Six Cylinders Motoring Notes - I have never seen this before!
Regards the above, my last MX5 also had a habit of emptying its expansion tank for reasons unknown.
Next FoD meet is looking questionable for me at the moment with my work rota. I'd love to be there and will strive to do so but likelihood is currently low.
  • Six-cylinder changed the title to Six Cylinders Motoring Notes - Next FoD weekend 10th 11th July.
The Mini is having a ride of shame!
  • Sad 3
I had to move a couple of cars around in storage. The Chrysler Sebring started on the button with a jump while the BiTurbo took a bit of churning.
Expand
Were you rallying the Maserati? It looks covered in mud.
Expand
It was MOTed upto Nov 2020 but I can't remember using it last year during lockdown so I guess that is Nov 2019 mud when I have a photo of it out and about.
Liking that Mini a lot!  I'll put my name down as a potential for 10th-11th if that's OK, will be in my camper.
Expand
So probably structural mud by now then...
  • Haha 4
Expand
Hope the clutch on that one is better than ians!
I'd love to come. Anyone want to look at a shonky 2002 Jaguar S-Type?
I also own a big tent
Edit: the limitation is that that is the weekend before my brother gets married so I might have to run around helping with preparations. If not, I'm in for sure
Expand
Of course we would like to see your S-Type.
It is the lovely thing about Autoshite that all shapes and sizes of cars are welcome.
Expand
A great, welcoming community for sure!
If a bring my Volvo 740  saloon with the hanging headlining will some one like looking at it enough to help me get it out so I can get some new fabric on, do you think?
Expand
staple gun
Coil Sprung and Water tight*
Driving this big bug has allowed me to answer a question i had wondered.
The "new" beetle was it SHIT?
Overall, not really. Windscreen to driving position feels odd at first and makes the car feel massive.  Seats feel quite upright but everything seems to fall to hand quite nicely . The handling and power are all very neutral but not so much in a bad way,  if you take it for what it is and drive normally id say its a fairly relaxed place to be and rather quiet.
Roof down  with the flower blowing in the breeze it feels a bit weird, as it really highlights how far back from the screen you are, i feel with all the windows down and the pillarless doors makes for a nicer place to be.
*the rear window is anyway.
Expand
Dealing with sagging headlining is a hard job and I am not aware of anybody who readily has the skills.
Try this video in case you think you can tackle it yourself and then I have several for you to do!
  On 05/06/2021 at 20:53, hairnet said:
staple gun
Expand
Cling film might be better
Expand
He cuts it in two!
I did wonder about simply lowering the front seats and disattaching the lining board but leaving it in the car and recovering it in the car while the board is loose.
Is this utter madness?
Expand
But you have stolen all the dirt that I carefully built up on it!
Thank you so much for all you have done for it.
  On 05/06/2021 at 21:03, Tim_E said:
He cuts it in two!
Expand
My guess is trying to glue the new headlining evenly to the board is going to be very very difficult within the confines of the car.
The rear window then, it had become detached from the hood and was hanging on one side. When i looked at it at FOD id found a sheared bolt/ stud from a swivel joint being seized up.
Peeling the remaining bit of roof away from the glass ment i could now pull the window out the car. I then drilled off the rivets holding the swivel part on.
Im sure you can buy this part but after a bit of a soak in some oil and some love taps i got the swivel to errr swivel and as i have a welder some fiddly tack welds would surfice,  it was a case of tack then lob it in a jar of cold water to not melt its bracket.
Re riveted to the frame and bothe swivels packed with copperslip.
Over a couple of evenings i bonded the screen to the roof material in sections top, bottom then the sides using mannol windscreen bond.  I couldnt do it in one as it kept moving around.
After it all dried i trimmed off any blobby bits and smearing, masked up with a sort of 6 mm gap rouund the edge and ran a bead round that i then smeared with my finger to push into any gaps and also to hide any lumps and bumps. Some thinners on a rag got the old gaffa tape residue off
Whip the tape off and it looks alright.
Buggin' me
After realising id have to glue the window in stages i had some time to kill,
The rather large veeee dubbbyaa on the front was looking very tired from a stone battering.
The paint on the car is  actually rather tidy so lets do something about that badge letting the front down
Some 3000 grit, satin black , leftover clear laquer and some steady masking .  Perfect? No but Much better.
Little things, big difference.
Expand
You are amazing!
Strut ya stuff,
The familiar sound of a broken spring required the front shock to come off,
With the beetles wee bonnet the struts are under the scuttle panel.  with the n.s having been replaced sometime recently i noted some odd chopping had been done!
At first i thought savages! Then i thought hold up, theres got to be a reason here as cutting it would be far more work that simply pulling it off. Indeed they were right. It feels as if the trims bonded on maybe from a new screen at some point.  It wouldnt budge
I thought id cut the other side but this would have taken ages. So some eyeballing and a step cutter drill and we have access for a 1/2" extension and some ugga dugga action .A rubber bung in after and shes almost factree.
No further pics as the following repairs involved a spinning track rod end and spring compressor shenanigans.  Jobs that really dont want to be remembered in pictures!
  On 05/06/2021 at 22:07, hairnet said:
chris is happy now
he can be a tart again :D
Expand
But this is what I wanted 543 bhp and 205 mph!
chris is happy now
Expand
Jam or lemon-curd?
staple gun
Expand
Drawing pins! A Citroen traction I have seen has a sort of mock Tudor plywood roof slats .
