Fire it up. ... Moogs Motahs
On 12/9/2019 at 10:35 PM, hairnet said:
wtaf
Was that a jealous noise?
In a slightly complicated deal, I have bought back a car and then swapped that car plus another one for a Saab Aero estate with no MOT. More of that later
Part of the deal includes as set of alloys that had a few marks. Mr N Monkey helpfully suggested that I should be able to home refurb them to make then look ok.
At his garage we had a poke and then he whipped out the air sander to start getting the worst of the marks off
29ef423a9b4c061449ad27210caff5d6.jpg0950e7e8fd2e4280a52f06b0f617a9d4.jpg30ac0f9e61ca35fc5c07fc9de0a6e56b.jpg
This got quite a lot off. They had obviously bene powder coated in the past and that was where most of the marks were. 8ae148af18e8d8b73d29e3a12bf0416e.jpg1ea574f6f2d6c728dad27ed981a54440.jpg
Micra doubling up as courier wagon
Missus Puss is away this weekend so I have been using the time fruitfully. Trip to Halfords on the way home from park run sorted the bits
c34b6f09cf51fb2092a60fdf8c8c39c0.jpg32435b40d47c7a3020d9c68fb266d64e.jpg quite a comprehensive pack, also easy to use.
Also picked up lacquer and down anthracite wheel paint.
Into the garage and have a look at the wheels
Grubby and needs some work. Cleaned down with thinners to get rid of the dust and grease
Then the wheels were sanded all over with 320 grit to get rid of small marks and key the surface. 4364232f12e3d3ba067a911efe53bb1e.jpg
Bolt holes needed to be covers so the 2ps I used on BAL came in use
Primer dug out of the cupboard and ready to spray
After two coats it doesn't look bad
Second wheel got the same treatment
The second wheel had some small gouges so the filler was out into action.
The kit has a mixing board with a hardener line so you know how much to mix
Mixed and left to go off
Some sanding action got them smooth and flat
That is where I am up to. Idea is to get these two with two coats of paint on by the end of tonight. Let them cure whilst I then work on the second ones.
Overall I think they will come up ok. The kit is pretty good - £20 for everything you need.
Biggest trick is using the air sander. It got the marks our really quickly, I think by hand I would have given up!
Part two once I have got them sprayed up.
Those wheels look like they will come up nice for a relatively small investment. So does this complicated car swap deal mean the Micra is going?
Nope. I think the Micra is going to be a keeper. I love the simplicity of it all. It needs stuff doing such as 12v socket and stereo fitting but beyond that it is a lovely car.
That's nice to hear. A shitter needs a super simple, utilitarian runabout on the fleet anyway and that particular era of Micra is rather alluring. Other cars that satisfy this need and are also cool in my book are the Citroen AX and of course the Lupo!
Couple of coats of paint on
It is far from perfect but for spraying in freezing cold in a damp garage by someone who thinks good enough is the answer, they aren't bad.
5127cdbdd69712e0af519c0695c63e46.jpg5ea867fee5934558504c3cbe38f91128.jpgba77858401419a0349f23f513e4107e8.jpg
Colour was anthracite.
Will let the paint dry then PU lacquer them.
  • Like 9
fuckin oem right there
tomorrow looking v cold will it be ok spraying stuff?
I think it just takes longer to dry. Ideally if I can get the other 2 sanded and primered tomorrow, I will be happy
On 12/9/2019 at 5:13 PM, snagglepuss said:
i'm guessing Colliers Nissan
Got most of the other two wheels done today
Starting
Sanded and then filled
ac9c9efb44c974ebe96a1f336a6d4118.jpge5d69c68a6e7983f1d7709336d7f2338.jpg1276557745cabffb1f01afa7c2da97d2.jpg32dd9ddc6f8b458a5b80b13732940789.jpg59a7b3cbd82721ecd1d19a054d49a141.jpg
Not too bad
Dusted with primer
Then some top coats. It bloomin freezing which has made the paint go a bit odd but it will do I think.
Need to have a look tomorrow in the light once it has dried.
Nice wheel content, however still need more Micra photos please
Micra - bit too cold to do anything.
