Dave_Q Posted February 27, 2024 Posted February 27, 2024 It's which side the grooves are on relative to the pointy bits of the keys. I can't see a difference between SKO 1 and 2 either. These blanks are like £1 each + post to me so if you want I can order you a couple of each for £10 or so. I can't cut them to code/picture though as my app doesn't recognize that pre-VAG Skoda existed but I reckon a local place should have no problem copying them. Send me a message if you want me to get some ordered for you. wesacosa 1
wesacosa Posted February 27, 2024 Author Posted February 27, 2024 1 hour ago, Dave_Q said: It's which side the grooves are on relative to the pointy bits of the keys. I can't see a difference between SKO 1 and 2 either. These blanks are like £1 each + post to me so if you want I can order you a couple of each for £10 or so. I can't cut them to code/picture though as my app doesn't recognize that pre-VAG Skoda existed but I reckon a local place should have no problem copying them. Send me a message if you want me to get some ordered for you. thanks Dave. I do remember someone on the Skoda forum mentioning there were different lengths so I wonder if 1 and 2 are slightly different lengths
Dave_Q Posted February 27, 2024 Posted February 27, 2024 You're right: Not sure where those lengths are measured from but hopefully one makes sense for your key. wesacosa 1
wesacosa Posted February 27, 2024 Author Posted February 27, 2024 34 minutes ago, Dave_Q said: You're right: Not sure where those lengths are measured from but hopefully one makes sense for your key. thanks I will take a look Do you think we can rule out sko8 or is that still a possibility?
Dave_Q Posted February 27, 2024 Posted February 27, 2024 1 minute ago, wesacosa said: thanks I will take a look Do you think we can rule out sko8 or is that still a possibility? SKO8 has the grooves on the other side of the key so can be ruled out. wesacosa 1
High Jetter Posted February 27, 2024 Posted February 27, 2024 3 hours ago, Dave_Q said: Not sure where those lengths are measured from but hopefully one makes sense for your key. According to the graphic above the key Nos. the profile appears to be different. Dredging my memory from long- past key cutting days the length is from the tip of the blade to the 90-degree stop nearest to the tip. Dave_Q 1
wesacosa Posted February 27, 2024 Author Posted February 27, 2024 2 hours ago, High Jetter said: According to the graphic above the key Nos. the profile appears to be different. Dredging my memory from long- past key cutting days the length is from the tip of the blade to the 90-degree stop nearest to the tip. ha I didn't even notice what those graphics were !
wesacosa Posted March 16, 2024 Author Posted March 16, 2024 someone bought this about 6 months before I bought mine Seeing it now on FB I feel both inspired and wholly inadequate at the same time 😂 LightBulbFun, SiC, Shep Shepherd and 12 others 14 1
Bazfr69 Posted March 16, 2024 Posted March 16, 2024 I’ve just started following this chap on instagram, awesome motor. wesacosa 1
wesacosa Posted March 16, 2024 Author Posted March 16, 2024 40 minutes ago, Bazfr69 said: I’ve just started following this chap on instagram, awesome motor. I know the guy, he's done a cracking job on it. He was at Rustival last weekend in it, I bought a spare carb and electronic conversion off him Bazfr69 1
brownnova Posted March 16, 2024 Posted March 16, 2024 58 minutes ago, wesacosa said: Seeing it now on FB I feel both inspired and wholly inadequate at the same time 😂 I get exactly the same, especially when I see restored Yugos… Rust Collector, wesacosa and tooSavvy 1 2
Bazfr69 Posted March 16, 2024 Posted March 16, 2024 2 hours ago, wesacosa said: I know the guy, he's done a cracking job on it. He was at Rustival last weekend in it, I bought a spare carb and electronic conversion off him I found his page when someone linked to it from the Dull Man fb group and I’m glad I did. wesacosa 1
