PhilA Posted December 16, 2018 Author Posted December 16, 2018 The other aspect of this is using the same gauge wire, I'm running lower current. So, to fit the analogy, I can have the smaller team pull harder by reducing the number of people pulling and replacing people with noodle arms for people who are physically bigger and stronger, but they take up more room because now muscle bulk so I can fit fewer on the rope.Therefore, I remove two weaker people and replace one stronger, all that happens is I get the same pull but the one person has now to work much harder for the same net result. I'm going to add a second rope to it and see if that helps. If it does I'll invest in people who are stronger and a slightly longer rope. Phil DeeJay and LightBulbFun 2
somewhatfoolish Posted December 16, 2018 Posted December 16, 2018 cort1977, LightBulbFun, Squire_Dawson and 2 others 5
DeeJay Posted December 16, 2018 Posted December 16, 2018 Thanks for that explanation, I had completely lost what was going on until that. It’s a good project this I'm sitting here nodding as though I understand it all.I still don't have a clue. egg and PhilA 2
egg Posted December 16, 2018 Posted December 16, 2018 I think you need this button (me too!!) adw1977, timolloyd, stonedagain and 2 others 5
PhilA Posted December 17, 2018 Author Posted December 17, 2018 Coerced the wife into helping in the garage. Unwound 1000 turns (3 times up and down the garage), started winding it back on, got 300 turns in and the old wire broke. She was real enthusiastic about being out in the cold. Going to unwind it and start over tomorrow. Phil LightBulbFun, DeeJay, mat_the_cat and 7 others 10
DeeJay Posted December 17, 2018 Posted December 17, 2018 Going to unwind it and start over tomorrow. Phil?Does she know she's vounteered again? LightBulbFun 1
PhilA Posted December 17, 2018 Author Posted December 17, 2018 I just thought. I should put a trimpot across the first coil. Phil somewhatfoolish, LightBulbFun and loserone 3
somewhatfoolish Posted December 17, 2018 Posted December 17, 2018 Yes, get it to work on a breadboard, then fuss about getting it right elegantly. LightBulbFun and PhilA 2
PhilA Posted December 17, 2018 Author Posted December 17, 2018 It's all alligator clips and such because I'm just clipping to the fine stands of wire rather than soldering then every time. Phil LightBulbFun and somewhatfoolish 2
PhilA Posted December 18, 2018 Author Posted December 18, 2018 Found a little time to experiment and actually look at the way the thing's wired- the right hand coil is actually in series. The coils are wired center tap Y. So I put a resistor in series with the left hand coil. Initial experimentation proves promising, with odd bias due to the winding of the coils as they currently are. I'm going to rewind the coils back to stock and try bring the left coil down a little with the trimpot. Phil scdan4, tooSavvy, somewhatfoolish and 3 others 6
PhilA Posted December 21, 2018 Author Posted December 21, 2018 Freshly wound coils, 1000 turns and 1500 turns. I need to solder up a couple new trimpots- with the other testing before I have burned some "null" spots in the current ones right around the value I need them to be smooth, but it feels like from here all that's needed is a bit of adjustment and pfaff. Should be able to use a fixed value resistor afterwards and have it accurate enough as a bias. It'll then be nice to actually get back to doing something that's not actually gauges on the car! I need to start redoing wires for the dash illumination, and then the rest of the car. Phil DeeJay, Coprolalia, scdan4 and 5 others 8
Clanger Posted December 21, 2018 Posted December 21, 2018 You know Phil, I haven't a friggin clue what you are doing... but I am enjoying watching you do it. Keep up the good work! Dan_ZTT, stonedagain, DeeJay and 3 others 6
PhilA Posted December 21, 2018 Author Posted December 21, 2018 I'm making the bits nobody will ever see all nice and shiny. Phil tooSavvy and Dan_ZTT 2
tooSavvy Posted December 21, 2018 Posted December 21, 2018 I'm making the bits nobody will ever see all nice and shiny.Phil..... Spoken like the man on ColdWarMotors. He 'refurbed' his Press-0-Matic dash trannie change buttons using less scabby Heater/Vent buttons. This tredd is GR9 Squire_Dawson, PhilA and Junkman 3
PhilA Posted December 22, 2018 Author Posted December 22, 2018 I think I've got it. With 120 Ohms across the left coil the gauge is pretty accurate. I need to get a resistor capable of at least 2 Watts power handling to put in line. Soon to be on order. I also took apart and cleaned up the cigar lighter assembly. That was quite therapeutic. Phil mat_the_cat, DeeJay, scdan4 and 8 others 11
Snipes Posted December 23, 2018 Posted December 23, 2018 Only pretty accurate? Pffft. PhilA and LightBulbFun 2
