£400 - 1989 Nissan Sunny 1.6 Gsi - 86000m - Manchester
Seller's Description
Nissan sunny 1.6 gsi manual ,very low miles 86.000,
Been in dry garage for six year, very good body work ,
Needs new brake pipes on front because of standing for so long,
This is a great classic and would make a great restoration with very little work,
Original bill of sale from nissan 1 previous owner £400
NO OFFERS so dont try??
You will be a clown ???
48391872_2191451717763695_23773537164758
49167971_2191451317763735_63591650942695
49128323_2191451347763732_12801056008893
48911373_2191451381097062_91532327684847
Blimey - £150 for a V6 2.0 75 Conny SE with High Line - no ticket, in Letchworth, no reg plate showing
Needs bought asap
https://www.gumtree.com/p/rover/rover-75-v6-connoisseur-se.-no-mot-but-driveable./1325870930
Sold on Ebay for £205 in November by the same seller. The words 'Rat' & 'Smell' strangely spring to mind..
https://www.ebay.co.uk/itm/rover-75-connoisseur-1999-2-0l-v6-auto-99p-no-reserve-/292803528775?nma=true&si=Vn8kc0c69lPR3VkMOJEqyIwLles%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
Don't think these had Yamaha engines, the only ones (that I recall) were the (earlier, Mk3) two stroke police cars and they (Yam) also had a hand in the Puma 1.7 engine. Like the man in the built up shoes though, I stand to be corrected.
<<Anorak On>>
The Zetec SE engine for the Fiesta / Focus is a Ford project, but the development was sub-contracted to Yamaha.
1.25, 1.4 and 1.6 versions were / are manufactured by Ford in Europe.
The 1.7 was manufactured by Yamaha themselves under contract to Ford, but that was because it was a low volume off-shoot project.
Yamaha also developed a 1.05 3 cylinder version for the Ka, but that didn't make it as it was too expensive compared to the old OHV Valencia donk.
<<Anorak Off>>
That 45 V6 is quite nice - I think it should have the horrible cheap taxi seats but someone has retro-fitted the earlier type. Must be one of the last v6 efforts, dont think I've ever seen any newer than an 03 plate
Good detective work sir, and handily a reg too with some base64 decoding : V373HEV
Date tested31 October 2018 FAIL
Mileage175,697 miles
MOT test number7814 3216 5913
Test location  View test location
  • Nearside Rear Anti-roll bar linkage ball joint dust cover no longer prevents the ingress of dirt (5.3.4 ( B) (ii))
  • Offside Rear Anti-roll bar linkage ball joint dust cover no longer prevents the ingress of dirt (5.3.4 ( B) (ii))
  • Offside Front Brake pipe excessively corroded (1.1.11 ©)
  • Oil leaking excessively from engine (8.4.1 (a) (i))
  • Front Registration plate deteriorated but not likely to be misread (0.1 ( B))
  • nsr tyre worn close to limit outer edge approx. 2mm
  • Nearside Rear Sub-frame pin or bush worn but not resulting in excessive movement axle bush (5.3.4 (a) (i))
  • Offside Rear Sub-frame pin or bush worn but not resulting in excessive movement axle bush (5.3.4 (a) (i))
Oh, the two stroke was nothing to do with Yamaha, it was a collaboration with Orbital, an Aussie design consultancy.
Killed by emissions, amongst other things.
I have driven a two stroke Fiesta (within the Aveley Plant no less!) but It didn't strike me as the answer to Ford's problems
£650 - 1993 Vauxhall Cavalier 1.8i GLS - 128,000m - Staines
So here I have this lovely little classic gem -
A 1993 Vauxhall Cavalier 1.8i GLS finished in a blue (sort of metallic?) fairly equipped with front electric and somewhat automatic windows, heated mirrors which do function!
It’s bodywork is in good condition considering age and mileage, it does have a couple of light dink’s and scrapes. No major rust on the car at all. The previous owner had acquired a set of GSI or Sri Alloys which are currently on the car at the moment but it does come with its original steel wheels and original hub caps! All 9 wheels (spare in the boot) have good tread depths.
Running wise it’s brilliant starts on the button even on a cold start, it has 128500 miles on the clock however you wouldn’t think from the way it drives as no knocks and bangs! It has back in March before I got the vehicle had a timing belt and water pump replaced, so that’s not required for a good mileage and few years!
It has an MOT till 03/19 and I cannot see why it would not sail through next year!
Has full hand books from when the vehicle was first bought and a Haynes manual. V5 is present
Viewing recommended
Cash on collection only
Can arrange delivery for an additional fee.
Sold as seen no warranty given
42235731_10156826359679175_2222303885261
42229927_10156826359864175_6827679875176
42217558_10156826359874175_8158808222958
42311763_10156826359999175_4140113963834
42264908_10156826360009175_3443831818770
46785130_10156982606964175_6450918038232
£1250 - 1990 Honda Prelude - Yeovil
Owned by the same lady since 1993 when imported from South Africa.
Fantastic condition for its age, starts and drives very well but will require a new clutch very soon
MOT June 2019
Has only covered about 12000 miles in the past 10 Years
Power steering
Electric windows
Just 122000 miles from new
49678570_10156823642324424_3073690553653
49509476_10156823640864424_1604112698134
49145508_10156823640944424_1143897585044
49183644_10156823640989424_6157157101413
I think they had some part in the 1.25?
I thought the 1.25 was all Kawasaki engineered???
I want this for myself, Soviet anti-theft system and all.
1979 UAZ 452b - £3500 - London
42473011_10155518245625286_5487978433369
42406727_10155518243750286_5567762583378
42394636_10155518243785286_8002208763249
42423034_10155518243970286_240766355838142498183_10155518243930286_2996548615985
RHD? they actually sold them over here?!
love the fact you can still buy them new, if I was money id buy one new  :mrgreen:
speaking of usual cars, I had no idea Ford made a 2 stroke Fiesta, must be one of the only modern-ish 2 stroke cars?
It was an experiment iirc, think they made them for the rozzers, but it didn't work out.
I just accidentally looked at the price of that Subaru. Its the French 'purple horse'!
Indeed, but there is this...
4ebffeb1a4f9055d9669316acd14351441c82567
