1 hour ago, Cavcraft said:
There aren't enough 'likes' in the world for that sexy little bastard of a car.
I had use of my Dad's company K-reg Astra LS estate in that colour BITD. With the 1.7 Isuzu turbo dizzle. I wouldn't call it sexy, but the turbo lag was fun.
Robin Hood, Robin Hood stood in my gar den
Picture 1 of 9
Robin Hood Robin Hood, been on fire again
Picture 7 of 9
Fire fucked it bad , left where it's stood
Robin Hood Robin Hood Robin Hood
Picture 5 of 9
Robin Hood 2b Kit Car | eBay
Quote
can’t see it needing much if anything for a new mot
Bollocks!
Quote
Date tested
7 September 2023
FAIL
Mileage
38,614 miles
Test location
View test location
MOT test number
8765 0013 6004
  • Nearside Front Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting inner sill / jacking point / floor area, close to seat mountings (6.2.2 (d) (i))
  • Offside Front Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting inner sill / jacking point / floor area, close to seat mountings (6.2.2 (d) (i))
  • Offside Front Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting outer sill close to seat mountings (6.2.2 (d) (i))
  • Nearside Rear Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting inner sills, also inside wheel arch. close to seat belt mountings (6.2.2 (d) (i))
  • Offside Rear Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting inner sill, also inside wheel arch, close to seat belt mountings (6.2.2 (d) (i))
  • Offside Front Brake pipe excessively corroded (1.1.11 (c))
  • Rear Exhaust has a major leak of exhaust gases rear part of centre pipe adjoining silencer (6.1.2 (a))
  • Front Exhaust has a major leak of exhaust gases catalytic converter flange leaking (6.1.2 (a))
  • Emissions unable to be completed Due to excessive exhaust leaks (8.2.1.2 (d))
  • Rear Exhaust noise is clearly in excess of that emitted by a similar vehicle fitted with a standard silencer in average condition (8.1.1 (a))
  • Nearside Rear Wheel bearing has slight play (5.1.3 (a) (i))
  • Offside Front Tyre slightly damaged/cracking or perishing (5.2.3 (d) (ii))
  • Nearside Rear Tyre slightly damaged/cracking or perishing (5.2.3 (d) (ii))
  • Offside Rear Tyre slightly damaged/cracking or perishing (5.2.3 (d) (ii))
https://www.gumtree.com/p/daewoo/daewoo-matiz-xtra-1ltr-extremely-low-miles/1465955495
86
On 9/15/2023 at 9:43 PM, bezzabsa said:
cheap S type 2005 Silver Jaguar S-Type 2.5 V6 Sport Plus 4dr for sale for £695 in Manchester, Lancashire (autotrader.co.uk)
BUT weak breaks vehicle need new brake servo/booster rest of the vehicle looks absolutely fine, engine/gearbox works great all electrical equipment work, clearing part exchange car hence low price, 1 different alloy original is in boot however 2 bolts needs to be taken off by the garage as they are snapped, 2 keys, mot december 2023 , Silver, £695
Image 1 of 13
Brakes...it's brakes - a 'weak break' is a holiday in Skegness*.
*A holiday in Skegness may turn out to be better for you.
Picture 1 of 9
Picture 7 of 9
Picture 5 of 9
Must have belonged to... Fire Truck.
“Range Rover LS322, 4.4 BMW engine, low mileage, engine and gearbox excellent. Over £500 spent on chrome, she looks great, I get compliments everywhere I go. She’s something out of the ordinary, especially for a 19yr old vehicle., as you can see from the pics.No MOT, requires some welding on subframe, and a new N/S front suspension airba..."
https://www.ebay.co.uk/itm/115914037242?hash=item1afd03d7fa:g:vt8AAOSwCkxlAJsP
Maybe spend the £500 on proper looking after?
Range Rover 4.4 V8  Vogue Petrol Spares or Repairs - Picture 16 of 16
