13 minutes ago, Danterzza said:
You think he'd at least asked one of his team to flick the Dyson over it, wouldn't you? Fame's clearly gone to his head, dirty swine.
Interesting fungal growth on those seats.
Once the spores have spread, they'll  just keep on coming back. Dyson won't cut it - that's going to need fungicide and fumigation.
I recommend fire.
Spears or Rapier BMW 330 Wagon. Looks Ok, been to the moon, lots of work done.  Image 51 - Bmw 330d
Quote
Selling my old faithfull as I don't have the time to get it mot'd
O RLY? | XSp.
Quote
Date tested27 October 2020
FAIL
View test certificate
Mileage209,481 miles
MOT test number2129 0013 1074
Test location
View test location
  • Offside Front Headlamp aim too high (4.1.2 (a))
  • Offside Rear Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced (6.1.1 (c) (i))
  • Front Inner Track rod end ball joint has excessive play both front inner tie rods (2.1.3 (b) (i))
  • Front Inner Suspension arm pin or bush excessively worn both sides front suspension arms rear bushes (5.3.4 (a) (i))
  • Front Registration plate deteriorated but not likely to be misread (0.1 (b))
  • Front Headlamp has a product on the lens but not seriously reducing light output both sides (4.1.4 (b))
  • Rear Brake disc worn, pitted or scored, but not seriously weakened both sides (1.1.14 (a) (ii))
  • Coolant leak pipe on front of engine ()
  • Oil leak, but not excessive (8.4.1 (a) (i))
  • Oil leak, but not excessive back of the gearbox (8.4.1 (a) (i))
  • Rear Subframe mounting prescribed area is corroded but not considered excessive (5.3.6 (a) (i))
Lying bellend.
https://www.ebay.co.uk/itm/Bmw-330d/154399043319?hash=item23f2e66ef7:g:HCUAAOSwqAFgUINX
An early contender for the Autoshite Most Pogweaseled  Paint award.  In Bideford BIN £280 currently £50RNM. To be fair it's lasted pretty well for a "seaside" car. Badermatic, only 77k.
https://www.ebay.co.uk/itm/Nissan-Sunny-1600-SLX-Auto-77000-miles/224416376847?hash=item344042280f:g:TBYAAOSwoSNgXfRm
Image 1 - Nissan Sunny 1600 SLX Auto 77000 milesImage 2 - Nissan Sunny 1600 SLX Auto 77000 miles
Oh wow, that's very local to me, I've seen it around for years here, half tempted to buy it just so I can finally get some T cut on it!
Selling my old faithfull as it's fuckin fucked m8
Maybe autocorrect was a bit way out west?
