Six-cylinder Posted December 26, 2018 Author Posted December 26, 2018 Having said to HMC it was my turn to test the reliability of a TD6 Range Rover things did not go well. To start with it needed a jump start. Fridge safely delivered to Wales Then on the way home the dreaded warning message came up. It still runs and is not sat down but its next run in the new year will to be a garage. HMC and Mrs6C 2
Mrs6C Posted December 26, 2018 Posted December 26, 2018 ^^^ Air suspension inactive - TADTS when the battery has been lacking sufficient volts... reset it by (when stationary and on suitable surface) turning the steering wheel full lock to the left and holding for a few seconds, then turning it to the right on full lock and holding for a few seconds, then go back to centre, switch off and back on again. Skizzer, The Reverend Bluejeans, Pillock and 1 other 4
Six-cylinder Posted December 26, 2018 Author Posted December 26, 2018 ^^^ Air suspension inactive - TADTS when the battery has been lacking sufficient volts... reset it by (when stationary and on suitable surface) turning the steering wheel full lock to the left and holding for a few seconds, then turning it to the right on full lock and holding for a few seconds, then go back to centre, switch off and back on again. I will give it a go tomorrow.Last time it was a position arm that had broken and was not sending messages to the brain so I got that message Mr cat fedCork in champaign Mrs6C 1
Mrs6C Posted December 26, 2018 Posted December 26, 2018 Should have added that wheels should be in straight ahead position before you switch on and start the above reset procedure... I remember that position arm. Wasn't it about the size of a small kebab skewer and composed mostly of rust?
Six-cylinder Posted December 26, 2018 Author Posted December 26, 2018 Should have added that wheels should be in straight ahead position before you switch on and start the above reset procedure... I remember that position arm. Wasn't it about the size of a small kebab skewer and composed mostly of rust? The arm was rusty, but it was the plastic part of it that had broken. Mrs6C 1
beko1987 Posted December 27, 2018 Posted December 27, 2018 Sounds like the xeon levelling arm on my first laguna. I cable tied it on in the end and it just popped a ball joint off somewhere else so I left it in the end!
Guest Hooli Posted December 27, 2018 Posted December 27, 2018 Having said to HMC it was my turn to test the reliability of a TD6 Range Rover things did not go well. IMG_20181225_103914 broad.jpgTo start with it needed a jump start. IMG_20181225_105727 broad.jpgFridge safely delivered to Wales IMG_20181226_162359 broad.jpgThen on the way home the dreaded warning message came up. It still runs and is not sat down but its next run in the new year will to be a garage. What a horrible green for the dash.
Six-cylinder Posted December 27, 2018 Author Posted December 27, 2018 ^^^ Air suspension inactive - TADTS when the battery has been lacking sufficient volts... reset it by (when stationary and on suitable surface) turning the steering wheel full lock to the left and holding for a few seconds, then turning it to the right on full lock and holding for a few seconds, then go back to centre, switch off and back on again. I have done the procedure and no change so it has been sent to the naughty corner. Add - 2 broken 5 working and in the garage 1 broken 1 working. Mrs6C, Cavcraft, chaseracer and 1 other 4
Mrs6C Posted December 27, 2018 Posted December 27, 2018 Yesterday I found myself drafting a PM to own the Allegro VP and had to have strong words with myself. Mrs6C is not helping by chipping in that she had found a place who will recon the gearbox for £400!Think you need to finish that draft... Six-cylinder, LightBulbFun and mat_the_cat 3
Andyrew Posted December 27, 2018 Posted December 27, 2018 Better do as you are told mr6c LightBulbFun and Mrs6C 2
hairnet Posted December 27, 2018 Posted December 27, 2018 When can we expect you?LIKE MORE THAN ONCE rich - introduce him to your maser