wesacosa Posted March 17, 2024 Author Posted March 17, 2024 since I downed tools on the Estelle in August its sprung some heavy leaks into the cabin, not sure if its because I have the front jacked up but its getting to be pain bailing it out every time it rains, especially given the crap weather so I thought I'd take a look First source of leaks I noticed was the sunroof, so that was duly taped up until further notice, but it barely made a difference. I had been told the seal around the heater unit was a prime source of trouble but it looked ok, I might whip it out anyway whilst coolant is drained as the fan motor is temperamental and I can inspect the heater matrix I mentioned it to the owner of the beige one @Bazfr69 showed above when speaking with him at Rustival and he mentioned he had huge issues on his with the grommet where the heater unit bleed hose passes through the bulkhead and through the luggage compartment to the radiator. I had replaced that hose recently so it popped up to the top of the suspect list, especially as the water did seem to be running through the transmission tunnel close to the heater (because the car is on ramps its pools at the rear seat mounts on the floor pan) I taped that up last week and after the heavy rain the last few days the trans tunnel and passenger side rear where it pooled was dry. Getting there now. There is still a small amount of water pooling in the drivers side rear, it seems to be running down the floor pan channels. hunting around I found a small drop on a seam around the pedal box I had been focusing on the scuttle, sunroof, window and doors but this was not in their path attention focused to the luggage compartment, bingo its seeping through the seems on the pedestal which the master cylinders and servo attach Taped up so fingers crossed the next rain shower leaves a dry interior and I will know I have identified all the sources What I am not yet sure is how the water is getting into the luggage compartment. I noticed a dent in one part of the boot seal close by, as if something had snagged there when boot was closed, so I built that up with tape. However it's also wet under the boot liner in other places where I can't see obvious damage to the seal, I wonder if because the front is raised the heavy rain leads to a puddle forming that then breaches the seal somewhere. Either way I will look at getting a new boot seal and see what happens RayMK, Rust Collector, Bazfr69 and 1 other 4
Bazfr69 Posted March 17, 2024 Posted March 17, 2024 Chasing a leak is a bloody nightmare. I count my blessings that I have a carport, if not a sexy Estelle to put in it. wesacosa 1
wesacosa Posted March 17, 2024 Author Posted March 17, 2024 yes indeed. I really hope I have them all pinpointed now. Helps that the interior was already removed to sort the first leak I found (heater hoses)
2flags Posted March 17, 2024 Posted March 17, 2024 Water leaks are a pain! I remember one lad telling me that they had a customer complain he had his boot filling with water. The foreman simply remover a bung in the boot floor. 'There you go sir, the water now has a way out! wesacosa and High Jetter 2
wesacosa Posted March 17, 2024 Author Posted March 17, 2024 28 minutes ago, 2flags said: Water leaks are a pain! I remember one lad telling me that they had a customer complain he had his boot filling with water. The foreman simply remover a bung in the boot floor. 'There you go sir, the water now has a way out! previous owner of my Favorit got fed up of the spare wheel well filling with water so just drilled a hole in it Rust Collector 1
Rust Collector Posted March 17, 2024 Posted March 17, 2024 1 hour ago, wesacosa said: previous owner of my Favorit got fed up of the spare wheel well filling with water so just drilled a hole in it I’ve done this with my Audi 100. Looked like too much of a pain in the arse to bail out the water compared to drilling a small hole from underneath 😂 If I ever get round to sorting it to the point of making it watertight then it’ll get a rubber bung, until then it’s sorted*. wesacosa 1
tooSavvy Posted March 18, 2024 Posted March 18, 2024 On 16/03/2024 at 11:25, brownnova said: I get exactly the same, especially when I see restored Yugos… When I see BMW powered imps I get a yen for my Pocket Rocket...rip 884KOE. 🚙💨
wesacosa Posted April 10, 2024 Author Posted April 10, 2024 No wonder finding the key blanks was a stuggle @Dave_Q These are the different ones used over the years on the Estelle with seemingly no obvious way of knowing which you have other than looking
stuboy Posted April 10, 2024 Posted April 10, 2024 10 hours ago, wesacosa said: No wonder finding the key blanks was a stuggle @Dave_Q These are the different ones used over the years on the Estelle with seemingly no obvious way of knowing which you have other than looking bloody 'ell
