chaseracer Posted November 5, 2022 Posted November 5, 2022 Wimp. French nuns used to ride these! Six-cylinder, wuvvum and GrumpiusMaximus 2 1
Mr Pastry Posted November 5, 2022 Posted November 5, 2022 Shite Ron, Six-cylinder and MiniMinorMk3 2 1
stendec Posted November 5, 2022 Posted November 5, 2022 French nuns aren't quite as I imagined they would be! 🤣 richardmorris, BeEP, AnnoyingPentium and 1 other 1 3
wuvvum Posted November 5, 2022 Posted November 5, 2022 They certainly didn't look like that when I lived in France.
hairnet Posted November 5, 2022 Posted November 5, 2022 1 hour ago, chaseracer said: Wimp. French nuns used to ride these! Yes. chaseracer 1
Zelandeth Posted November 5, 2022 Posted November 5, 2022 2 hours ago, Six-cylinder said: It just popped up on FB 8 miles from me. The story is it was a barn find and the engine was rebuilt 4 years and 2 owners ago. When the seller I got it from bought it 4 years ago it coughed and sputtered and he lost interest. I remember telling @hairnet I wanted one and he said that I would not catch him riding one and they were more dangerous than his big bike with all that weight over the front wheel! Very much appeals to my sense of ridiculousness and "how simple can you make something?" Bet that wouldn't be at all difficult to get running if it's been going that recently then. LightBulbFun 1
Six-cylinder Posted November 6, 2022 Author Posted November 6, 2022 16 hours ago, Zelandeth said: Very much appeals to my sense of ridiculousness and "how simple can you make something?" Bet that wouldn't be at all difficult to get running if it's been going that recently then. Test pilot with his own crash helmet needed here!
Six-cylinder Posted November 6, 2022 Author Posted November 6, 2022 My trip to Milton Keynes with the XM went well in spite of the grey damp weather. I rather like this Kia Stinger 362bhp. Dyslexic Viking, MiniMinorMk3, RayMK and 7 others 10
grogee Posted November 6, 2022 Posted November 6, 2022 I like the 'Faster Than Light' Cavalier. Very Luton.
hairnet Posted November 6, 2022 Posted November 6, 2022 nice calibre roads in sussex were doing a rufford ford today but it was far too far away to come up from here sadly
stendec Posted November 6, 2022 Posted November 6, 2022 Much want for the Bond and Citroën Six-cylinder 1
hairnet Posted November 6, 2022 Posted November 6, 2022 3 hours ago, Six-cylinder said: Test pilot with his own crash helmet needed here! no evel knievel says no also Six-cylinder 1
Six-cylinder Posted November 6, 2022 Author Posted November 6, 2022 What have I bought? I bought this as a 1969 Velosolex S3800, but now I look on line feel it might not be. When I get it running how do you switch it off? Also what is the plastic tube thing that was loose under the topcover? LightBulbFun 1
RayMK Posted November 6, 2022 Posted November 6, 2022 A fellow pupil at Queens School, Rheindahlen had one. He just stalled it on the brake whereas my posh Peugeot BBCT had a decompression lever, as did a girl's Batavus. The Solex guy also had a lever which raised the engine and friction wheel off the front tyre. He tried to use said lever as a clutch when in stop start conditions but the engine still required pedal assistance unless facing downhill. Six-cylinder 1
Six-cylinder Posted November 6, 2022 Author Posted November 6, 2022 10 minutes ago, RayMK said: A fellow pupil at Queens School, Rheindahlen had one. He just stalled it on the brake whereas my posh Peugeot BBCT had a decompression lever, as did a girl's Batavus. The Solex guy also had a lever which raised the engine and friction wheel off the front tyre. He tried to use said lever as a clutch when in stop start conditions but the engine still required pedal assistance unless facing downhill. Mine has a decompression lever so I guess that will work fine to stop the engine. RayMK 1
Mr Pastry Posted November 6, 2022 Posted November 6, 2022 On 11/6/2022 at 9:19 PM, Six-cylinder said: What have I bought? I bought this as a 1969 Velosolex S3800, but now I look on line feel it might not be. When I get it running how do you switch it off? Also what is the plastic tube thing that was loose under the topcover? It is definitely a 5000, so a bit later than 1969. Same 49cc engine as the 3800, hence number on casting. IIRC there is a stamped engine number which will date it - not sure they had frame numbers until later. Possibly on the crank case at the base of the cylinder. The loose bit is a fuel filter, but I can't remember how it fits! The ignition is permanently live, and you stop the engine with the decompressor. Note also choke/"start" lever at rear of carb. There is an automatic clutch which will disengage the drive at idling speed. The fuel system is interesting. The fuel is pumped up to the main jet by a diaphragm pump, which is operated by crankcase pressure. There is no float chamber and surplus fuel flows back to the tank through the large plastic pipe. Almost fuel injection! Dirt in fuel/fuel pipes or damaged pump diaphragm are likely problems. I have a flywheel extractor, should you need to look at the points - the gap is quite critical as it controls the ignition timing. GrumpiusMaximus, Six-cylinder, RayMK and 1 other 4
wuvvum Posted November 7, 2022 Posted November 7, 2022 Permanently live ignition and decompressor to stop the engine was pretty standard on French mopeds for a long time - my Mobylette had that arrangement originally, although since I fitted the engine from a later electronic ignition bike it now has a kill switch instead. Six-cylinder 1
Weird Car Posted November 9, 2022 Posted November 9, 2022 Definitely a decompression lever to cut the engine, I had a 3800 a few years ago, i had to get rid of it due to it being absolutely terrifying on the road, and that’s coming from someone whose owned 2 Invacars lol LightBulbFun, Mr Pastry, AnnoyingPentium and 1 other 4
Mr Pastry Posted November 9, 2022 Posted November 9, 2022 The 3800, or some of them anyway, had another interesting* feature whereby the front brake lever also operated the throttle.