PhilA Posted December 23, 2018 Author Posted December 23, 2018 It's accurate to the center of the scale and towards the hot side. It over-reads by about 10F at the bottom of the scale. I decided it was more important to know if the engine was hot than if it is cold. Also now looking for 3/16" brass oval head tubular rivets. I don't want to solder the original rivets for the center pin connection on the bulb holders. I want to reproduce the original crimped style connection to tolerate heat better in case I decide to nix the LED dash illumination... Phil somewhatfoolish and mat_the_cat 2
PhilA Posted December 27, 2018 Author Posted December 27, 2018 Well, there we go. My temperature gauge is calibrated and operational. Bench test there shows it reading correctly. Mounted temporarily back in the dash cluster, and it works correctly with the common ground. Quite happy with that. Phil Scruffy Bodger, Saabnut, Snipes and 12 others 15
PhilA Posted December 27, 2018 Author Posted December 27, 2018 Pulled the gauges out of the frame. Started taking the old black paint off. Looks quite nice with the chrome all shiny but while impractical for sunshine reflections. Masked it all up with fine line tape. Blown over with satin black. All pulled off and gauges back in. Oh yes, that'll do. Phil Scruffy Bodger, 3VOM, Crusty Sills and 21 others 24
Rocket88 Posted December 27, 2018 Posted December 27, 2018 One in my 88 was chrome...............never had a problem with glare.......probably because British weather...... PhilA 1
PhilA Posted December 27, 2018 Author Posted December 27, 2018 I've seen pictures where people have taken the paint off and polished the metal up, however I really like the contrasting black and silver. Here though- sunshine is definitely an issue! The upper edge of the little "shelf" that sticks out would be evil for bright reflections. You can see how bright the fluorescent lights above my bench reflect in a line in the pictures. I may temporarily pop it back in the dash today to see what it looks like. It may yet get a bit of a rub down and a repaint, haven't decided. Depends how lumpy the paint came out. By now it should be mostly dry (it's warm but humid with rain). Phil Steve79 1
PhilA Posted December 27, 2018 Author Posted December 27, 2018 Saw an area that I missed with the paint last night. Started to mask it all back up again. Rubbed it down with 1000 grit. Nice new even coat of black. All the masking removed. That's better. Greased up the gears in the odometer. Repainted the speedometer bucket and reassembled it. And put it all together with the lights all lit. Going to wait for the paint to fully harden, but that's one thing off the checklist. Phil Dan_ZTT, egg, MorrisItalSLX and 19 others 22
dollywobbler Posted December 27, 2018 Posted December 27, 2018 Lovely. LightBulbFun, jumpingjehovahs and PhilA 3
DSdriver Posted December 27, 2018 Posted December 27, 2018 Freshly wound coils, 1000 turns and 1500 turns. I need to solder up a couple new trimpots- with the other testing before I have burned some "null" spots in the current ones right around the value I need them to be smooth, but it feels like from here all that's needed is a bit of adjustment and pfaff. 20181220_210544.jpg Should be able to use a fixed value resistor afterwards and have it accurate enough as a bias. It'll then be nice to actually get back to doing something that's not actually gauges on the car! I need to start redoing wires for the dash illumination, and then the rest of the car. PhilSomewhere in the UK a BT phone installation is missing some wire... PhilA and LightBulbFun 2
paulplom Posted December 28, 2018 Posted December 28, 2018 One for the dash at night. LightBulbFun and PhilA 2
Guest Hooli Posted December 28, 2018 Posted December 28, 2018 From a time when dashboards were nice to look at & provided the information you actually needed. Rocket88, PhilA and LightBulbFun 3
purplebargeken Posted December 28, 2018 Posted December 28, 2018 I'm making the bits nobody will ever see all nice and shiny. ^^ This was all you needed to say................ ever. All this magic about wires and winding and stuff, it's just scary. PhilA and DeeJay 2
LightBulbFun Posted December 28, 2018 Posted December 28, 2018 Nice work on the dash is that with LED bulbs? it gives it a vintage fluorescent Juke box look like its being backlit by an 8W T5 tube (I wonder if anyones ever done a fluorescent tube backlit dash? the closest I know to that was in aircraft where they used UV/Blue fluorescent Tubes to make fluorescent dials glow) I'm making the bits nobody will ever see all nice and shiny. ^^ This was all you needed to say................ ever. All this magic about wires and winding and stuff, it's just scary. so on a scale of 1-10 how scared does this make you? (just a small* thing I did back in early 2012 when I had a 1Kw Mercury lamp but not the correct ballast to run it with, so I lumped a bunch together to try and hit 1Kw, in the end I only managed about 500W before running out of ballasts) purplebargeken, egg and mat_the_cat 3
