That Mini is lush!
http://www.ebay.co.uk/itm/CLASSIC-MINI-1000-1977-/172157737801?hash=item2815669b49:g:D6gAAOSwQoFWQSLb
'If the winning bidder would like to put wide arches, a centre exhaust and a "Mini owners do it..." sticker on, I'll come round your house, remove the subframe with your sawn off knob and stick the bastard right up your council'
Horrible colour, I genuinely couldn't live with that, but it just screams not to be restored, as loud as not to be barried.  It's a perfect timewarp to 1989.
Gooner ABS Roulette anyone?
 It was recently parked on a grass verge, and on moving it the nearside front wheel has spun on the wet grass. This has put on the ABS light which might be expected, however it has stayed on, which was more of a surprise! We're not really into Renaults so don't have the correct diagnostic equipment for the car, and we've even less inclination to get involved. Be aware that the ABS system on this car also regulates the speedo and tyre pressure monitors, so these won't work properly until the problem is sorted.
Is that right? Another gr8 design feature if that's the case.
Sounds a load of bollocks to me. The tyre pressure monitors are shit on these but can be turned off easily with the right bit of kit. To be honest an abs fault is probably one of the easier things to fix on a Laguna 2
ABS Sensors often control speedos nowadays and traction control, not sure about tyre pressure monitors though.
Turbo diesel Corsa in Manchester, ending shortly, no bids yet on 200 quid start.  Billy?
There was a Laguna II estate on eBay, ended earlier today - one of its "features" was that you could only open the boot if the headlights were on.  Renault electrics do not follow normal logic or laws of physics.
Endemic FCC: French Canbus Cancer.
Styling dept, not a tour de force with hearses were they!
