Shite in Miniature II
  On 06/03/2024 at 18:50, bunglebus said:
That looks like it's reacted to a chemical.
I'd try polishing it first, but if it's inside and out that'll be hard.
Next trick would be the old floor polish dip, and lastly I'd try spraying it with clear lacquer - fair chance that will react too though - I tried a bit of tinting spray on a yellow Hot Wheels glass unit and it ruined it completely
Hot Wheels Volvo Drift wagon custom
Does it look clear when it's wet? If not I'd say it's game over
Expand
No, if it’s wet it still looks opaque.
I don’t suppose there’s anything left to lose by polishing it!?
  On 06/03/2024 at 19:46, quicksilver said:
That looks like a particularly bad case of UV degradation. Some clear plastics seem prone to it and the cloudiness goes right through the plastic so I don't think it can be polished out. I haven't seen any suggestions that it's repairable unfortunately.
Expand
There’s a little bit of the same cloudiness on the sides of the headlights too so I bet it’s been sat somewhere in full sun for a long time.
I reckon the paint inside the rear window was some effort to try and fix it or disguise it as tinting.
I’ll try a good polish and see what happens. It can’t hurt it anymore. I’ll have to make something or adapt something if it comes to it.
Yup, as others have said, that's UV light damage alright.
The model shop I used to work at kept display models in the window, and for slow-selling lines, after a year or two the glazing would go that same milky white all the way through.
Very annoying - generally they'd then get sold off cheap, probably for parts. Vanguards and Oxfords seemed particularly susceptible.
Lovely big model all the same!
Cheers fella’s. I’ll see what’s what tomorrow and have a go but it sounds like the glazing at least is toast. Shame, but hey ho!
might have found at least a potential solution. If it fits. It’ll take a while before it arrives though so I’ll continue stripping the Jaaaaaaaaaag, then see if I can cobble something together to replace the windows.
If nothing else the old windows will make a pattern for cutting new from plastic sheet, or my idea of a fix will work. On of the two!
I fancied doing a custom mk10 when I got the mint boxed one last year but I’m not stripping that one! In a way this one’s ideal for that now.
Friend of mine had some photoshops of a 2 Dr pillarless coupe mk10 that looked really good.
I remember back in the '80s there was a conversion kit for a convertible Mk10. Can't remember who it was by but the cars were worth nowt then so not sure how many were converted.
Might be an option to do a replica model perhaps ?
UT Models E46 BMWs were particularly prone to the milky windows and for a relatively complex model, there was no solution unfortunately. Mine is well out of the sun but sadly that means it's not very prominent on my shelves either which is a shame.
Expand
You can get a Matrix (mega £££) model of the soft top.
https://www.ebay.co.uk/itm/404062746371?itmmeta=01HRC4FH5A1SPN36MW7YZJ3CKN&hash=item5e14043703:g:HKAAAOSwObZj661e&itmprp=enc%3AAQAIAAAA4G0GhBPPaEGMmjYIyFMa%2BpF4CkvssdpfbVzK2NNG%2Fdwn7kD1%2BlvxhQKgry%2BrdrmawguXbVArGqisOdyKth%2BJ7Ct0nJZDoKRK3IA%2B9jFWY9%2BGOu5fCUyF5qDXMsffb6yrBLi3OQsqRWRDxE1%2FrFtmWtaZuLz3VxcvdbGJ7olqj610waSa19YJQDrs5AOp4ARaHh11UXQCndnQbJsahUyY%2Fn80N9ie53tz17yAkLd6maiLC88vhVaz5I02id8bk99UikfeJZ9M8GBQ0b%2B8n06%2FVuvv0jpdevrD14Nq2wh4KHun|tkp%3ABFBM4JK-hMNj
Expand
It is ridiculous really that it’d be a problem. For what it’d cost you’d think they’d use a UV stable type of plastic.
What I find even more baffling is that this UV/sun damage is a problem at all in the UK!! There’s probably only about two days of the year we see the sun!😄
  • Agree 1
I think that's the problem though, cloud cover will block out visible light but not UV light! For the models stuck in the window of McCulloughs right on the seafront, every day was a sunny day from dawn til dusk, from a chemical degradation standpoint anyway.
Found a pic from a few years back of an EFE Leyland Atlantean that was similarly afflicted, at the front at least.
Expand
Greater Glasgow PTE livery! I'd have loved that one as I have the same bus on an earlier livery and I also made my own orange and black 'Strathclyde's Buses' livery.
Well, it’s bollocks’d!! No amount of polishing or cutting compound will make a difference sadly. But that’s probably not unexpected really.
I’ve ordered a Spot-On Jaguar S type replacement glazing unit from Mr Flowers, which obviously isn’t going to fit, but it might be adaptable for at least the front and rear screens? We’ll see when it arrives. Failing that, I could probably use the original glazing as a pattern and cut new from clear plastic then bend to shape with a bit of heat. There will be a solution I’m sure.
I could do a convertible, but tbh, I’m no fan of soft tops, real or model. Don’t know why but they just never look as good as a tin top!
I’ll carry on with it though and see what I can come up with.
