Just a touch of acne, maybe the odd hole...   That gets bigger and bigger!
Then you can't find a big enough cereal box for template material.  That's what I call a cereal killer!!  I'll get my coat.:-D
Nice though and the floors look solid.
https://www.ebay.co.uk/itm/Triumph-2-5pi-Mk-1-Saloon/233561566370?hash=item36615aaca2:g:YcwAAOSwNlVemH0k
9 hours ago, The Mighty Quinn said:
Looks like £150 to me tbh. 2000/2200's are cheap enough in nice working order - that's just a money pit.
P6's priced at £500-£1000 usually are quite rotten anyways. As Sheldon of Classic Britain learnt with his early P6 2000TC which in the end was rotten beyond repair.
That 1300 is lovely. I had a 66 1100 about eight or nine years ago - long since scrapped, but I miss it dearly. This never goes down well, but I genuinely prefer them in every way (usability, drivability, practicality etc) to a similar vintage Mini.
19 hours ago, Wack said:
Something wrong with the world when one person has so much money they can store millions of dollars worth of cars and never even look at them
https://youtu.be/Y_Wc_m06pG8
Why????
Walked past this on my daily exercise this morning. £495.
IMG_20200417_102614.thumb.jpg.a2b2a9ddf2a825c3d4a6af522004cc61.jpgIMG_20200417_102600.thumb.jpg.0256a967789707823d9de43da29683e8.jpg
56 minutes ago, tul66 said:
Who's going to mention women drivers first??????
You.
  • Haha 3
https://www.ebay.co.uk/itm/Citroen-Berlingo-First-2008-5-seater-MPV-ULEZ-exempt-sleeps-1/283841449310?hash=item421644cd5e:g:8w4AAOSwLu5ejiAB
Seems an OK Berlingo, a write off but new clutch and bits and pieces done.
But why is it loaded with boxes?
And an old pasting table ?
Hang on , doesn’t the description call it a camper?
What sort of masochist would think a yoga mat balanced on a pasting table and some rickety plastic crates is acceptable as a camper?
Quote: “ Reason for selling is that I’m going to live in a Buddhist Monastery for a year”
Ahhh...
https://www.facebook.com/marketplace/item/209853386929304/
90703842_2571419183133749_85620437229198
Obscurification Skillorz 2
90914246_2571418256467175_16136627168309
Quote
Very good No lights on dash body work is mint Drives perfect New streo Come grab ur self a barging
Barging you say....?
Date tested7 March 2020
FAIL
 View test certificate
Mileage92,112 miles
MOT test number9922 3534 0599
Test location
 View test location
  • Nearside Windscreen wiper does not clear the windscreen effectively (3.4 (b) (ii))
  • Nearside Windscreen washer provides insufficient washer liquid (3.5 (a))
  • Offside Rear Rear fog lamp not working (4.5.1 (a) (ii))
  • Nearside Headlamp aim projected beam image is obviously incorrect (4.1.2 (c))
  • Offside Headlamp aim projected beam image is obviously incorrect (4.1.2 (c))
  • Nearside Headlamp has a product on the lens so that the light output is severely reduced (4.1.4 (b))
  • Offside Headlamp has a product on the lens so that the light output is severely reduced (4.1.4 (b))
  • Nearside Rear Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced sill (6.1.1 (c) (i))
  • Central Rear Seat belt missing buckle (7.1.2 (a))
  • Nearside Front Brake pipe excessively corroded to rear (1.1.11 (c))
  • Offside Front Brake pipe excessively corroded to rear (1.1.11 (c))
  • Nearside Rear Service brake excessively binding (1.2.1 (f))
Repair as soon as possible (minor defects):
  • Nearside Obligatory mirror slightly damaged (3.3 (b) (i))
  • Nearside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c))
  • Nearside Rear Coil spring corroded (5.3.1 (b) (i))
  • Offside Front Coil spring corroded (5.3.1 (b) (i))
  • Rear brakes just passed brake roller test
  • all four tyres cracking on side wall
Its fooking fooked M8
