vulgalour Posted February 12, 2016 Posted February 12, 2016 I've never won a raffle yet and I don't plan to start now! barefoot, NorfolkNWeigh and eddyramrod 3
scaryoldcortina Posted February 12, 2016 Author Posted February 12, 2016 Right, some annoying news - the airbag light came on today. Scanner says RH Side Impact Sensor Comm fault and config fault. Autodata says "It's under the driver's seat"... Anyway, sitting on a drive all winter hasn't done it any favours and the sensor is in fact sitting in a puddle under the carpet. I've mopped it and dried off the sensor and the plug but the codes persist - ebay says £20 to replace so not too bad (some seat removal required...) Also, the pad wear warning is on, this isn't faullty, it does need front brake pads soon (est 2-3mm material remaining) and it says there is a bulb failure in the front sidelight - again it is correct, OSF sidelight is not working. I can't see how you are supposed to get at it without dismantling the whole car though.
CortinaDave Posted February 12, 2016 Posted February 12, 2016 Airbag light is almost certainly the connector under either the driver or passenger seat. They're shit. Every MG Rover is plagued by srs faults. I cut the connectors and scotch locked them to solve the problem on my old ZT. Usually happens after the seat has been moved for some reason
Bstardchild Posted February 12, 2016 Posted February 12, 2016 So just so I'm up to speed the draw is based on the bonus ball or whatever it is in the Sat night lottery draw?
scaryoldcortina Posted February 12, 2016 Author Posted February 12, 2016 Airbag light is almost certainly the connector under either the driver or passenger seat. They're shit. Every MG Rover is plagued by srs faults. I cut the connectors and scotch locked them to solve the problem on my old ZT. Usually happens after the seat has been moved for some reason Yeah, except this time it isn't. I was thinking "bet it's the seat, I moved the damn thing" while I was fetching the scanner... yay, the plenums are full of water! Driver's side was. Isn't now. Expect it to be a regular job when you win* So just so I'm up to speed the draw is based on the bonus ball or whatever it is in the Sat night lottery draw? Yep, Bonus ball on saturday.
matto Posted February 12, 2016 Posted February 12, 2016 The wet sensor/module causing those codes is certainly not unique: http://forums.mg-rover.org/mg-zt-rover-75-sponsored-rimmer-bros-90/another-airbag-fault-but-dont-think-seat-wires-288151/ replacement module seemed to fix it for that guy.
Sealtainn Posted February 12, 2016 Posted February 12, 2016 Paid, so we're good to go as I was the tardy one this time
purplebargeken Posted February 12, 2016 Posted February 12, 2016 Small hatch on the front of the inner wheel arch. Open this to get to the bulb. Good luck unless you have the hand size of a 3 year old with extra long fingers and 3 times the acceptable number of joints.
taxi paul Posted February 12, 2016 Posted February 12, 2016 To change sidelights. Turn wheel onto lock and there is an access panel inside wheel arch. Remove and pike your hand through. Also use same access panel for when the bonnet wont open and pull on bonnet wires. This info is top secret. Tam and EssDeeWon 2
scaryoldcortina Posted February 12, 2016 Author Posted February 12, 2016 Like a megane then? I'll do the bulb in the morning.
scaryoldcortina Posted February 12, 2016 Author Posted February 12, 2016 It's ok, you can negotiate with whoever is kicking themself for winning it! vulgalour, andrew e, DeeJay and 1 other 4
flat4alfa Posted February 12, 2016 Posted February 12, 2016 I'll pay £8 for a ticket eddyramrod and EssDeeWon 2
Bstardchild Posted February 13, 2016 Posted February 13, 2016 I'll pay £8 for a ticketI have two numbers 12 & 36 you can have one of them for £4 - you can pick which one
The Moog Posted February 13, 2016 Posted February 13, 2016 1 Robinmasters2 phil_lihp3 aldo1354 eddyramrod5 taxi paul6 spartacus7 loserone8 Sporty-shite9 eddyramrod (from bobthebeard)10 CortinaDave11 WilsonWilson12 bstardchild (missed earlier)13 Aldo13514 matto15 WilsonWilson16 eddyramrod17 Sporty-shite18 spartacus19 loserone20 sealtainn21 Danterzza22 The Moog23 drum24 HillmanImp25 Primerdoner26 Robinmasters27 eddyramrod (from bobthebeard)28 stephen0129 cavcraft30 Aldo13531 Gearoil32 NorfolkNWeigh33 Vulgalour (complimentary ticket)34 loserone35 WilsonWilson36 Bstardchild37 taxi paul38 eddyramrod39 barefoot40 cavcraft41 egg42 Sporty-shite43 sealtainn44 matto45 Primerdoner46 Brownnova47 Angry Sheep48 Jazoli49 CortinaDave50 DeeJay 51 Danterzza52 drum53 Jazoli54 sealtainn55 Primerdoner56 Cavcraft57 CortinaDave58 Brownniva59 NorfolkNWeigh Deejay has bought number 50 from me. DeeJay 1
DeeJay Posted February 13, 2016 Posted February 13, 2016 Whoo hoo.I can stop kicking myself now and start wetting myself instead.(With excitement).
scaryoldcortina Posted February 13, 2016 Author Posted February 13, 2016 Changed the sidelight bulb - it's a lot less fiddly than a megane, and you can actually see what you are doing (mostly - you can either see inside or reach inside) Sidelight now works. Car still has the bulb warning thing going on but doesn't say which one any more. YAY! Lacquer Peel and Cavcraft 2
Jim Bell Posted February 13, 2016 Posted February 13, 2016 I really want to win this, for some reason.
taxi paul Posted February 13, 2016 Posted February 13, 2016 Well I won the last one. Which ,despite my advice my son didn't want to do up. He bought a Volvo 850 cos it was nicer with leather and shiney bits. Said Volvo left half its engine on the M55 last night and is now a large paperweight or bird table on the garden. If I win this one I am keeping I regardless. Son keeps sending me links to Saab 9.3 2.0 ltrs now. Kids ! eddyramrod, andrew e, Cavcraft and 1 other 4
EssDeeWon Posted February 13, 2016 Posted February 13, 2016 Good luck everyone, I am being dragged out for dinner tonight because tomorrow is a big day for Clintons cards and local florists or something?? But I look forward to coming home later and continuing the romantic night with GF and checking who has won this Rover. HillmanImp and stephen01 2
sporty-shite Posted February 13, 2016 Posted February 13, 2016 I'm so excited!And I just can't hide it.
scaryoldcortina Posted February 13, 2016 Author Posted February 13, 2016 I'm about to lose control, and I think I like it.... sporty-shite 1
aldo135 Posted February 13, 2016 Posted February 13, 2016 About 9? The show is on just now. I better win after watching this drivel. Who keeps Shane Ritchie in a job?
eddyramrod Posted February 13, 2016 Posted February 13, 2016 Casualty's on at 9.20 so I reckon the draw will be about 9.15. I'll be watching the Stallone/Schwarzenegger movie on 4......
stephen01 Posted February 13, 2016 Posted February 13, 2016 I'm watching live, never mind the 32/million I'm after a 200 quid rover, bonus is I'm off all next week's so collection is easy . skattrd 1
