Floatylight Posted January 13, 2021 Posted January 13, 2021 9 minutes ago, loserone said: No contest I'm with him!
chaseracer Posted January 13, 2021 Posted January 13, 2021 Yeah, I like the Beetle too... <runs away...> loserone and richardmorris 2
wuvvum Posted January 13, 2021 Posted January 13, 2021 30 minutes ago, chaseracer said: Yeah, I like the Beetle too... <runs away...> Yeah, but you drive a washing machine, so your opinion doesn't count. 😝 Six-cylinder, brownnova, LightBulbFun and 3 others 6
chaseracer Posted January 13, 2021 Posted January 13, 2021 37 minutes ago, wuvvum said: Yeah, but you drive a washing machine, so your opinion doesn't count. 😝 That's a hot point... (Sorry.) Talbot and wuvvum 1 1
richardmorris Posted January 13, 2021 Posted January 13, 2021 Did pininfarina ever manage an inelegant design? The beetle is just an ugly pastiche of what wasn’t pretty to start with. Six-cylinder 1
chaseracer Posted January 13, 2021 Posted January 13, 2021 The BMC Oxbridge wasn't his best work. Though he did better with the Peugeot 404, which was basically the same design with French dressing... Six-cylinder and egg 2
Zelandeth Posted January 14, 2021 Posted January 14, 2021 Dash lighting on a 306 should be warm white. Six-cylinder 1
Six-cylinder Posted January 14, 2021 Author Posted January 14, 2021 Black beauty is back! Fresh MOT after new front shocker, CV boots, MAF and bulb failure warning sorted. Now we have 7 fully working MOTed, taxed and insured cars on our drive, the question is how we are going to share out the 20 miles per week we are currently driving! LightBulbFun, Craig the Princess, BeEP and 5 others 8
Mrs6C Posted January 14, 2021 Posted January 14, 2021 2 hours ago, Six-cylinder said: bulb failure warning sorted. Umm, no... it's still there, unless there really is a light out somewhere?
Six-cylinder Posted January 14, 2021 Author Posted January 14, 2021 3 minutes ago, Mrs6C said: Umm, no... it's still there, unless there really is a light out somewhere? Does it drive the same as the silver one now with the new MAF instead of feeling like it is holding back sometimes?
Six-cylinder Posted January 17, 2021 Author Posted January 17, 2021 The XM had sat for two weeks and when Mrs6C went to use it it had a dead battery. I have had concerns the battery was at the end of its life so instead of just charging it I decided to put a new battery on the car and then I will know if it goes flat again we have a discharge or charging problem. I will recharge the battery from the car now and then I have a load discharge tester to see how it is. The problem is the + battery clamp has broken and there are four wires to the terminal. I can not see any terminals on eBay that look a good fit.
Noel Tidybeard Posted January 17, 2021 Posted January 17, 2021 this might work- just cut the ring off yours https://www.ebay.co.uk/itm/12V-Car-Battery-Terminals-Negative-Clamp-Connectors-Heavy-Duty-Brass-Bolts/273431321969?epid=14010706847&hash=item3fa9c6dd71:g:7A0AAOSwAbBe6fmu
Six-cylinder Posted January 17, 2021 Author Posted January 17, 2021 16 minutes ago, Noel Tidybeard said: this might work- just cut the ring off yours https://www.ebay.co.uk/itm/12V-Car-Battery-Terminals-Negative-Clamp-Connectors-Heavy-Duty-Brass-Bolts/273431321969?epid=14010706847&hash=item3fa9c6dd71:g:7A0AAOSwAbBe6fmu I have ordered the + version of that and will give it a go.
Noel Tidybeard Posted January 17, 2021 Posted January 17, 2021 1 minute ago, Six-cylinder said: I have ordered the + version of that and will give it a go. happy days 👍
Six-cylinder Posted January 17, 2021 Author Posted January 17, 2021 Wanted trailer ramps, has anybody got anything to sell? Thinking ahead with some optimism that we will be able to play with the cars in the spring I would like to get some proper ramps for Mrs6C's Timmy car trailer. I am thinking they need to about 6 ft (2m) long. I do have a new hand winch ready to fit. Craig the Princess, LightBulbFun and Dan_ZTT 3
Talbot Posted January 17, 2021 Posted January 17, 2021 Assuming you want to keep said trailer, and want something that works, it may be much easier/better to make some ramps specifically for it, then have them galvanised. Probably cost a bit more than some existing ones, but at least they will work properly with the trailer, and will last forever.
