Ahoy team,
What's the consensus on these little Rav4s? They're getting fugging cheap, but I assume are ruinous on tax and MPG?
£400 for one with MOT and with the price of petrol what it is, are these a good winter 2-litre beater? Plus they're almost classic insurance now (WTF?).
http://www.ebay.co.uk/itm/121858166842?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
STOP PRESS
A laguna DCI that has MOT and runs
The car has MOT until 22nd February 2016 and will need some work to get it through:
            the low beam does not work which I believe is due to the stalk as the lights and bulbs themselves are fine.
The front nearside shock top mount may need replacing, I have looked at it basically the two discs are a little notchy which I hoped to overcome with grease but the noise is still there, I'm not sure if this would be an MOT failure but I've found that the part is between £65 and £120 from GSF etc.
I believe these would be the only issues for MOT, two more things of note would be that one rear door seal could do with being replaced and the front bumper/inner arch plastics could do with some attention as a few bits are missing and part of the bumper is held on with a cable tie.
99p
http://www.ebay.co.uk/itm/262256198117?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Farmers favourite for £100
The reason the car is advertised as spares/repairs is that the back box has snapped from the main pipe and that the bolt on cradle that hold the rear diff, suspension links etc has corroded and needs replacing. This part is readily available and seems on a quick inspection to be a fairly easy fix. The car does drive but wobbles from side to side.
http://www.ebay.co.uk/itm/281917156847?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
That BX is a rare survivor, but not as rare as the Reliant behind it, which is the only yellow Reliant van not to have Trotters Independent .....etc painted on it.
How much would that Merc have been new - £60-£70k???
£56,400 before options according to CAR November 1989, so yes.  (S-class saloons had been relegated to the 'Boring' section of the GBU by then, incidentally.)
A V8 SEC of this era is on my bucket list but an SEL is just a bit too vast.
According to the Bank of England's inflation calculator that £60k in 1989 is equivalent to £134,653 today  :shock:  :shock:
Which sounds horrific - but I just looked and a new S600 is listed at Â£142,735.  Also  :shock:  :shock: .   (The S-Class range starts at about half that.)
The new LWB Range Rover starts at £106k. The next trim level up - the SVAutobiography (whatever that is) starts at £156k :shock:
No way did I thought they were worth that much seeing them on the road.
That blue Metro is lovely, shame it looks a bit frilly and is probably more so underneath!
The wheel trimz look great though.
Ahoy team,
Tax isn't going to be an issue with this, it's only the 1550cc split at this age, so it'll cost the same as any other 2-litre.  Insurance, no idea, probably no worse than an MR2 though.  I quite fancy one, having had a soft-top as my rental car the first time we visited Cyprus.
edited to add: I've looked at the listing now.  Holy shit, you had to post that didn't you?  Right price and a proper gearbox!  The only thing keeping my credit card in my wallet is the distance involved.... probably just as well though!
can someone please decipher the reg plate number from the ebay ad on this little Sei? Ta! (Or tell me how).
http://www.ebay.co.uk/itm/FIAT-SEICENTOS-/272114541555?hash=item3f5b4a63f3:g:yAcAAOSwLnlWpNc1
W465YTW
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewJumpPageForVehicleHistory&vrm=VzQ2NVlUVw%3D%3D&vrm_d=W*** ***
Take the bit after VRM and before the &amp and url decode it here
http://urldecode.org/
Then base64 decode it here.
https://www.base64decode.org/
Top security there ebay.
Shit the bed.
Better have a derisory punt on this one then...
No MOT
http://www.ebay.co.uk/itm/121870923191?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
If I win it for tuppence I'm gonna cover it in 'VVTI yo' and OLLI stickers.
Possible bargain for someone
Long MOT, £100/submit best offer
'Non runner. Keys wont turn in ignition'
Look at this Musso!
  • Low miles (69k)
  • More than 12 months MOT (previous one had a load of advisories, most now gone - hopefully all fixed in the last year??).
  • Bickle-approved towing capabilities to boot!!
  • £650!!!
https://www.gumtree.com/p/ssangyong/ssangyong-musso-2.9td-gls/1152165758
MOT history of this vehicle
  • Test date 25 January 2016
  • Expiry date 11 February 2017
  • Test Result Pass
  • Odometer reading 69,370 miles
  • MOT test number 5708 5824 4847
  • Advisory notice item(s)
    nearside Front wheel bearing has slight play (2.5.A.3c)
    offside Front wheel bearing has slight play (2.5.A.3c)
/\ /\ Over budget and won't deliver to door for a bacon butty.
1.2 Diesel!!! You must like driving to own this as you will be spending a fair chunk of time behind the wheel getting anywhere.
