22 minutes ago, cort1977 said:
That is lovely.  Is it a bit salty or is that what a turbo CX goes for these days?
Click on the ad. and look at the others 3 Gti Turbos all £15,000 a couple of S1 Pallas’ for £20 k. Something else I’ve missed the boat on , then.
2 hours ago, The Mighty Quinn said:
It looks a lovely example of one of the most significant cars of the seventies/eighties.
Some mong will pay that for a Mark 3 Cortina. Away it goes, Pinto rattling away, rear axle hopping about over bumps as the four links try in vain to hold it in place. A car built in Dagenham for around 3 quid and it shows. That early blue 2400 Pallas earlier......
CX's are hard work to keep good but if you want the best.....
You make a very convincing case.  Just need to find 8 bags...
6 hours ago, UltraWomble said:
https://www.facebook.com/marketplace/item/209853386929304/
90703842_2571419183133749_85620437229198
Obscurification Skillorz 2
90914246_2571418256467175_16136627168309
Barging you say....?
Date tested7 March 2020
FAIL
 View test certificate
Mileage92,112 miles
MOT test number9922 3534 0599
Test location
 View test location
  • Nearside Windscreen wiper does not clear the windscreen effectively (3.4 (b) (ii))
  • Nearside Windscreen washer provides insufficient washer liquid (3.5 (a))
  • Offside Rear Rear fog lamp not working (4.5.1 (a) (ii))
  • Nearside Headlamp aim projected beam image is obviously incorrect (4.1.2 (c))
  • Offside Headlamp aim projected beam image is obviously incorrect (4.1.2 (c))
  • Nearside Headlamp has a product on the lens so that the light output is severely reduced (4.1.4 (b))
  • Offside Headlamp has a product on the lens so that the light output is severely reduced (4.1.4 (b))
  • Nearside Rear Vehicle structure corroded to the extent that the rigidity of the assembly is significantly reduced sill (6.1.1 (c) (i))
  • Central Rear Seat belt missing buckle (7.1.2 (a))
  • Nearside Front Brake pipe excessively corroded to rear (1.1.11 (c))
  • Offside Front Brake pipe excessively corroded to rear (1.1.11 (c))
  • Nearside Rear Service brake excessively binding (1.2.1 (f))
Repair as soon as possible (minor defects):
  • Nearside Obligatory mirror slightly damaged (3.3 (b) (i))
  • Nearside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c))
  • Nearside Rear Coil spring corroded (5.3.1 (b) (i))
  • Offside Front Coil spring corroded (5.3.1 (b) (i))
  • Rear brakes just passed brake roller test
  • all four tyres cracking on side wall
Its fooking fooked M8
I wonder why they were covering the rear number plate? Oh yes, the front plate says why.
1 hour ago, 11001010 said:
dont care what it is
hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggggg
Yeah unlike the over complicated galic spaceship leaking Vulcan blood from various orifices.
