54 minutes ago, sierraman said:
Is that a proper Ford colour? I’ve always wondered?
I dunno but there's another one at Gaydon Motor Museum.
There's loads of great exhibits there, but the green Capri is just... meh
8 hours ago, Dick Cheeseburger said:
That is one hell of a find. Chevanne survivors must be in single digits, surely?
There can't be many left, I think I've only seen 1 in the last 30 years or so.
  • Agree 1
There was lemans green in the early 70s , but not then.
the one in Gaydon is the actual one from the show (well technically the second one used in the show, as the first episode it features in is actually a mk2 Capri)
Yes.
37 minutes ago, Low ontime said:
Signal green?
Maybe, my memory of the Holts colour chart has...faded.
Not signal green ( a rare/unpopular colour & I think  with signal yellow reserved for "S" models) think the MK2  (UYD was a G or M suffix in Somerset) was painted specifically in a bright green for the show, the MK3 was probably genuine ford highland green as it changed during 81 to peppermint green & (CCA was only issued with an S or X suffix by Cheshire ) so both are false plates ,it's possibly 2 different mk3s or maybe just the pics, as several reliants were used over the years.
https://www.ebay.co.uk/itm/326926811611
Quote
Nearside Front Position lamp not working (4.2.1 (a) (ii))
Offside Front Anti-roll bar linkage ball joint excessively worn (5.3.4 (a) (i))
Offside Front Lower Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting under sill area, large area (6.2.2 (d) (i))
Nearside Front Lower Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting under sill area (6.2.2 (d) (i))
Offside Front Lower Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting chassis railing and its surroundings area (6.2.2 (d) (i))
Nearside Front Lower Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting chassis railing and its surroundings areas (6.2.2 (d) (i))
Offside Rear Upper Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting under wheel arch area, covering large section (6.2.2 (d) (i))
Nearside Rear Upper Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting under outer wheel arch area, large section (6.2.2 (d) (i))
Rear Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced front crossmember (6.1.1 (c) (i))
Rear Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced central crossmember (6.1.1 (c) (i))
Nearside Rear Lower Suspension component mounting prescribed area excessively corroded significantly reducing structural strength central chassis railing (5.3.6 (a) (i))
Nearside Rear Upper Suspension component mounting prescribed area excessively corroded significantly reducing structural strength chissis railing (5.3.6 (a) (i))
Nearside Rear Lower Vehicle structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting under sill and wheel arch area (6.2.2 (d) (i))
Nearside Rear Seat belt anchorage prescribed area strength or continuity significantly reduced under wheel arch area (7.1.1 (a) (i))
Offside Rear Seat belt anchorage prescribed area strength or continuity significantly reduced under wheel arch area (7.1.1 (a) (i))
Brake performance unable to be tested due to excessive corrosions (1.2.1 (g))
Offside Rear Lower Vehicle structure or chassis corroded within 30cm of a mounting, but not seriously affecting overall security under sill area (6.2.2 (d) (i))
Front Coil spring corroded both front (5.3.1 (b) (i))
Rear Coil spring corroded both rear (5.3.1 (b) (i))
Offside Front Upper Suspension component mounting prescribed area is corroded but not considered excessive under wheel arch (5.3.6 (a) (i))
Nearside Front Upper Suspension spring mounting prescribed area is corroded but not considered excessive under wheel arch (5.3.6 (a) (i))
Front Brake pipe corroded, covered in grease or other material all (1.1.11 (c))
Rear Brake pipe corroded, covered in grease or other material all (1.1.11 (c))
Doubtful that this will see the road again with a legit MOT
3 hours ago, Knotty Ash Towers said:
That is ace, obviously. I never realised how tall the instrument binnacle is. It looks like I'd struggle to see the road ahead over the top of it, judging by the seat position.
