https://www.gumtree.com/p/other-cars/austin-montego-1.3-a-5-speed-garrage-find-stored-19-years-/1162316890
its beige, its the base model, and it was built by BL, what is not to like?
well i would like to own it, there cannot be many 1300 base Monty's left in the world.
i wonder how bad the body is cos it don't look bad at all in the (hopeless) pictures.
Wow! Super long gear stick and open rubber head rests all present and correct.
those pembertons where everywhere when I was a kid in the 70's, proper static caravan
Is that some sort of deal lash up "special edition"?
We lived in one for a year while our house was being done up, at the end we set it on fire 🔥
If that was mine the fire extinguisher would be nailed to the outside.....
Really? I'd just let the monstrosity burn.
Daewoo Matiz, 12K... £550.  :shock:
It could use a door.
Linky
Doors on those are really easy to replace. I've replaced the driver's side rear on one of them before.
Not even for £550 though. Hateful little cars.
That weird Renault snail camper has been on before, I was tempted last time, I know it's the same one as I'm sad enough that the MOT history check suggested the reg number when I went to fill it in. It looks like it's been welded up a bit. I'm sure it was a lot cheaper before as I'm too tight to pay anywhere near £3k for it.
That Renault Extra camper with the super fat arse looks brilliant. I can just imagine me and the good lady wife settling down in bed at the back and the front end lifts up, showering us with pots and pans in a hilarious fashion.
2-litre Bluebird saloon with some serious giffer bodging but a year's test nonetheless.  Seems reasonable value at 500 quid.
The interior is worth the start bid on its own. 8)
Cheap 2CV ending imminently.  Would if I had somewhere to put it - even I can do an engine swap on one of these.
Went for £433 in the end. Surely that's a good price for a 2CV these days even without an MOT?
There's something off about this...? The front end and rear end look different to any of these I've seen before.
http://www.carandclassic.co.uk/car/C738445
JDM 323, I'd always thought but this one makes me doubt that - I saw one at the auctions in Leeds just after the Citroen C4 came out, and often wondered if that's where PSA got the idea for the 3-door's rear styling - they've got the vertical window below the edge of the tailgate.
Those 3-door 323s were officially sold over here.  I think they managed to shift about 8 of them.
Diesel Fellatio.  It's a bit rough and the seller doesn't appear to have much of a command of English, but for a hundred quid start with test until December you can't go too far wrong.
http://www.autotrader.co.uk/classified/advert/201604203175549?radius=1500&page=29&searchcontext=default&postcode=IP1%201AA&sort=default&search-target=usedcars&onesearchad=used%2Cnearlynew%2Cnew&logcode=p
Dig that shitty stick out as you'll be needing it to beat those hunnyz away!.
I'm loving that hand written Proton badge!. In all seriousness why would you even bother to waste £30 advertising this on Autotrader?, it hasn't even got a MOT. Just fragg the fecker.
I think we've found where all the white dog turds went, they're making up the front wing of that Proton.