I did check tyre pressures as was quite heavy to drive. They were about 15 all round
As it stands
Intermittent wiper setting doesn't work
No windscreen washed
Got a new crossmember to fit
Got new front discs and pads
Needs a service
Need to sort out passenger side window
Needs tracking and balancing as wheel shake at 70+
Got to install a stereo and have a look at speakers
Need to attack bits of stone chip that have got a bit rusty
Needs a service
Needs a new parcel shelf
Ideally get another key cut
Need to source a centre cap for the wheels
Also need to get it undersealed to try and stop any rot from taking it from me!
I am loving it though. Not driven anything else since I got it!
As it stands
Needs a service
s'cuse me mista...can I av that ikkle aerial thass on the back ov ya mota plz????
(unless its already been lobbed into nearest bin??)
Starting
looks like the cosmic rays have had fun with this picture!
Dunno what happened there. Reuploaded.
I am not doing anything with it. I assume you want all the cable with it?
If it is easy to remove you can have it otherwise if it involves messing about with headlining then I can just cut the cable and take it off that way.
The wiring for the 12v socket is already behind the dash tucked up by the radio.
Also - track down a rear shelf with Nissan speakers fitted for instasnt stereo upgrade - wiring is behind the right hand carpet in the boot.
is it pre nats,the spare key i had done cost only 3 to do,due to being standard,no fancy,expensive chip jobbie,air filters cheap £2.50.crossmember not too bad to do,they can be just bolted on,as non pws versions,checked with mot man,no problem,
Thank you kind sir....I'll inbox address.. lemme know about P&P ;)
Three wheels have come out ok and 1 is a bit iffy. They are definitely ten footers, yet to put lacquer on. I didn't know how much that would cover stuff.
Ok ones
This one has got a few runs and odd spot where paint is a bit manky.
Got to decide whether to sand it back and spray it again or just live with it, as I don't care that much and they are better than was.
Also took opportunity to swap out air filter and sparkplugs on Volvo
495af6f3900e1baece8000ea09034370.jpgd5b20e809e56e38f3dc844037979c63e.jpg282d9efbfab182c5d3566f893db5c5c1.jpg
Certainly about due. Got an oil change with filter plus fuel filter to do in not too distant future.
Had ftp this morning with Micra. Turned key and nothing
Popped the bonnet
and found the positive battery terminal is loose.c796c0422f176832c3b8491b675b6e90.jpg. Took it off and cleaned it all, but it is still loose.
I assume this isn't the correct battery
The cross member is seen below
Increased sporting factor by elventy with mx5 mats6b42af06d37724142aec847ef823bc11.jpg
Stereo was dug out of the garage and slipped into place
It needed the perm live connecting to keep the setting and now we have tunes
Radio aerial doesn't seem to work but that's fine as I will always be using Bluetooth.
One of the alloys is missing a centre cap. Any idea of where to source one?
That's good to know. Binned off the old parcel shelf as it was shot. I think I might have a 12v socket knocking about somewhere
Nope it has got NATS. It's fine for now but always prefer two keys.
24 minutes ago, snagglepuss said:
That's good to know. Binned off the old parcel shelf as it was shot. I think I might have a 12v socket knocking about somewhereNope it has got NATS. It's fine for now but always prefer two keys.
Bypass the NATS by removing the steering cowel and sticking the chip with some araldite to the aerial by the ignition ( black circular affair). Then any normal key will work the car.
I did that on the Mk1 I had as only 1 key and I was a tight arse.
your c/member looks ok,is it just surface rust,or is it holed,i had to put 073 battery on mine, used 1 shop new battery clamp,im up in accy town centre,if you want free air filter,oil filter i can drop of..
17 hours ago, snagglepuss said:
Popped the bonnet
Wrap some insulating tape around the battery terminal to get the clamp to grip better.
  • Haha 3
Not sure if serious???
Use a bit of coke can or similar.
That would be ace if you do have that - very kind of you Mr Shadow.
Battery seemed happy this morning - I think a bit of a clean helped.  Thermostat needs to be changed as after 10 mins on motorway was still cold.
Cut a hole in the bonnet directly above the battery and clamp terminal with a pair of 10 inch mole grips
Problem solved?
