dollywobbler Posted December 4, 2017 Posted December 4, 2017 Empty garage? Quick! Fill it! Six-cylinder and Heidel_Kakao 2
Six-cylinder Posted December 4, 2017 Author Posted December 4, 2017 No, it had a fuel leak this morning when it was dislodged from its garage.The fuel pipe union to the carb was loose and nip solved the problem but I don't understand why sitting there for a few days should cause it to leak.
Heidel_Kakao Posted December 4, 2017 Posted December 4, 2017 but I don't understand why sitting there for a few days should cause it to leak.Because British car..... Six-cylinder 1
Six-cylinder Posted December 4, 2017 Author Posted December 4, 2017 Because British car..... That is oil that escapes at will! Heidel_Kakao 1
Heidel_Kakao Posted December 4, 2017 Posted December 4, 2017 That is oil that escapes at will!Maybe it felt like a change from leaking oil, cars get bored too you know
Six-cylinder Posted December 4, 2017 Author Posted December 4, 2017 Maybe it felt like a change from leaking oil, cars get bored too you know You are as bad as Mrs6C she thinks cars have feeling too!
Six-cylinder Posted December 4, 2017 Author Posted December 4, 2017 The reveal is simply a friend has bought over his Spitfire 1500 to change the broken rear spring and whining diff. Sigmund Fraud 1
Guest Hooli Posted December 4, 2017 Posted December 4, 2017 No, it had a fuel leak this morning when it was dislodged from its garage.The fuel pipe union to the carb was loose and nip solved the problem but I don't understand why sitting there for a few days should cause it to leak. It's self cleaning, they leak petrol to wash the oil leak off. Supernaut, Heidel_Kakao and Six-cylinder 3
Six-cylinder Posted December 4, 2017 Author Posted December 4, 2017 Progress has been good and nothing we were not expecting. When I say we, I mean Tom the owner is laying on his back with me making coffee and dispensing the odd word of wisdom that comes with mending Triumphs for nearly 40 years! DeeJay, djimbob, Exiled_Tat_Gatherer and 1 other 4
hairnet Posted December 4, 2017 Posted December 4, 2017 You are as bad as Mrs6C she thinks cars have feeling too!alfas do giulietta lonely
beko1987 Posted December 4, 2017 Posted December 4, 2017 Cars do have feelings, I can't look my old one in what's left of its face anymore as it's crying. It thought it was a normal day, then it never drove on the road again mat_the_cat and DSdriver 2
DSdriver Posted December 4, 2017 Posted December 4, 2017 On the subject of cars having feelings, if I was a back axle I expect I would whine if I was being used with a broken spring
Six-cylinder Posted December 4, 2017 Author Posted December 4, 2017 On the subject of cars having feelings, if I was a back axle I expect I would whine if I was being used with a broken spring It also has a lot of backlash but only on the drivers side? Turns out the spring is not broken just saggy and when the car was on stands on the chassis you could wriggle the end of the spring where it is bolted though the upright and rattle it.
Mrs6C Posted December 5, 2017 Posted December 5, 2017 You are as bad as Mrs6C she knows cars have feeling too!FTFY... mat_the_cat, wuvvum and DSdriver 3
Six-cylinder Posted December 5, 2017 Author Posted December 5, 2017 The Spitfire has progressed well and is mostly back together. Dick Cheeseburger and Sigmund Fraud 2
chaseracer Posted December 5, 2017 Posted December 5, 2017 I remember when I was a kid my Dad and his mate changing the rear spring on Reg's Vitesse before he chopped it in on a Renner 16TL. The seven-year-old me may have learned a few words that day! Six-cylinder 1
Six-cylinder Posted December 5, 2017 Author Posted December 5, 2017 Our "Field of Dreams" now has 8hp more! chaseracer, Supernaut, Bucketeer and 9 others 12
Six-cylinder Posted December 5, 2017 Author Posted December 5, 2017 I have been to see my friend today who is rebuilding his Riley Elf that his Grandad bought new and has always been in the family. There is a round plastic dome with 4 more modern wires to it that we cannot identify, anybody know?
Sloth in a bowl Posted December 5, 2017 Posted December 5, 2017 I can't see what the other end of the wires are attached to, but my first thought on something that size is a voltage regulator for the alternator output.
Sheefag Posted December 5, 2017 Posted December 5, 2017 Bit small for a voltage reg though, in pic 2 there's a voltage reg behind and above it. Looks a bit more like a headlight, spotlight or horn relay to me. I'd be identifying the live, disconnecting it and see what stops working.
Six-cylinder Posted December 5, 2017 Author Posted December 5, 2017 I can't see what the other end of the wires are attached to, but my first thought on something that size is a voltage regulator for the alternator output. The wires are not attached to anything at the moment. The car has always had a dynamo, which has its regulator on the same side as the mystery object.
SiC Posted December 5, 2017 Posted December 5, 2017 Cables look too thick for a horn relay. The removable lid is throwing me a bit. Maybe starter relay? Where do the wires go?
SiC Posted December 5, 2017 Posted December 5, 2017 Pop the lid off and take a few photos of the inside. All most likely become clearer Sheefag 1
Sheefag Posted December 5, 2017 Posted December 5, 2017 Some pictures of the writing on the lid would be helpful too. The cables don't look at all original to me. The removable lid wouldn't be that unusual on a period relay, it allowed you to access and clean up the contacts with a bit of emery paper. Bearing in mind the Riley was the sporting option, I wonder if it was factory wired for driving lamps?
Sheefag Posted December 5, 2017 Posted December 5, 2017 Aftermarket hazard flasher relay would also make sense. Sloth in a bowl 1
Mrs6C Posted December 6, 2017 Posted December 6, 2017 There is a round plastic dome with 4 more modern wires to it that we cannot identify, anybody know? A Happy Meal toy from Finding Nemo? Mr_Bo11ox, Mally, chaseracer and 1 other 4
Eddie Honda Posted December 6, 2017 Posted December 6, 2017 There is a round plastic dome with 4 more modern wires to it that we cannot identify, anybody know? Do not trust it - it says "Made in France" on it! Heidel_Kakao, Sigmund Fraud and somewhatfoolish 3
Guest Hooli Posted December 6, 2017 Posted December 6, 2017 Aye I'd be tracing the wires back to see where they go too. Along with not trusting frogs.
Exiled_Tat_Gatherer Posted December 6, 2017 Posted December 6, 2017 typed really long post about a similar one on the inner wing of my Trump2000 - but no help whatsoever so won't waste more of your time..... carry on.(Of course I'd be interested to find out what it is - although the 2000 is long gone)
richardmorris Posted December 6, 2017 Posted December 6, 2017 what's written on the cap? Wires look pretty heavy duty - three wires suggest a voltage regulator.
