ShiTe170- Moogs Mootahs
That car looks stupid and dangerous mate, you want a nice wafty Benz.
PS: I would like to apologise for the horrible faux-leaded windows on my house, the previous owner fitted them OK?
2 hours ago, DVee8 said:
Who does the rebuild? not that i need one but always handy to know.
I'll dig out some details and pm you tomorrow chap.
Since the Volvo joined the Puss fleet it has had issues with wheel balancing.
Rather than fix it by getting them balanced I did the sensible thing and bought a set of 15 inch steels from eBay with winter tyres.
They came today and so after the rainstorms stopped I slapped them on.
c1cd6413066659c0db808783af817b85.jpga5dcdde57e80e7f4f6c2948fc871437a.jpg683f7a657d784c9eee9eab008a9b9c2b.jpgd46e89017260bc762a5d0a428dffbba0.jpgefbe4aa69402ad041a2bfab3c5f5e961.jpg
The old tyres are a bit knackered
bc917787b521100c4b42512bbe73290f.jpg6d0b66c2868da2b0310e5664004dc3c2.jpg8b035a237ffc14d999c95a2a66cb2392.jpg
The steels I think look better on it than the alloys. They are quite rusty so the plan is to run with them as they are for now and at some point to take them off, derust and paint them.
Discs could do with changing at some point
At this point my jack broke. Luckily the spare jack came to the rescue but I had to afford a fix
The clip that pulls up the wee ram came unclipped. 5ebaf76f31c5cf47ccd0e339610b7886.jpg89ef793c18d1af5afb0eca2570f2218a.jpga187b0e04a42f828732ca3d46e7fa476.jpg4d91e93e9f935d99dda08c48768c3de6.jpgeae58e04d1d1b35a69f0814cba1a6bdf.jpgbb34abaaf1e7996ae96a5083b97eda9f.jpg
All fixed and back together.
A set of abs rings also arrived in the post, so that will be next job to fix the abs fault and traction control light. The car will then need an alignment to sort that bit out.
The brake light switch has come for the SMART so that will be fixerated in next couple of days.
I've been doing the brakes on the P2 this afternoon, they look pretty much identical even down to that clip, fiddly buggers they are! Looks like a lucky escape with those tyres too...
With all this work going on have you got an assignment that needs done?
Shhh that starts again at the end of next week!
Tyres weren't great. It's like a different car with the new set on.
There is an estate up for sale in Warrington for £300 with MOT till June 2020. Missus SP has threatened violence if I accidently buy it... I had thought about buying it and then sorting out one good one between them and then selling/scraping the other.
pics if this happens :D or video if shes got an ace left hook :D
pics if this happens  or video if shes got an ace left hook
She is Scottish ... I won't stand a chance.
Today I wandered over northern monkey motors in the turbo, smart turbo obvs.
Put the car on the ramp
It's a case of drop the front undertray down to access the brake light switch ca4fe7b6d99d6df264c9088f0912923c.jpg
06f10ccd1b2a1ec1d5ddb8db8d49b05d.jpgsomeone has been in there before
This is the old switch
We were ably assisted by garage dog
It fixed it initially but then it has gone to the old ways.
On a trip to shops tonight the car started being more random, interior lights kept coming on and off, central locking stopped working, headlight buzzer worked occasionally. I think it is going to be a SAM issue.
After I got the SMART off, Harmonic Cheeseburger had arrived for a quick fettle of his brakes
His Micra is a lovely old straight thing
Post came from China this morning and this beauty came
An omp copysuede wheel. It is 320mm so a bit smaller than the momo which is better for autotesting.
The old wheel is nice but very large
Beauty of it being momo one is that the boss is already fitted.
The screws were a bit narled up so had to be careful getting them out. The new ones are a touch longer
Came with different horn connectors as well
You can see the difference in size
The horn buttons come in two very different styles. The momo one has a metal ring to fit it to the wheel which sits behind the centre part where as the new one sits in front of it but then has a plastic cover on top.
The new horn button broke almost immediately so I have put together the old one.
If I get a chance I will paint it black and it should be ok
Looks not too bad.
  • Like 11
why not put the included centre ring on to hide the silver bit?
It doesn't fit. The silver ring is a good fit (being from the momo wheel) and the horn button sits inside it but proud of the wheel
The OMP knock off is a recessed plastic piece and they don't go together.
In other news I found a boost gauge in my garage and fitted it this evening.
Launching onto the motorway shows that it is doing about 9 psi of boost...
put the silver ring between wheel & bosss?
It won't fit. The horn button then isn't raised enough to work. The metal ring isn't symmetrical one side is folded over and that is where button sits, the other side is flared.
Will get some photos later to show it.
