VW T4 Caravelle L8 PL8 M8
Quite jealous of the auto box as changing gear in this one is a case of imagining where it might be and throwing the stick in that rough direction with as much wrist strength as you can muster.
Heh, sounds about right, at least you'll get a workout, you can save money on the gym 🤣
The auto in this one supposedly learns how you drive and adapts but in practice it just gets lazy and you have to use VCDS to reset it again. Does yours have the blue clocks?
Yes it does - feels very weird being in a T4 with indigo backlighting when all the rest of the switchgear is early 90s VAG.
Quick update on the bus. Not discovered any horrors yet… reapplied the rubber door seals with new tape and plastic pegs as the one above the sliding door kept sagging.
I did consider replacing the head unit with an original VW Gamma one, but this Blaupunkt one is such a good fake (right down to the red backlighting) and has proper modern Bluetooth and aux support. It works brilliantly:
  • urpert changed the title to VW T4 Caravelle L8 PL8 M8
Those Blaupunkt HUs are great for 80s, 90s and 00s stuff as they look almost OEM in any car you fit them to. I’ve got one in my MG for exactly the same reason.
Think that's bad? You should try a T2 with a three foot lever connected to 14 feet of linkage and a gearbox just this side of the noisy cupboard.
I like to think of it as an anti theft measure as no one else will be able to find the gears!
I have previous form:
Somehow got 37.5mpg out of the first half a tank.
Today, a 3 point seatbelt to be fitted to one of the middle seats.
Haha! My old '61 LHD Split required you to lift your right leg, then repeatedly smash the gearknob into your plums to obtain reverse gear.
This particular (cracked) trim panel is causing lots of grief with the sliding door. Trying to work out what it’s called. image.jpg.257aeef628d3e103e96a78f53d2b58a4.jpg
I bet it didn't, you just liked to do it for fun !!
ohh.. do they have a bad design in the gearstick that i seen lot of angled knob adjusters?
On 05/04/2025 at 11:21, reb said:
According to Wikipedia it was Bradford before '74 and Sheffield after
But this is a post-2001 plate so in this case it's Northampton.
yes. That's what I said to begin with. This was specifically concerning pre 2001 plates.
It's too short, the angled things are more of an extender than an adjuster.
Stops you hitting the legs of the passenger as bad if you are running 3 seats across the front and it does help raise it a little.
Looks nice this @urpert
I just got another T4 recently and will be looking at one of those head units as they look really smart.
Have a piccie of ours, just a converted van but it’s ace just the same.
They look like a horses cock, but still aren't quite long enough.  Mine gave me back ache for about the first month until I built up the requisite lower back muscles, after which it was never a problem.
You can buy a cock extender if it continues to be an issue.
i accidently bought one for my galaxy after 7 years of ownership.... though wasnt compatable..
Here is mine. Currently sorned while I plooter about with the C15. Also just a van.
On 18/04/2025 at 07:58, Nibbler said:
Nice purchase! Is it a 1,9 or a 2,5 TDI?
2.5 with the weird 5 cylinder engine.
  • Congratulations 1