hairnet Posted December 27, 2018 Posted December 27, 2018 I have done the procedure and no change so it has been sent to the naughty corner. Add - 2 broken 5 working and in the garage 1 broken 1 working.its spelt land cruiser and fix the caddy or how much cheap cheap please
Six-cylinder Posted December 27, 2018 Author Posted December 27, 2018 Think you need to finish that draft... Do you know how many broken cars we already have! 1971 BMW 3.0 S, 1966 Jaguar E Type, 1968 Triumph Spitfire MKIII 2.5, 1961 Triumph Herald 1200 Coupe, 1963 Triumph Herald 12/50, 1994 Cadillac Eldorado Coupe, 1983 Citroen LNA Inca, 1990 Mercedes 200TE, 1978 Lancia Gamma, 1999 Volvo V70 T5, 1989 Citroen 2CV, 1999 Citroen Xantia V6 Exclusive, 2000 BMW 330Ci, 1990 Volvo 740GLE A, 1990 Citroen Oltcit, 1985 Range Rover 3.5 Auto, 1992 Citroen BX Gti, 1983 Citroen CX 2400 I/E Pallas, 1964 Bond GT4S, 1964 Bond GT4S, 1968 Triumph Herald 13/60 convertible, 1966 Triumph Spitfire, 1961 Triumph Herald 1200, 1968 Triumph Herald 13/60 convertible, 1983 Alfa Giulietta 2.0, 1966 Jaguar MK10, 1965 Triumph Spitfire MKII, 1983 Citroen Visa GT. DeeJay, wuvvum, Mrs6C and 4 others 7
beko1987 Posted December 27, 2018 Posted December 27, 2018 That's an odd number though, an even one would be much better! MorrisItalSLX, Mrs6C, Cavcraft and 1 other 4
Justin Case Posted December 27, 2018 Posted December 27, 2018 I must say that I am impressed with the way in which the 6Cs appear to only communicate with each other by means of AS posts; a recipe for the perfect marriage, I am sure Angrydicky, Skizzer, The Moog and 10 others 13
Tadhg Tiogar Posted December 27, 2018 Posted December 27, 2018 I must say that I am impressed with the way in which the 6Cs appear to only communicate with each other by means of AS posts; .......mostly sent from different parts of the house? richardmorris and Mrs6C 2
Six-cylinder Posted December 27, 2018 Author Posted December 27, 2018 I must say that I am impressed with the way in which the 6Cs appear to only communicate with each other by means of AS posts; a recipe for the perfect marriage, I am sure I can't shout 200 miles! no phone signal where she is and I am not even looking at my emails! Justin Case, Mrs6C and richardmorris 3
Mrs6C Posted December 27, 2018 Posted December 27, 2018 Do you know how many broken cars we already have! 1971 BMW 3.0 S, 1966 Jaguar E Type, 1968 Triumph Spitfire MKIII 2.5, 1961 Triumph Herald 1200 Coupe, 1963 Triumph Herald 12/50, 1994 Cadillac Eldorado Coupe, 1983 Citroen LNA Inca, 1990 Mercedes 200TE, 1978 Lancia Gamma, 1999 Volvo V70 T5, 1989 Citroen 2CV, 1999 Citroen Xantia V6 Exclusive, 2000 BMW 330Ci, 1990 Volvo 740GLE A, 1990 Citroen Oltcit, 1985 Range Rover 3.5 Auto, 1992 Citroen BX Gti, 1983 Citroen CX 2400 I/E Pallas, 1964 Bond GT4S, 1964 Bond GT4S, 1968 Triumph Herald 13/60 convertible, 1966 Triumph Spitfire, 1961 Triumph Herald 1200, 1968 Triumph Herald 13/60 convertible, 1983 Alfa Giulietta 2.0, 1966 Jaguar MK10, 1965 Triumph Spitfire MKII, 1983 Citroen Visa GT.I think the phrase is 'not on the road at present'... as some just don't have MOT and/or tax currently... which is fine... richardmorris 1
Six-cylinder Posted December 27, 2018 Author Posted December 27, 2018 So I can now add the stray cat has been fed. Mrs6C and chaseracer 2
richardmorris Posted December 27, 2018 Posted December 27, 2018 This thread is rapidly turning into an episode of terry and June!, Cavcraft, r.welfare and blakey79 3
Six-cylinder Posted December 27, 2018 Author Posted December 27, 2018 This thread is rapidly turning into an episode of terry and June!, Yes I would like a Princess! beko1987 and richardmorris 2
Eyersey1234 Posted December 27, 2018 Posted December 27, 2018 So I can now add the stray cat has been fed. Have you taken one of the Jaguars to the petrol station? Mrs6C, Eyersey1234, Tadhg Tiogar and 2 others 5
Six-cylinder Posted December 27, 2018 Author Posted December 27, 2018 I think the phrase is 'not on the road at present'... as some just don't have MOT and/or tax currently... which is fine... I did not add the ones that I do not expect to need expensive things to get them an MOT.