Thinking Rover...
You've got fuel (we think), you've got spark, you've presumably got compression...have you got everything at the right time though?  If you've got spark I'd expect it to go on easy start.
Timing belt jumped?  Worth checking that TDC is where it thinks it is?
Also worth making sure the plugs aren't drowned in fuel by now...get them out, then attack them with a blowtorch to get them really hot, refit and see if you get any more signs of life.
nice looking wheel, can you fit the thin silver part behind the wheel then use the black trim on the front of the wheel ? mine is a very similar set up
Life has been a busy week in last week so no car work.
What did pop was photobucket saying it was going to delete my photos. I hadn't realised I had some on there.
I think I put up pictures of my sans before but came across some I had forgotten
Not in chronological order
Caravelle that was going to be turned into a camper
Ended up selling it and just buying a camper
935d6922309dc2e45a00dfb967415bc3.jpg1c77f8a6123c63ffed1b0bad70b66ef8.jpg6bcd0e35bf6bfe9ef530f672d0162441.jpg
Nice van but sold to go to Cambodia.
The original camper bought from dollywobbler - Bernard
Sold to a couple of US airmen who were going to ship it back to the US.
Just a Volvo
Another slightly banger rallied Volvo
Raised about £8k for charity with that one.
Previously managed to raise £4k with an escort
That got there but had only two gears, so to get home we spent a euro on this
What a beast.
Another saab - 8v turbo I think, bought fairly cheaply. Started cutting out when warm and I didn't have space to work on it. I sold it and the guy worked out it was the hall sensor breaking up
613cf888fb816f1c3bb8388b6294715b.jpgcc0c8469e183bb7d708bd7c372d8abc9.jpg863932a0fb580a00cfcc0a4bbec3d035.jpg
eBay purchase time - was something silly like £150, less than the guy had paid for the new exhaust. I was sworn to secrecy and told his wife it was double that purchase price
82886c6c3dec67a3ece973c0959afdee.jpg3e08ecc7a47ab06879a11b325dc1da3b.jpg7196ccd01a8de4fae59eaa1b1fd1f92b.jpgd24548b46392238d4f9c2ad4c9cc036b.jpg9fcc2c6a462c742ba4364466faa792cb.jpg
Super straight, super quick. Gearing sucked donkey Wang though as 70 was 4k. Swapped it for this
The guy who swapped it with me had bought it for drifting then realised it was fwd. Had the V6 in it but bugger all power. He then destroyed the 323f GTi by slamming and ratrodding a mint car.
Sold the Audi to someone on RR. Simmo from AS managed to help me break into it when I locked myself out.
Missus Moog loved a Micra or two
Twister spec
Shat its gearbox on the way to a flight at Gatwick. Which wouldnt have been so bad except I had been celebrating/commiserating theast home game ever at my football club. So rolled in hammered at 6 am with us leaving at 7. Standing at side of M25 swaying and not being sick didn't make for a happy relationship - not helped by her breakdown cover only doing a 10 mile coverage.
Went through a run of xantias - so wanted to love them but never did
Also had a run of Volvo v40s - capable of yawnsome cars
All of them were written off in accidents so make them the most profitable type of car I ever owned - phact.
More ramblings and random photos if and when I find them
On 9/4/2019 at 7:47 PM, snagglepuss said:
Head studs need to be sorted before I chase Dome round the track
Are these the droids/bolts you are looking for ?
SMART has been having little electrical maladies recently including hill hold not working, car randomly beeping, central locking working intermittently, headlight warning buzzer working once in a while etc.
Often this points to SAM module. Following the evilution instructions I thought I would take it out.
Carpet up
Battery off
Hmmm not sure cable ties are factory fit
Many many plugs
bd20fea7efa0b169bc62cfecdc28384b.jpg46ffde42bae537751b5a7eb64965bb87.jpgloads of photos taken to ensure I don't forget where stuff goes.
The last thing to do is the bolt holding the power cable in. This should have a cover over it - it has gone walkies.
Bugger - the bolt sheared off.
Writing is a bit worn
Undoing the case there are broken clips at the side as well
Never great sign. Board out and they look ok, no obvious water ingress at all
c4244f226fe6e0abe09d94938abab7d7.jpg788f198d119c4027e0367059c77aeb02.jpga73be7c34c2962a29bc8e655096a4457.jpg
So basically need to get the SAM repaired/cloned. Will have to hunt on line for options.
In meantime missus Puss has been driving the 850 estate which she likes more than the smart...
Phoned a SMART specialist today about looking at the SAM module. It is £75 to check it, plus £12 return postage. If it needs cloning it will be £375.
Also messaged someone on eBay who fixes them and they can test and repair it for £250 including postage.
