That X Type is a flippin outrage, and the owner a weapons-grade spazzer
I did start off to give it only the ratted look, and thought I'd take it to car shows but then I realised how fast it actually was so I thought I would also use it as a track day car which is the reason I started to strip it out.
http://www.autotrader.co.uk/classified/advert/201609167827084?search-target=usedcars&make=vauxhall&model=omega&sort=pricedesc&searchcontext=default&page=1&radius=1500&postcode=l378bt&onesearchad=new%2Cnearlynew%2Cused&logcode=p&adPos=10
You can tell it's a GOOD One
Check the MOT history of a vehicle
Registration number:  W126KKU
•Vehicle make VAUXHALL
•Vehicle model OMEGA
•Date first used 21 July 2000
•Fuel type Petrol
•Colour Black
MOT history of this vehicle
•Test date 16 September 2016
•Expiry date 15 September 2017
•Test Result Pass
•Odometer reading 61,224 miles
•MOT test number 9530 1929 3221
•Advisory notice item(s)
surface rust under vehicle
•Test date 4 September 2015
•Expiry date 9 September 2016
•Test Result Pass
•Odometer reading 59,802 miles
•MOT test number 1192 9704 5231
Heavy surface corrosion on the o/side front chassis outrigger.
•Test date 23 August 2014
•Expiry date 9 September 2015
•Test Result Pass
•Odometer reading 56,028 miles
•MOT test number 6992 1583 4287
•Test date 17 August 2013
•Expiry date 9 September 2014
•Test Result Pass
•Odometer reading 53,303 miles
•MOT test number 9352 2922 3216
Heavy surface corrosion n/side front subframe mounting.
•Test date 1 September 2012
•Expiry date 9 September 2013
•Test Result Pass
•Odometer reading 52,059 miles
•MOT test number 2285 3554 2284
•Test date 28 August 2012
•Test Result Fail
•MOT test number 6355 1134 2288
•Reason(s) for failure
Nearside Rear coil spring fractured (2.4.C.1a)
Offside Rear coil spring fractured (2.4.C.1a)
Nearside Rear Coil spring not correctly located (2.4.C.2)
Offside Front Tyre has ply or cords exposed (4.1.D.1b)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
•Test date 26 August 2011
•Expiry date 9 September 2012
•Test Result Pass
•Odometer reading 49,672 miles
•MOT test number 2461 6863 1230
Both front tyres worn on inner and outer treads
•Test date 10 September 2010
•Expiry date 9 September 2011
•Test Result Pass
•Odometer reading 46,897 miles
•MOT test number 7604 8365 0274
•Test date 9 September 2009
•Expiry date 8 September 2010
•Test Result Pass
•Odometer reading 45,735 miles
•MOT test number 6924 2215 9286
Both front tyres have wear on the inner and outer treads
•Test date 9 September 2008
•Expiry date 8 September 2009
•Test Result Pass
•Odometer reading 44,446 miles
•MOT test number 3033 4315 8217
•Test date 31 August 2007
•Expiry date 31 August 2008
•Test Result Pass
•Odometer reading 42,467 miles
•MOT test number 4547 9314 7219
Rear Exhaust has part of the system slightly deteriorated (7.1.1a)
Both front tyres have wear on inner treads.
•Test date 1 September 2006
•Expiry date 31 August 2007
•Test Result Pass
•Odometer reading 39,960 miles
•MOT test number 6109 7474 6217
•Test date 31 August 2006
•Test Result Fail
•MOT test number 7920 9344 6240
Offside front brake juddering severely (3.7.A.2b)
Nearside Rear Direction indicator slightly discoloured (1.4.A.2f)
Offside Rear Direction indicator slightly discoloured (1.4.A.2f)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Nearside front brake juddering slightly (3.7.A.2b)
I have to think that 61K miles were hard miles
That Omega is a strange one.
Facelift model, but with the pre-facelift 2.5, instead of the 2.6.
Holy shit, that Rover 420! I've never seen a saloon with the bump in the bonnet. It really does look the tits!
I've owned this eccentric 205 for nearly ten years
It has a Peugeot 405 1.8TD engine conversion and is based on a 205 Cti.
I'm listening...
Originally a bluey green..I painted it NATO green all those years ago, and it has preserved the bodywork if nothing else!
http://www.ebay.co.uk/itm/322262919938?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
anigif_enhanced-buzz-22353-1382473164-16
  • Like 6
The loader arms on that little grey Fergie are something special, they are a bit HR Giger / Alien. Anyone know amything about the loader? is it Ferguson or third party?
Awful design from Ferguson themselves I think. I've used one, you can only 'mount' the tractor from the rear when fitted, but the worst part is that the bucket is tilted by its own hydraulic ram. Oil has to be diverted from the lift rams every time you wish to shoot your load which involves manipulating a knob located between your legs.
Fall guy truck is heavier duty suspension/payload than that one, those funeral cars will be based on BA falcon or possibly late AU3 versions .
This is why there are no Suzuki 410s anymore.
NUMPTY!
Turn your Suzuki rust bucket into a 4WD roadster!
DIY Body conversion for SJ410/413 and Samurai.
 The JC Midge 'Roadster' Hand built special
 The acceleration and performance of the car is exceptional! The low gearing gives great acceleration and the reduction in body weight allows 70mph in 4th gear with 5th still to go!
The system allows you to construct the replacement body for this car yourself from plywood and aluminium using full size paper patterns to cut out each panel.
 THIS LISTING IS A CLASSIFIED AD YOU CANNOT BUY FROM THIS LISTING BUT .........
 YOU CAN BUY THESE PLANS FOR £99 (Plus p&p) ON A 'BUY IT NOW LISTING' (See sellers other items)
http://www.ebay.co.uk/itm/112139233283?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