Tadhg Tiogar Posted December 27, 2018 Posted December 27, 2018 Have you taken one of the Jaguars to the petrol station?There'll be a Panther in the collection next. Eyersey1234 and Six-cylinder 2
Six-cylinder Posted December 28, 2018 Author Posted December 28, 2018 There'll be a Panther in the collection next. Funnily enough I would like a Panther Rio, I know, I know an uglier, slower, more expensive Dolomite sprint! jumpingjehovahs 1
Noel Tidybeard Posted December 28, 2018 Posted December 28, 2018 Do you know how many broken cars we already have! 1971 BMW 3.0 S, 1966 Jaguar E Type, 1968 Triumph Spitfire MKIII 2.5, 1961 Triumph Herald 1200 Coupe, 1963 Triumph Herald 12/50, 1994 Cadillac Eldorado Coupe, 1983 Citroen LNA Inca, 1990 Mercedes 200TE, 1978 Lancia Gamma, 1999 Volvo V70 T5, 1989 Citroen 2CV, 1999 Citroen Xantia V6 Exclusive, 2000 BMW 330Ci, 1990 Volvo 740GLE A, 1990 Citroen Oltcit, 1985 Range Rover 3.5 Auto, 1992 Citroen BX Gti, 1983 Citroen CX 2400 I/E Pallas, 1964 Bond GT4S, 1964 Bond GT4S, 1968 Triumph Herald 13/60 convertible, 1966 Triumph Spitfire, 1961 Triumph Herald 1200, 1968 Triumph Herald 13/60 convertible, 1983 Alfa Giulietta 2.0, 1966 Jaguar MK10, 1965 Triumph Spitfire MKII, 1983 Citroen Visa GT. yes but that list needs added PLAH Mrs6C 1
SiC Posted December 29, 2018 Posted December 29, 2018 You would never run out of cars to fix for sure! Yesterday I found myself drafting a PM to own the Allegro VP and had to have strong words with myself. Mrs6C is not helping by chipping in that she had found a place who will recon the gearbox for £400! If you do happen to buy it and then later get buyers remorse, I'll happily buy it back off you in a few more months. My intention was to fix it up and then give it to my Father-in-Law as a present (he loves them). However with the 1100 on the drive, there is no way I can buy it as I won't have anywhere to store it. I'm resisting getting additional storage, otherwise I would end up with having far too many cars... Which this thread is a great example of what would happen to me if I had a spare field (I know this post won't be helping those matters either ) Mrs6C 1
Mrs6C Posted December 29, 2018 Posted December 29, 2018 ^^^ The FoD has always been useful for those moments when something turns up that is worth having but we don't quite know what to do with it yet... Justin Case, chaseracer and The Moog 3
Six-cylinder Posted December 29, 2018 Author Posted December 29, 2018 Tow car broken now, then it needs an MOT so won't be available for weeks.
