Post Apocalyptic Shite
I have always been fascinated with a post apocalyptic world.
It may yet happen, who knows....
What would you drive? It would have to be an old diesel. Petrol would be near impossible to find but diesel may still be available, or if not then other things could be sourced that would work in an old diesel.
You wouldn't want any electrics in the engine. Batteries will die eventually so you want something that will run without a decent battery, you can leave it on a hill and bump it to start.
Spares will no longer be available so after a decade or so cambelts will no longer be an option.
Clutch slaves will fail too eventually. Brakes are not important, just slow down with gears and stop on the handbrake
What does that leave left running? Old tractors?
Steam powered stuff like traction engines? Solid enough roads for them to run on could be increasingly hard to find, though.
Merc 300D W123. Sure, a 240D might be more economical, but sod it. The world has ended and the five-pot warble might allow me some enjoyment.
XUD Berlingo with the stop solenoid removed.
Daresay some smart arse would convert a solar panel - into collecting radioactivity - wire it up to a Prius and fuck me -go like a drag car :-)  although sitting in it will produce scabs and an extra arm
I'd be staying inside with a air rifle until the baked beans run out.
Coprolalia correctly established in the eBay thread recently that the only things that will
survive a nuclear blast are 90s Toyotas and cockroaches.
I don't know how to tell the two apart, but he is right.
Knowing my luck, my chances of being among the survivors would be zero, so if anyone  thinks a scruffy, Cat C nuclear holocaust damaged Mazda could be useful, feel free :)
Volvo 740.
Even after an EMP from a nuclear blast the bastard headlights woukd still be on.
Cambelt done in 20 minutes using tights.
any 1990's toyota.
petrol - diesel, it doesn't matter.
similarly the actual model doesn't either, though the Hi-lux, corolla and the starlet would be my best guess for still running after world war 3.
You can have whatever you want, there's just you and 10000 single women to repopulate the planet
I would suggest a large V8
It will be the Ford Model T, which is the car of the future anyway.
Magneto ignition, designed to run on Ethanol, on which it indeed runs actually better, no brakes,
hence no brake parts needed.
When Henry decided to build it en masse, he didn't know whether there will be enough petrol to fuel them,
so his idea from the onset was to design it for bio fuel and farmers to allocate part of their land to plant
distillable crops.
Something that keeps fascinating me in every post apocalypse film I ever saw is that the preferred conveyance
when resources are scarce for the baddies are the biggest bloody V8s ever and the goodies walking across
a landmass at least the size of Africa while carefully ignoring every bicycle or moped by the wayside.
A Ford Falcon XB Coupe...
Wrong fuel
Yes this would be my choice
Great til the cambelt snaps
land rovers and hiluxs
Yep. Not sure about hydraulic clutch or not though
Depends how much fuel you leave in it
Volvo 740.
But where are you going to buy the new cambelt? Will the tights be given to you or will there be a fight?
I have two old diesels,
1986 Peugeot 205 xud,and my converted FE estate,
both old school engines.
I think the FE would be a good Post Apocalyptic car,
raise the suspension,fit a bull bar and cover the windows with sheet steel and it's good to go.
Bring it on.
70 or 80 series Landcruiser.
Almost nothing electrical needed, take the stop solenoid out park on a hill and bump start the sods if no batteries available
Micra K11 - the very definition of an automotive cockroach
2CV or something eastern european. Mostly because they're designed to be fixed with a big hammer and fueled with the crappiest fuel imaginable. So that homebrew moonshine will work great in it.
Failing that, a quad bike or motorbike. Most can be started without electrotrickery and again, run on shit fuel. Plus the added durability is useful when roads are turning to shit from lack of people to maintain them.
Actually this describes an old yank much more.
Especially the 2CV is reliant on some pretty good quality essence and huile, whereas an old yank will win the Daytona 500
with four quarts (whatever that is) of Pennzoil detergent and some crew members pissing in the tank after a good night out.
Except The Stand (Stephen King) Frannie and Harold use pushbikes and small motorbikes
Toyotas do not make a gratifying crunch noise when stood on, nor do they exude noxious yellow ooze.
One of these..... although I am pretty sure some meddling Gubbermint types would survive the holocaust and before doing anything constructive would immediately ban anything that I would want to drive.
BMC B Series diesel  FTW
I would put my Cowley interior in it though.....
Is that a euphemism?