  • Sad 2
Popped back into the toy shop, got a sneaky pic through the door
It's crazy mix of stuff from model kits to NOS Corgi and Matchbox, tat box level oldies, Marvel stuff - all sorts
I saw this in there yesterday and kept thinking about it
  • Like 6
Expand
Make it into a banger racer, then you won't need any glazing.
  • Haha 3
Expand
I remember a toy shop that was on Hastings sea front that had yellow film on the windows in an attempt to stop the damaging effects of 1960s sunlight. I always thought it must of come from a big Lucazade bottle.
Expand
Heh, yes I remember those too! There was an old haberdashery up the top of High St which had the same crinkly-looking brown celluloid-type blinds right up until it closed in the mid-2000s. I assumed it was some sort of anti-fade device - and it seemed to work, because there was stuff in the window that was probably from the 1940s.
McCulloughs had a large pull-out awning that covered half the shop frontage and kept the light levels low for the nursery goods in the window, but not the models window on the right for some reason.
I had a few Britain’s toys that I kept in the window as a kid and they basically disintegrated after several years as the plastic faded and became brittle.
Aye. Sunlight is no friend to toys.
I had some Matchbox playtrack I'd been handed down by my older cousin, which lived in a basket in our playshed - this flexible plastic stuff:
Vintage Matchbox 1978 Play Track PL-1 Fully Complete. Damaged Box Free Postage! - Picture 1 of 8
There was a window in the shed, and as the sun moved round the garden throughout the day, a shaft of light beamed across the shelves.
One day I went to fetch the playtrack - having not bothered with it for a while - and the flexible pieces just broke up as I touched them. Seems that the UV in the sunlight just degraded it to the point it all turned brittle (the same thing happened to the plastic basket it was in).
It probably all went in the bin, which is annoying as now I think about it the little plastic shops and houses were probably alright!
Expand
No it isn't
Matchbox VW Transporter Ambulance Graffic Traffic Matchbox VW Transporter Ambulance Graffic Traffic resto
But hydrogen peroxide is brilliant stuff - doesn't undo the reduction in flexibility though. I have had to repair this as it broke removing it, but you'd be hard pressed to tell.
One day I might get the body painted!
Expand
My kids have that one, wife picked it up on Facebook Marketplace for a fiver a few years back. Wasn’t the track rebranded from something else?
Expand
Didn't know that, but quite possibly - I think there were always a few of Lesney's lines that were made for them by another firm and rebranded.
The Matchbox Motorway system was a German-built toy repackaged under licence, I think?
Matchbox Motorway extension set. | Matchbox, Model cars collection ...
The playtrack had a long old life - I think it was recoloured grey for the 1980s, and continued on into the 1990s under the Motor City banner.
This has been in my eBay watchlist for way too long... I sold mine, still in its box, for like £5 at a car boot sale.
Picture 2 of 9
Regrets, hey?
I can't remember what colour track I had but that stripey stuff does look familiar. I have a strong memory of there being red plastic clamps to attach the start to the dining room table, creating lots of speed for the loop-the-loop at the bottom before the cars went through the gates and crashing into the fireplace.
Aha
My parents clearly didn't love me, or they'd have bought this instead
That explains where my Corvette came from then
Matchbox Superfast 62 Chevrolet Corvette
I've no doubt my set came either from the jumble sale or my older cousin, so I wouldn't have had a lot of choice either way!
Expand
@Split_Pin must love me as he sent me one! It’s ace, had it out a few times to test it. I had in circa 1994 the Rapid Shot track which was similar, anyone remember that?
I might have done my parents a disservice there, as I definitely had twin loops and a finish gate, so S-400 it was - now I remember the cars on the box too, definitely this first pic
Memory unlocked
I had a load of this stuff,
https://www.meccanoindex.co.uk/Other/Kenner/CV-Bridge-4-Plan.pdf
It was originally my uncles from new, but was passed down. The original box must have fallen to bits yonks ago so my grandad made a big plywood box with loads of little sections inside for all the different parts.
There was absolutely shit loads of it though. You got loads of different girders and braces to build the bridges and buildings then the building faces and road surfaces would clip to them, or just lay on the floor.
It was a fantastic system and you could just run your matchbox and corgi toys on it.
No idea where it went though. I could have sworn blind it was still up in the loft but clearing out to move last year I didn’t find it, so god knows where it went.
Expand
20191113_135209.thumb.jpg.f10b2b667b9860a2484cd5930ce111f1.jpg20191113_135218.thumb.jpg.75478ba1ab81695e4d39c6723170395c.jpg20191113_135428.thumb.jpg.98b4ad8c52ea232883a9f3dd70cced04.jpg
I've got this knock off set if you're interested?
Expand
It was a classic Jag specialist in Hinckley, always had half a page ad in T&CC. I think he made the Nazi Staff cars used in Raiders of the Lost Ark  out of butchered MK10s too.
  • Agree 2
I had this... they also did one with a mould for you to cast an ice screen for the car to blast through which seemed unbelievably cool at the time. image.jpeg.977944b8801dc5b024bfe5dd56023c6d.jpeg
