Front Electrical wiring connectors for braking disconnected (4.11 (a) (iii))
  • Nearside Front Tyre tread depth below requirements of 1.6mm (5.2.3 (e))
  • Offside Rear Tyre tread depth below requirements of 1.6mm (5.2.3 (e))
  • Service brake efficiency below requirements (1.2.2 (a) (i))
  • Nearside Parking brake inoperative on one side (1.4.1 (a))
  • Offside Parking brake inoperative on one side (1.4.1 (a))
  • Front Brakes imbalanced across an axle (1.2.1 (b) (i))
  • Nearside Front Brake disc contaminated (1.1.14 (b))
  • Nearside Front Brake pad(s) contaminated (1.1.13 (b))
  • Nearside Outer Seat belt anchorage prescribed area strength or continuity significantly reduced body sill (7.1.1 (a) (i))
  • Nearside Outer Seat belt anchorage prescribed area is inadequately repaired body sill (7.1.1 (a) (i))
  • Nearside Seat belt anchorage prescribed area is inadequately repaired floor to sill (7.1.1 (a) (i))
  • Nearside Seat belt anchorage prescribed area strength or continuity significantly reduced floor to sill (7.1.1 (a) (i))
  • Offside Outer Seat belt anchorage prescribed area strength or continuity significantly reduced body sill (7.1.1 (a) (i))
  • Offside Seat belt anchorage prescribed area strength or continuity significantly reduced floor to sill (7.1.1 (a) (i))
  • Offside Outer Seat belt anchorage prescribed area is inadequately repaired body sill (7.1.1 (a) (i))
  • Offside Seat belt anchorage prescribed area is inadequately repaired floor to sill (7.1.1 (a) (i))
  • Exhaust has a major leak of exhaust gases (6.1.2 (a))
  • Emissions not tested due to exhaust blow (8.2.2.2 (e))
  • Nearside Front Hydraulic fluid leaking excessively (8.4.1 (a) (i))
  • Nearside Front Direction indicator incorrect colour (4.4.3 (a))
  • Offside Front Direction indicator incorrect colour (4.4.3 (a))
  • Nearside Side repeater incorrect colour (4.4.3 (a))
  • Offside Side repeater incorrect colour (4.4.3 (a))
  • Offside Front Suspension pipe leaking (5.3.5 (c))
  • Front Sub-frame corroded and seriously weakened (5.3.3 (b) (i))
  • Nearside Outer Suspension component mounting prescribed area is inadequately repaired body sill (5.3.6 (a) (i))
  • Offside Outer Suspension component mounting prescribed area is inadequately repaired body sill (5.3.6 (a) (i))
  • Nearside Suspension component mounting prescribed area is inadequately repaired floor to sill (5.3.6 (a) (i))
  • Offside Suspension component mounting prescribed area is inadequately repaired floor to sill (5.3.6 (a) (i))
  • Nearside Outer Suspension component mounting prescribed area excessively corroded significantly reducing structural strength body sill (5.3.6 (a) (i))
  • Offside Outer Suspension component mounting prescribed area excessively corroded significantly reducing structural strength body sill (5.3.6 (a) (i))
  • Nearside Suspension component mounting prescribed area excessively corroded significantly reducing structural strength floor to sill (5.3.6 (a) (i))
  • Offside Suspension component mounting prescribed area excessively corroded significantly reducing structural strength floor to sill (5.3.6 (a) (i))
  • Offside Front Lower Suspension arm pin or bush excessively worn (5.3.4 (a) (i))
Repair as soon as possible (minor defects):
  • Offside Front Position lamp insecure (4.2.1 (c) (i))
  • dipstick missing
  • underside of vehicle in general poor condition
  • Nearside Rear Tyre worn close to legal limit/worn on edge (5.2.3 (e))
  • Offside Front Tyre worn close to legal limit/worn on edge (5.2.3 (e))
 What are defects and advisories?
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity – dangerous, major, and minor. Find out more
Date tested11 March 2010
PASS
Mileage103,416 miles
MOT test number4728 5037 0062
Test location
 View test location
Expiry date31 March 2011
Date tested4 March 2009
PASS
Mileage94,182 miles
MOT test number8016 5316 9014
Test location
 View test location
Expiry date31 March 2010
Advisory notice item(s)
  • Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
  • front tyre inner edges wearing slightly
 What are advisories?
Date tested18 March 2008
PASS
Mileage83,889 miles
MOT test number6802 6897 8037
Test location
 View test location
Expiry date31 March 2009
Date tested28 March 2007
PASS
Mileage73,891 miles
MOT test number8643 3738 7023
Test location
 View test location
Expiry date31 March 2008
Date tested27 March 2006
PASS
Mileage62,700 miles
MOT test number1942 3658 6468
Test location
 View test location
Expiry date31 March 2007
Outstanding vehicle recalls
Check if CITROEN XM W294WGS has outstanding recalls
Support links
Open Government Licence
All content is available under the Open Government Licence v3.0, except where otherwise stated
52 minutes ago, MarvinsMom said:
£2000 for rust held together with paint.........
i know minis are idiot amounts of money, but surely that is taking the piss??
It’s made me realise how wildly out of touch I am with mini values.
and to think that that crock of shit was roadworthy as recently as 2014. Presumably it’s spent the last 6 years stored at the bottom of the ocean
Late Minis can quite easily get into that state in 6 years whilst stored in a hermetically sealed cocoon.
Yeah, it’s something I unfortunately know first hand. The rustproofing (or rather lack thereof) on late 90s Minis was a disgrace
What is cooler than tooling around in a shonky Shadow?
A yellow one with blue interior! This Shadow is sub zero
https://www.ebay.co.uk/itm/Rolls-Royce/164280081951?hash=item263fdb1e1f:g:T7IAAOSwFB9fBGuP
The pictures are not great so you may need to use your imagination as to how good* it might be.spacer.png
New  number plates first job, then wheels, then maybe look at addressing rust issues.
I have never been a huge fan of Rolls Royce but this colour really does suit it ?
spacer.pngspacer.pngspacer.pngspacer.pngspacer.pngspacer.pngspacer.pngimage.jpeg.41c1cc831fc83aa25164692d9bd7375a.jpeg