Six-cylinder Posted January 17, 2021 Author Posted January 17, 2021 3 minutes ago, Talbot said: Assuming you want to keep said trailer, and want something that works, it may be much easier/better to make some ramps specifically for it, then have them galvanised. Probably cost a bit more than some existing ones, but at least they will work properly with the trailer, and will last forever. I have been looking some more and found these for sale at £120. What do you think?
Talbot Posted January 17, 2021 Posted January 17, 2021 Will they clip on to the trailer is the biggest question. Also, is there somewhere on the trailer that they will store? Other than that, they look good.
Six-cylinder Posted January 17, 2021 Author Posted January 17, 2021 32 minutes ago, Talbot said: Will they clip on to the trailer is the biggest question. Also, is there somewhere on the trailer that they will store? Other than that, they look good. Looking at the picture there is a chance for them to clip on. Mrs6C wants it altered for an Invacar to use it so a ramp store can be included in that. I was really looking for a cheaper solution, but using present car ramps and bits of wood is going to end up with an accident.
LightBulbFun Posted January 17, 2021 Posted January 17, 2021 1 hour ago, Six-cylinder said: Mrs6C wants it altered for an Invacar to use it so a ramp store can be included in that. glad im not the only one who was thinking that LOL on that front, I wonder if it would be worth finding the same model of trailer or similar that is in scrap condition and pillaging one of the, uhhh whatever you call the bits the wheels of whatever vehicle your transporting sit on (I know on a normal trailer thats called the load bed, but not sure if its still called that on car trailers where its split in 2 one for each side of the car) and sticking it in the middle of the good trailer therefor giving a 3rd "rail" (hopefully not electrified in this case!) making it suitable for 3 wheelers
Six-cylinder Posted January 17, 2021 Author Posted January 17, 2021 3 minutes ago, LightBulbFun said: glad im not the only one who was thinking that LOL on that front, I wonder if it would be worth finding the same model of trailer or similar that is in scrap condition and pillaging one of the, uhhh whatever you call the bits the wheels of whatever vehicle your transporting sit on (I know on a normal trailer thats called the load bed, but not sure if its still called that on car trailers where its split in 2 one for each side of the car) and sticking it in the middle of the good trailer therefor giving a 3rd "rail" (hopefully not electrified!) making it suitable for 3 wheelers I have been thinking about a mesh deck for lightness. With a filled in light deck it will also be useful for carrying other things without adding too much weight. LightBulbFun 1
wuvvum Posted January 17, 2021 Posted January 17, 2021 Yeah, I suppose it doesn't have to be particularly strong to support the front wheel of an Invacar...
Noel Tidybeard Posted January 17, 2021 Posted January 17, 2021 2 hours ago, Six-cylinder said: I have been looking some more and found these for sale at £120. What do you think? there aren't enuff there for all your i@*acar needs!
Noel Tidybeard Posted January 17, 2021 Posted January 17, 2021 2 hours ago, Six-cylinder said: looking at that pic there seems to be storage for the ramps already there
Talbot Posted January 17, 2021 Posted January 17, 2021 1 hour ago, LightBulbFun said: the same model of trailer or similar Looking at the pictures, that looks very much like a home-brew trailer to me. Certainly it's made from standard sections of steel, so rather than needing to find one, it's just as easy (if not much easier) just to fabricate something up. Given the popularity* of invacars at the moment, I did wonder about making a trailer for them. It would be very easy to do. Could be single axle, and (depending on the kerb weight of an invacar, which I don't know) might even be able to be unbraked. It wouldn't be a lot more than a motorcycle trailer, and they're dead simple to make.
Six-cylinder Posted January 17, 2021 Author Posted January 17, 2021 20 minutes ago, Talbot said: Looking at the pictures, that looks very much like a home-brew trailer to me. Certainly it's made from standard sections of steel, so rather than needing to find one, it's just as easy (if not much easier) just to fabricate something up. Given the popularity* of invacars at the moment, I did wonder about making a trailer for them. It would be very easy to do. Could be single axle, and (depending on the kerb weight of an invacar, which I don't know) might even be able to be unbraked. It wouldn't be a lot more than a motorcycle trailer, and they're dead simple to make. I think Mrs6C said it was made for an MGB. There is a steel mesh that looks like it is stretched strips and forms diamonds that I am sure will support its share of the 410 kg Invacar.
Talbot Posted January 17, 2021 Posted January 17, 2021 51 minutes ago, Six-cylinder said: 410 kg Invacar. Blimey is that it? I may have to look at a design for a 300-ish KG three-wheeler trailer. Could be very simple indeed: Only needs one full-length runner (for the front wheel) and then two short stubs for the rear wheels. It needn't have brakes, could be towed by most people even with a post-97 licence, and could easily be designed for quick/easy loading and unloading. Hmmmmmmmmmm...
