4a527b914838913996e2106bb19f5fa268cc4c5f
https://www.leboncoin.fr/voitures/1005679100.htm?ca=15_s
f**king wars, look at this for 1250 quid, all running and driving too
Now that is interesting I fly in to Toulouse on Sunday for 10 days holiday. It's within budget but the lack of brakes would mean finding a transporter to deliver it which will probably cost as much as the car. The guy's I have used in the past for deliveries all seem to of packed it in now so I expect it will be even dearer.
http://www.ebay.co.uk/itm/Ford-Fiesta-1-3-Flight-ONE-OWNER-FROM-NEW-LONG-MOT-SERVICED-20-TIMES-/162171259940?hash=item25c2290c24:g:xdcAAOSwZVlXsyP-
i like this too, i wonder if it is as clean as the advert makes out?
MOT history suggests not...
MOT history of this vehicle
  • Test date6 July 2016
  • Expiry date8 July 2017
  • Test ResultPass
  • Odometer reading47,564 miles
  • MOT test number5796 8038 2798
  • Advisory notice item(s)
    nearside front lower Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
    nearside front Brake pipe slightly corroded (3.6.B.2c)
  • Test ResultFail
  • Odometer reading47,562 miles
  • MOT test number8291 4210 4052
  • Reason(s) for failure
    nearside Headlamp not working on dipped beam (1.7.5a)
    nearside rear Suspension component mounting prescribed area is excessively corroded sill (2.4.A.3)
    nearside rear Suspension component mounting prescribed area is excessively corroded innersill (2.4.A.3)
    offside Front constant velocity joint gaiter insecure to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
  • Test date3 July 2015
  • Expiry date8 July 2016
  • Test ResultPass
  • Odometer reading45,625 miles
  • MOT test number3385 2408 5141
    Offside Front coil spring corroded (2.4.C.1b)
    rear shockers weak
  • Test date2 July 2015
  • Test ResultFail
  • Odometer reading45,624 miles
  • MOT test number3373 4388 5176
    Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
    Front registration plate deteriorated (6.3.1d)
    Nearside Rear Brake hose ferrule excessively corroded (3.6.B.4e)
    Offside Rear Brake hose ferrule excessively corroded (3.6.B.4e)
    Nearside Front Brake hose ferrule excessively corroded (3.6.B.4e)
    Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
    Nearside Front coil spring broken (2.4.C.1a)
    Offside Front Suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
    Offside Front Track rod end ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.2.C.1c)
    rear shockers weak
  • Test date16 June 2014
  • Expiry date8 July 2015
  • Test ResultPass
  • Odometer reading42,577 miles
  • MOT test number8665 3746 4179
    Nearside Front coil spring corroded (2.4.C.1b)
    Nearside Front Brake hose has slight corrosion to ferrules (3.6.B.4e)
  • Test ResultFail
  • Odometer reading42,576 miles
  • MOT test number7254 6736 4103
    Offside Front Brake hose ferrule excessively corroded (3.6.B.4e)
    Offside Front Seat belt anchorage prescribed area is excessively corroded (5.2.6)
  • Test date12 June 2013
  • Expiry date8 July 2014
  • Test ResultPass
  • Odometer reading40,007 miles
  • MOT test number4886 4376 3120
    Offside Front Tyre worn close to the legal limit (4.1.E.1)
  • Test ResultFail
  • MOT test number3695 8356 3145
    Offside Front Brake pipe excessively corroded (3.6.B.2c)
  • Test date3 July 2012
  • Expiry date8 July 2013
  • Test ResultPass
  • Odometer reading37,787 miles
  • MOT test number4567 5588 2136
    Offside Front Brake pipe slightly corroded (3.6.B.2c)
  • Test date5 July 2011
  • Expiry date8 July 2012
  • Test ResultPass
  • Odometer reading35,686 miles
  • MOT test number1185 1688 1171
  • Test date9 July 2010
  • Expiry date8 July 2011
  • Test ResultPass
  • Odometer reading34,291 miles
  • MOT test number8732 9079 0191
  • Test date6 July 2009
  • Expiry date6 July 2010
  • Test ResultPass
  • Odometer reading32,160 miles
  • MOT test number8100 1768 9130
  • Test ResultFail
  • MOT test number5102 6738 9179
    Offside Headlamp not working on dipped beam (1.7.5a)
  • Test date4 July 2008
  • Expiry date6 July 2009
  • Test ResultPass
  • Odometer reading30,036 miles
  • MOT test number7826 0628 8135
    Offside Front Lower Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
  • Test ResultFail
  • MOT test number7326 2658 8166
    Offside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
  • Test date4 July 2007
  • Expiry date6 July 2008
  • Test ResultPass
  • Odometer reading27,590 miles
  • MOT test number1738 1598 7164
  • Test ResultFail
  • MOT test number2619 8548 7473
    Nearside Brake pipe excessively corroded (3.6.B.2c)
    Offside Brake pipe excessively corroded (3.6.B.2c)
    Nearside Front Anti-roll bar linkage has slight play in a pin/bush (2.4.G.2)
  • Test date4 July 2006
  • Expiry date6 July 2007
  • Test ResultPass
  • Odometer reading25,841 miles
  • MOT test number3141 9598 6181
    Nearside Front Torsion bar slight play at an end fixing (2.4.E.2)
    Nearside Brake pipe slightly corroded (3.6.B.2c)
    Offside Brake pipe slightly corroded (3.6.B.2c)
i think i'll pass.......
Yikes. That Croma is hot. Shame that cycling through the photos makes it look less hot. That roof rot does look a tad scary.
I had a dream last night about how this shape Fiesta are disappearing like snaw aff a dyke (Eng: snow from the top of a wall) and will soon be a forgotten car - the previous Valencia powered one seems less rust prone.
Buy it then!
1999 VOLKSWAGEN PASSAT SE TDI BARGAIN TOILET CLEARANCE CHEAP SHED DRIVES MINT
Cleaner than my toilet.
http://www.ebay.co.uk/itm/1999-VOLKSWAGEN-PASSAT-SE-TDI-BARGAIN-TOILET-CLEARANCE-CHEAP-SHED-DRIVES-MINT-/152217111527?hash=item2370d8cbe7:g:3dcAAOSw-itXvWDX
Any good fur BUB?
in Oldham less than 200 and 17hrs to go.
Its only at £214, looks like he has emptied at least £300 worth of silicone spray on that interior.
One for the Junkman photo album (this is the only photo on the listing)...
https://www.gumtree.com/p/toyota/toyota-camry-sport-2.2-automatic/1184785480
I like Camrys but I was looking at one in a car park and it was bigger than the E-class sat next to it (ie; much bigger than I need or could be arsed with). That early brown Estate would be nice but I've had obscure 80s J cars before and getting parts can be a ballache, even if the car was popular in America.
The 2.2 is a Toyota 5S-FE engine so in the same family as Turbo Celicas and MR2s (3S-GE). I know it's a bit RR but I wondered if anyone has either done a swap?
