Ohh, just what I am after  :-D
- Colour
- Brand
- Engine
- Cruise control
Time left: 6h 45m
High bid: Â£720
http://www.ebay.co.uk/itm/1993-DAIMLER-4-0-AUTO-BLUE-/262318276843
only known issue alternator light on and no currant MOT on the car
Sounds great!
Oh, I can see from the photos you're a garage with a nice indoors two-post, maybe I can look it over and you can sort a ticket on for me then? Let me check your number
CONSERVE CAR CARE MOT Centre located at Redditch (B98 7AL) Tel: 01527 63261
Oh!
Ok then
MOT history of this vehicle
  • Test date 1 October 2014
  • Test Result Fail
  • Odometer reading 128,236 miles
  • MOT test number 8065 7457 4251
  • Reason(s) for failure
    Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.3)
    Exhaust emissions hydrocarbon content after 2nd fast idle excessive (7.3.D.3)
    Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.3)
    Windscreen washer provides insufficient washer liquid (8.2.3)
    Offside Inner Front Upper Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Front Front position lamp(s) has less than 50% of the light sources illuminating (1.1.A.3b)
    Nearside Rear Front position lamp(s) has less than 50% of the light sources illuminating (1.1.A.3b)
    Nearside Inner Front Lower Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
    Offside Inner Front Upper Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
    Nearside Front Upper Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
    Offside Front Upper Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
    Nearside Front Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
    Offside Front Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
  • Advisory notice item(s)
    Nearside Inner Front Upper Suspension spring mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    Front Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    Nearside Rear Upper Body has slight corrosion (6.1.B.2)
    Offside Rear Lower Body has slight corrosion (6.1.B.2)
    Rear Body has slight corrosion (6.1.B.2)
    Nearside Rear Upper Vehicle structure has slight corrosion (6.1.A.1)
    Offside Rear Upper Vehicle structure has slight corrosion (6.1.A.1)
    Nearside Front Front wheel bearing has slight play (2.5.A.3c)
    Offside Front Front wheel bearing has slight play (2.5.A.3c)
    Nearside Rear Front wheel bearing has slight play (2.5.A.3c)
    Nearside Rear Sub-frame rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
    Offside Rear Sub-frame rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
    Fuel pipe/s corroded
    n/s/r tyre has cracks to sidewall
That Allegro is PBV 278T.... I used to have PBV 220T.  Just sayin', like.  I can see this being perfect for Marvin's Mom.
Cop a load of this!
Here is a Ginetta G26 based on a 2 litre Pinto engined Cortina from 1976.
This is a kit type of car consisting of a glass fibre body with steel doors from a Mk1 Fiesta. This is the top option as it has a galvanised chassis so has next to no risk of structural problems
Yeah I heard they were reknowned for their structural rigidity
http://www.ebay.co.uk/itm/172125722186?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Check out this sellers gear. Think he must be a small-town arfur daley type, with Bipolar pricing.
Reasonable start:
Saxo Forte - tidy with MOT and 76k - £0.99 with a ?reserve
Better:
2.5 DSE - leggy at 160k but 7 months MOT and all faults repaired - £1.5k
Winner:
25 GTS
One owner, FSH, currently 1k on an auction
http://www.ebay.co.uk/itm/222042649950?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Then this:
Heritage body shell with full rebuild and brand new/ reconditioned everything. But still
£25,000
wtf man?
He's got a ton of old BL spares too, all similarly priced all over the place.
http://www.ebay.co.uk/itm/391395789768?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
MIne's cheaper.
Cannot find advert.
my eyes are not good enough to detect rot in that floor but on the whole it looks pretty good to me, unusual colour too
the floor of that allegro looked to me at least to be a suspicious brown colour.
maybe its just surface rust, but, been a pessimistic person i did wonder if it was more that just surface deep......
oddly enough on the car spares bit on ebay there are all sorts of repair panels fopr the allegro including scuttle p[panels and back window panels just like whats crusty on the tara green one!
Like castles?
Like bouncing?
Like old VWs?
Step this way, sir. Please remove your shoes. And your brain.
http://i.ebayimg.com/00/s/OTYwWDk2MA==/z/2BMAAOSwvgdW4Wy3/$_57.JPG
'This is a convertible hard top'
Call me cynical and paint my bollocks blue, but I'm pretty sure if you Googled 'hard top' you won't actually find a picture of the padded walls of a Charlie Chalk's kids soft ball play area.