Weird Car Posted November 9, 2022 Posted November 9, 2022 6 minutes ago, Mr Pastry said: The 3800, or some of them anyway, had another interesting* feature whereby the front brake lever also operated the throttle. Yes mine had that but i hand built a separate hand throttle for it operated via a small lever on the bars, it worked a bit like a choke lever on a Honda Express. Mr Pastry 1
Mr Pastry Posted November 10, 2022 Posted November 10, 2022 I put a separate throttle trigger on mine, but I'm not sure it was a great improvement, and all the later ones had normal twist grips. Thinking again about the fuel filter, I think it just drops into the top of the carburettor, and is retained by the air filter assembly. There is another similar fuel filter in the bottom of the tank.
Six-cylinder Posted November 10, 2022 Author Posted November 10, 2022 Our 200TE has bust a metal pipe on the SLS (Self Levelling Suspension). I should add Mrs6C was driving it at the time! GoGently 1
wuvvum Posted November 10, 2022 Posted November 10, 2022 51 minutes ago, Six-cylinder said: I should add Mrs6C was driving it at the time! Was it carrying many tonnes of narrow gauge rolling stock at the time?
Six-cylinder Posted November 10, 2022 Author Posted November 10, 2022 11 minutes ago, wuvvum said: Was it carrying many tonnes of narrow gauge rolling stock at the time? 7 1/4 inch!
Mrs6C Posted November 10, 2022 Posted November 10, 2022 This lot! CaptainBoom, wuvvum, LightBulbFun and 4 others 7
High Jetter Posted November 10, 2022 Posted November 10, 2022 Phew, at least it wasn't a weight issue anonymous user, wuvvum and stendec 1 2
Paul-l Posted November 11, 2022 Posted November 11, 2022 On 11/6/2022 at 9:19 PM, Six-cylinder said: When I get it running how do you switch it off? Also what is the plastic tube thing that was loose under the topcover Decompressor lever to stop, the clutch is centrifugal so you can’t stall it (or shouldn’t be able to) the plastic tube is the carb fuel return - there’s no float bowl, instead the pump pumps continually with the excess fuel weiring over into the large return pipe. 30 mph is doable down a steep hill, 40 if you lift the engine off the wheel! But generally 18 or so on the flat Six-cylinder 1
Six-cylinder Posted November 12, 2022 Author Posted November 12, 2022 This evening low strong sun showed the out line of an old sticker on our XM. M & M Citroen 01484 687706 They still show as a a garage in Holmbridge with that phone number. Were they ever a Citroen dealer? Floatylight and LightBulbFun 2
Six-cylinder Posted November 12, 2022 Author Posted November 12, 2022 Mid November and the weather is lovely but soon winter will be with us. What a good time to be donated a roller shutter door for the FoD and it was delivered today. A chance to play with the JCB. Back in May 2018 I bought a 2.5 six cylinder Triumph engine with the view to fitting it to my Vitesse from my favourite garage. A while ago I was asked if I sell it back as now the car it came from is being restored. Rather than take my money back I have requested an IOU for a Triumph engine when I am ready for one. I had to move out the BMW E3 to get the engine out of the garage and it started well and and drove fine. When I have done the Saab V4 engine I will get back to wire brushing the rust bubbles and apply rust killer. Floatylight, richardmorris, mk2_craig and 9 others 12
