Finally, a direct rival to the mitsubishi in the giffer-mobile stakes. Buy both and do a feature for Dollywobblers Retro Japanese mag
http://www.ebay.co.uk/itm/Honda-Civic-GL-1-4-manual-EE-EF-EG-EK-/112444266250?hash=item1a2e33570a:g:mBUAAOSw8d5ZQpMe
"The car is a 1.4 multi-point fuel injected twin carb"
So many ways of getting fuel in, no wonder he was gonna turn it into a track car.
NOS Escort that has never had a bolt attached. Weird!
http://www.ebay.co.uk/itm/172729650097
There was a breakers somewhere a few years back that had a shitload of body in white Ford shells. Mk5 Escort, also Sierra I think. Photo on eBay included a barn shot of them all stacked up.
Possibly ex rally stock? WRC Escort was based on a real Escort rather than Cosworth and there must have been a fair few Sierras stockpiled.
What's going on here?
Not sure if he or she.
Shorts? Skirt?
Hairy legs?
I think he's simply taken the Viva back to its birthplace in Ellesmere Port. That sort of thing is normal there.
Probably not rally stock in view of the hole in the roof so just a "normal" shell. I think seller knows that "I am being led to believe...". Quite an opportunity if you have the mechanical bits though. It'll end up as a Cosworth "replica" with a 1.3 OHV engine and 4 speed box with any luck.
Might have been Furber's, as they often had that sort of thing in stock.
This is probably a nice little car under all that dogshit smeared on it.....
http://www.ebay.co.uk/itm/Austin-A35-2-Door-/322553763821?hash=item4b19b3d7ed:g:9DQAAOSwDiBZMrwP
Shiny, gravel drive but still sensible(ish) money
http://www.ebay.co.uk/itm/volvo-740GLE-estate-classic-REDUCED-/192220043475?hash=item2cc13518d3:g:~0UAAOSwi7RZLoh3
Sherpa in natural habitat....
http://www.ebay.co.uk/itm/FREIGHT-ROVER-SHERPA-CITY-VAN-/272722175124?hash=item3f7f822494:g:lB8AAOSwuxFYvrX9
With approved accessory vital to ownership...
Love a cheap one of these to throw around country lanes.....but not this £99 beauty
GOOD TYRES
RLY ?
MOT history of this vehicle
  • Test date1 June 2017
  • Test ResultFail
  • Odometer reading123,130 miles
  • MOT test number3702 9552 7343
  • Reason(s) for failure
    Rear registration plate deteriorated (6.3.1d)
    Offside Rear Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings Seal (6.1.B.2)
    Nearside Front Shock absorber has a serious fluid leak (2.7.3)
    Front Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings Close to front engine mounting (6.1.B.2)
    Offside Registration plate lamp insecure (1.1.C.1c)
  • Advisory notice item(s)
    All brake pipe covered in grease
    Central Exhaust has a minor leak of exhaust gases (7.1.2)
    Front coil spring corroded Both (2.4.C.1b)
    Rear coil spring corroded Both (2.4.C.1b)
    Central Brake pipe slightly corroded Front to rear (3.6.B.2c)
    Offside Front Tyre deteriorated
    Offside Rear Tyre deteriorated
    Nearside Rear Tyre deteriorated
https://www.gumtree.com/p/nissan/1997-nissan-micra-1.0-automatic-bargin-%C2%A399/1249200485