Bit of a dilemma - the SMART guy said it might be SAM but could also be another electrical problem.
Car mojo has been at an all time low so decided last night to have a go at project Volvo. There are a lot of little niggles on the car which I think are not massively difficult fixes but will make huge improvements.
First on the hit list is the check straps. Both front doors flap like bloomers on the breeze, which is a bit dodgy in car parks. New check strap ordered from eBay and it has been sitting in the car for a couple of weeks.
The doors just open wide straight away
Quick YouTube check and on with job
Pop pull handle off
Trim popped off and bolts out
Original speakers which are past their best (I think they will be changed)
Cheeky little screw at the front
Speakers disconnected
There's the bad boy
It is quite broken - top is the old one and new is at bottom
(Just realised I have chucked the gaiter away - will need to rummage through the bin in a bit)
New one came with new bolts as well
The longest part of the job was fitting the strap through the hole in the door - luckily I wasn't bad at Tetris
a1ea5e9f41be2b0d197fe67ab0ca00a9.jpga6dc14798271645267f2b03a734e0af1.jpg032d828845f37c267543a5fdcf33d66e.jpg
Time for grease
All fixed.
The rear driver's door had been sticker bombed by an 8 year old, time to get the rest of them off.
The trim removal tools are good for this as don't damage the door
Little bit of alcohol to remove residue
Looks nice.
The trim for the door was hanging off
It's held on by a hidden screw
30c14563e0aa045816175788f90ff8d3.jpg394108ae1f089f10b998be1ecf4cfacd.jpg58379719b1569536b0de53420632e704.jpg
You can then slide the rubbing strip forward and off
I bent it back in, although it is missing the trim clips. They look like this
Looks ok I think
Next little jobs are trying to fix roof rail trim
You can buy these clips new on eBay at £7 each! So not sure how to fix it
Passenger door is missing it's rubbing strip and needs de funking
And need to think about wheel trims for the steels I have fitted (come with winter tyres and solved the wheel wobble) 3258318ae8603eafe17d0d06ebbe278b.jpg
Yep! they get full of dry solder joints from memory. I've repaired a few, but it's been years since the last. Get a magnifying glass and look at all the solder joints for big things like connectors, relays etc and see if there's a ring round them (google dry solder joint for good pictures) then just give it a splash of flux and a dab of some nice leaded solder. You'll need a decent soldering iron and warming the whole board up to about 70c will help too.
The Rover has been looking forlorn over last month or so.
Currently the SMART is out of action and the mx5 has developed some idle issues, with missus Puss borrowing the Volvo I thought I would see if I could work out what is up with it.
I left it in the naughty corner after the car cut out at 70mph and wouldn't restart. Easy start didn't help. Fitted new coil, charged battery and changed the fuel filter.
Back to basics and start with spark. I have a connector that sits between HT and plug which flashes when spark is received. bcd071f8f06f784f01afb812264228d6.jpg
On all the HT leads it showed nothing. Tried it with a screwdriver inserted instead and nothing with that.
Checked the king lead
Getting a spark through that, slightly yellow but looks good enough.
That means somehow the spark is going missing.
Whipped off dizzy cap and that looks clean enough 3815451d41846f25015eae0eee2fc938.jpg
The rotor arm was given a bit of a clean and checked it was spinning f43e1aa9d3b376d4e553070131b64508.jpg
All looked ok. Back together and no difference. So new dizzy cap and rotor arm ordered - perhaps the new ones are just shit.
May ask Northern Monkey to change the rotor arm as that was what started this whole issue!
Had that with my old Saab C900. Everything seemed in order, but no spark. Also driving at 60 when it just cut out.
New rota arm and sprung back into life. (After having changed\checked\swapped a load of other stuff first)
I'll keep my fingers crossed.
I will be overjoyed if it is as simple as that. Fingers crossed
New cap and arm came today.
Swapped the caps over first - easiest thing to do and less likely to screw it up
They look the same and of course no difference. Checked for spark and still no joy - it is going to king lead but no further.
So it is rotor arm next
It has a little screw to hold it on but the arm itself is very stiff on the shaft
Gently I managed to get it off and checked them together. The old is certainly worn
At this.point the heavens opened followed shortly by battery going flat.
I struggled to get the arm on so gently gave it some graphite lube and same for the shaft. Also used a little of wet and dry to clean up the shaft.
I got it mostly on but also realised that the shaft itself is actually moving in and out. Not a massive amount but did get me wondering if it just wasn't making great contact at the centre pin before causing the issue.
So plan is to charge battery, measure the length of the shaft needed to make contact with centre post and try that.
Then use fire when it doesn't work.
Bonfire night is not far away now ;)
