1 minute ago, D.E said:
It does say so on the bootlid.
The wise Mr. Wikipedia says:
So, the model underwent several name changes it seems.
I must have missed that phase in the middle. I thought they went from SEC to CL!
Spotted my old Volvo for sale at £4995 ono.
Wonder if he has managed to fix the leaking sunroof? I gave up trying. If anyone is interested in it pm me for contact details of the seller.6468a6a631388d89f3479666bac8f17a.jpg
Sent from my SM-A127F using Tapatalk
This looks like proper value and quite genuine too…
https://www.ebay.co.uk/itm/165428612941?hash=item2684504f4d:g:KqQAAOSwKcNiGnQq
Quote
MOT RAN OUT  FEBUARY 2022
Actually, it failed:
Quote
26 February 2022
FAIL
View test certificate
Mileage163,806 miles
MOT test number3289 4799 9110
Test location
View test location
  • Exhaust carbon monoxide content at idle exceeds default limits see print out (8.2.1.2 (b))
  • Exhaust carbon monoxide content after 2nd fast idle exceeds manufacturer's specified limits see print out (8.2.1.2 (a))
  • Headlamp levelling device inoperative (4.1.5 (a))
  • Offside Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced outer sill in several places (6.1.1 (c) (i))
  • Nearside Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced outer sill (6.1.1 (c) (i))
  • Nearside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength structure holed (5.3.6 (a) (i))
  • Offside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength structure holed (5.3.6 (a) (i))
  • Exhaust has a major leak of exhaust gases mid box (6.1.2 (a))
  • Parking brake efficiency below requirements (1.4.2 (a) (i))
Repair as soon as possible (minor defects):
  • Windscreen damaged but not adversely affecting driver's view (3.2 (a) (i))
  • Stop lamp(s) with a multiple light source up to 1/2 not functioning 1 out of 5 bulbs innop (4.3.1 (a) (i))
  • Power steering pipe/hose has slight seepage weaping in 2 places, rack gaitor and power steering pipes (2.1.5 (a))
  • Power steering pipe/hose slightly corroded (2.1.5 (g) (i))
  • Play in steering rack inner joint(s) ()
  • Suspension arm corroded but not seriously weakened both front suspension arms corroded (5.3.3 (b) (i))
  • Coil spring corroded all 4 coil springs corroded (5.3.1 (b) (i))
  • Macpherson strut corroded but not seriously weakened both front suspension struts corroded (5.3.3 (b) (i))
  • all underbody corrosion and covered in underseal
  • Brake disc worn, pitted or scored, but not seriously weakened both rear discs corroded (1.1.14 (a) (ii))
There was a short period in which Mercedes called their S-Class coupe S420 Coupe to S600 Coupe. Makes it a pain to search for one of these as they were sold under 3 different names.
Also WTF would anyone do this to the back of the car?!! Its not a panel that would be easily replaceable either. Sent the seller a message anyway...
Edit: boot damage was at the other S500 coupe currently on ebay. The seller of the blue one is a "professional" breaker and claims that this 1993 top of the line Mercedes never came with cats. There is so much scum out there nowadays...
“Hi dude, I’m looking for a new ride, something cool like a 2 door koop and with plush leather too, I want classy.  When I’m rollin’ round the hood I need my crew to respect me, nuthin less than a V8 will do.  I’ve got better things to spend on than juice so get me a diesel too”
”Step this way sir, this could be your lucky day!”
https://www.ebay.co.uk/itm/284752055988?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=bxeql0ujsym&sssrc=2349624&ssuid=y9xs1hiVQ9O&var=&widget_ver=artemis&media=COPY
Got a link M8? A search doesn’t seem to drag it up
On 4/9/2022 at 1:21 PM, wesacosa said:
I actually found this local to me and got it going. Its in absolutely unbelievable condition and Rick is a good friend of mine. Runs like a sewing machine, it's a pre VW one.
35 minutes ago, garethj said:
Peugeot 206, it looks like the main job on this Gran Turismo version was fitting a massive, ugly bumper
I was wrong, two massive, ugly bumpers
https://www.ebay.co.uk/itm/115337934306?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=N6VMb8J6QMS&sssrc=2349624&ssuid=y9xs1hiVQ9O&var=&widget_ver=artemis&media=COPY
They’re sort of the crappest homologation model ever, just a boggo 206 GTi with extra long bumpers so as to meet WRC regs (a 206 being slightly under the required 4m length). Obviously didn’t have 4wd or 300hp either.
I quite like it.
