A 5-door 16v GTa?  Rarer than a GTi.  Want.
Registration number: J61CNN
  • Vehicle makeROVER
  • Vehicle modelMETRO
  • Date first used29 August 1991
  • Fuel typePetrol
  • ColourBlue
MOT history of this vehicle
  • Test date31 May 2016
  • Expiry date31 May 2017
  • Test ResultPass
  • Odometer reading54,210 miles
  • MOT test number1908 5510 4526
  • Advisory notice item(s)
    x2 front tyres worn on inner edges.
    unable to fully inspect front brake pads!
    Offside Front Subframe mounting prescribed area is corroded but not considered excessive sill (2.4.A.3)
    Offside Front Brake pipe slightly corroded (3.6.B.2c)
  • Test date1 June 2015
  • Expiry date31 May 2016
  • Test ResultPass
  • Odometer reading51,574 miles
  • MOT test number8258 7295 5106
    Offside Front Upper Front suspension ball joint dust cover deteriorated, but preventing the ingress of dirt (2.4.G.2)
    Both front tyres wearing on inner edges.
  • Test date1 May 2015
  • Test ResultFail
  • Odometer reading51,570 miles
  • MOT test number9266 3122 5196
  • Reason(s) for failure
    Nearside Front Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Rear Subframe mounting prescribed area is inadequately repaired (2.4.A.3)
    Nearside Rear Radius arm has excessive play in a pin/bush (2.4.G.2)
    Offside Rear Radius arm has excessive play in a pin/bush (2.4.G.2)
    both front tyres worn on inner edge
  • Test date6 May 2014
  • Expiry date5 May 2015
  • Test ResultPass
  • Odometer reading50,667 miles
  • MOT test number2789 0662 4101
    Both front tyres worn on inner edge
    Both front tyres perishing
  • Test date28 April 2014
  • Test ResultFail
  • Odometer reading50,664 miles
  • MOT test number5673 0811 4113
    Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
  • Test date27 April 2013
  • Expiry date26 April 2014
  • Test ResultPass
  • Odometer reading46,040 miles
  • MOT test number2252 1791 3134
    Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
    both front tyres worn on inside edges
  • Test ResultFail
  • MOT test number3063 5741 3127
    Hazard warning switch faulty (1.4.B.1d)
  • Test date12 April 2010
  • Expiry date11 April 2011
  • Test ResultPass
  • Odometer reading43,398 miles
  • MOT test number9940 6210 0140
    Exhaust has part of the system slightly deteriorated (7.1.1a)
    Nearside Rear Suspension arm has slight play in a pin/bush (2.4.G.2)
    Offside Rear Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.D.4)
    Offside Rear Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.D.4)
    corrosion on outer sill
  • Test date8 October 2008
  • Expiry date7 October 2009
  • Test ResultPass
  • Odometer reading42,965 miles
  • MOT test number8412 5278 8276
    Corrosion on both outer sills and wheel archs but not considered excessive
    Nail in nearside front tyre
    Fuel filler neck corroded
    Rear brake hose ferrules slightly corroded
  • Test date29 September 2008
  • Test ResultFail
  • Odometer reading42,959 miles
  • MOT test number3411 5327 8400
    Nearside Outer Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Outer Rear Seat belt anchorage prescribed area is excessively corroded (5.2.6)
    Offside Rear Brake pipe excessively corroded (3.6.B.2c)
    Nearside Front Brake pipe excessively corroded (3.6.B.2c)
  • Test date8 October 2007
  • Expiry date7 October 2008
  • Test ResultPass
  • Odometer reading41,092 miles
  • MOT test number9225 8148 7217
    Nearside Rear Radius arm has slight play in a pin/bush (2.4.G.2)
    Offside Radius arm has slight play in a pin/bush (2.4.G.2)
    corrosion on off side outer sill and rear wheel arch
  • Test date7 October 2006
  • Expiry date6 October 2007
  • Test ResultPass
  • Odometer reading39,051 miles
  • MOT test number3101 2058 6293
    front suspension slightly low
  • Test date28 September 2006
  • Test ResultFail
  • Odometer reading39,032 miles
  • MOT test number4130 2157 6210
    Offside Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    petrol tank corodded
    offside rear wheel arch corodded
  • Test date13 September 2005
  • Expiry date28 September 2006
  • Test ResultPass
  • Odometer reading37,635 miles
  • MOT test number3131 8625 5273
  • Test date8 September 2005
  • Test ResultFail
  • Odometer reading37,614 miles
  • MOT test number3544 7105 5453
    Nearside Stop lamp not working (1.2.1b)
    Exhaust has a major leak of exhaust gases (7.1.2)
    outer sills and offside rear wheel arch slightly corodded
    slight play in rear radius arm bushes
do not try read the description with anything sharp nearby
Holy shit, you aren't kidding when you aren't kidding!
I didn't get to the end of the first sentence, which actually isn't a sentence.
Minimum effort to obscure number plate of Micra or poor photographic style ( take that thumb from the camera & stick it up your arsenal )
Rover Metro Chairman
A five door, face lifted version? never seen one like this before, I have only ever seen three door versions
Rover Metro Chairman | eBay
The owner of that Chairman seems to imply that, not only is is a magnificent mode of transport, and there is no argument there of course, but that its also a sound investment opportunity...which I think may be a less universally held view.
I wonder if they ever did a GTI version?
I now have an image in my head. A VVT-swapped Metro Chairman ripping round Knockhill. :D
My list of stuff from the land of septics that tickles my fancy has just increased by one
fapadee fap
http://www.ebay.co.uk/itm/1964-Ford-Thunderbird-Automatic-Harvest-Moon-Yellow-3-9cu-inch-6-400cc-V8-DRR256-/382090152776?hash=item58f6590b48:g:qwwAAOSwB-1Yn7rF
I think I would keep crashing though because I wouldnt be able to concentrate on the read ahead
I used to live in gala I don't think anyone else does anymore. I think cortinadaves mate who's name I've totally forgotten lived near Selkirk and had a shit ton of cortina . That isn't him though .
If you want some lols check out the Renault 4 he's selling .
The broon one? It's a belter*.
