PhilA Posted September 1, 2018 Author Posted September 1, 2018 Asimo, dome, Sudsprint and 28 others 31
Guest Hooli Posted September 1, 2018 Posted September 1, 2018 Why does your pickup have a motel sign on the roof? Junkman, Mally, johngarty and 2 others 5
PhilA Posted September 1, 2018 Author Posted September 1, 2018 Aerodynamic aid. Edit: Apparently the film "Parker", with Jason Statham was filmed on location there. Dan_ZTT and eddyramrod 2
hairnet Posted September 1, 2018 Posted September 1, 2018 Why does your pickup have a motel sign on the roof?Could easily live in it Bigger than my hotel room DeeJay 1
PhilA Posted September 2, 2018 Author Posted September 2, 2018 Car is sitting on the driveway. No pictures because it was lashing it down with rain. I pulled the Renault up alongside and put the jump leads on. Would it start? Would it buggery. Click crrnnnnn. Turn over half-assed. Eventually got it running, cleared the road, backed it up down off the trailer and into the driveway. Just drove to town and dropped the trailer off at U-Haul. 330 miles round trip, 15.1mpg (18.1UK). Worn out. Need to fuel up the truck. Feels like a sports car to drive now. Running smoother too, guess it needed a good long run. View in my mirror all the way home, a stern looking chief. Dropped off the trailer in town. Long trip and it's still not over... Update later when it's light. Phil Exiled_Tat_Gatherer, Sigmund Fraud, mercrocker and 16 others 19
PhilA Posted September 2, 2018 Author Posted September 2, 2018 Oh, and a tidbit to chew over while I sleep. Leaning under to unhook the chains tonight I noticed that 1) it's on lowering blocks 2) the front springs are either cut or heated to be lower and 3) it has air shocks but I'm not sure if only at the back. Phil somewhatfoolish and Jim Bell 2
PhilA Posted September 2, 2018 Author Posted September 2, 2018 All tucked in for the night. Full photo and video review in the morning (weather pending). Phil DVee8, danthecapriman, DeeJay and 11 others 14
Rocket88 Posted September 2, 2018 Posted September 2, 2018 If my Rocket 88 was anything to go by, it was probably originally on lever arms..........and may still be at the front........judging from the pics, it's sits well as it is.
Junkman Posted September 2, 2018 Posted September 2, 2018 '51 should be proudly teleshockers. I could see from 4,700 miles away that it's slamt. Air shocks are only available for the rear. Entirely btw, mine was beige with a grey roof. Originally from Illinois it was rotten as a pear, but my Indian lit up!Thanks God no MoT was required on cars like this in Belgium 25 years ago, otherwise no hoonage would ever have ensued. Squire_Dawson, mercrocker, eddyramrod and 3 others 6
PhilA Posted September 2, 2018 Author Posted September 2, 2018 It was difficult to judge, sat where it was. Looks like a 2" set of blocks at the rear and the front lower arms are horizontal so about the same at the front. Service manual doesn't give "height from the ground" as a measurement. I'll have to drive it for a while to reserve judgement. It may end up raised up, it may not. Initial views underneath show a moderate proportion of the body has been coated with the vehicle's built in corrosion protection. I need to get it up on the ramps at work and start having a poke. Indeed it's telescopic dampers all round. On the outside it smells like my old man's Sprite (old oil, old grease, other engineering smells). This is a good thing. Also, someone has cared for it at some point in the past. The kingpin grease points at least are caked with glop and dirt. Back to bed (it's 3am). Phil Squire_Dawson, Tickman, tooSavvy and 6 others 9
PhilA Posted September 2, 2018 Author Posted September 2, 2018 First things first. Stand in the porch and look at the car from a distance. If I can find my umbrella I'll take some more, but this rain is due all week. Phil Squire_Dawson, Datsuncog, CGSB and 7 others 10
Guest Hooli Posted September 2, 2018 Posted September 2, 2018 Big car looks smoll behind smoll car. somewhatfoolish, Crispian_J_Hotson, Junkman and 3 others 6
PhilA Posted September 2, 2018 Author Posted September 2, 2018 It stopped raining long enough to do a video. It's no Dollywobbler production, be warned! Enjoy! Phil Conrad D. Conelrad, Bobthebeard, andrew e and 32 others 35
PhilA Posted September 2, 2018 Author Posted September 2, 2018 Does it have good working Wipers Phil? Epic Car loving the transmission selctor Yes, it has wipers. They don't work Phil Joloke and somewhatfoolish 2
PhilA Posted September 2, 2018 Author Posted September 2, 2018 Oh, and importantly, since the video: We have illuminated chief. Needed a bulb. Phil anonymous user, LabRat, cort16 and 30 others 33
PhilA Posted September 2, 2018 Author Posted September 2, 2018 The good: The bad: The ugly: It's chucking it down with rain again, too. Phil Skizzer, vulgalour, Datsuncog and 17 others 20
PhilA Posted September 2, 2018 Author Posted September 2, 2018 Oh, the big canister- looks like it's a vacuum tank for the wipers. Phil
hairnet Posted September 2, 2018 Posted September 2, 2018 mississipppppppi plate ftmfw what part of looeesee aaaaannaaaaa is that west countree accent from can i ask a stoopid q - the steering column - whats the small tube parallel to it
PhilA Posted September 2, 2018 Author Posted September 2, 2018 mississipppppppi plate ftmfw what part of looeesee aaaaannaaaaa is that west countree accent from can i ask a stoopid q - the steering column - whats the small tube parallel to itHa, still got the accent after eleven years here. The second small tube has the gear shift mechanism inside it. Phil
vulgalour Posted September 2, 2018 Posted September 2, 2018 Those wires are doing me a scare. PhilA and Talbot 2
vulgalour Posted September 2, 2018 Posted September 2, 2018 Oh, and big mystery yellow* canister is probably your washer fluid reservoir which normally has a vacuum system stuck on top for the wipers, at least if the videos corvetteben on Youtube has done on his 58 Cadillac are anything to go by. The line running to the fuel pump could well supposed to run to the carburettor instead and is just routed to the wrong place. For fuel filter, look under the car for a metal one strapped to the chassis somewhere, that seems to be the norm, as does not having one at all anywhere.
Mally Posted September 2, 2018 Posted September 2, 2018 Vacuum wipers!Memories of a Ford Prefect I'd rather not remember.Best of luck with those. PhilA and DSdriver 2
DeeJay Posted September 2, 2018 Posted September 2, 2018 Not a very long "Ugly" list.It'll probably be easier to get parts for this than the ungratefull Renault. eddyramrod 1
somewhatfoolish Posted September 2, 2018 Posted September 2, 2018 Vacuum wipers!Memories of a Ford Prefect I'd rather not remember.Best of luck with those.A 4.4l straight 8 has a better chance of being on a trailing throttle than a 1.2 4 pot. Those wires are doing me a scare. They're giving me teh fearz as well. Fire extinguisher and a BFO battery switch required until that lot's chopped out. PhilA 1
tooSavvy Posted September 2, 2018 Posted September 2, 2018 Just watched Utoob 'classic truck rescue'... Where they score the red wrecker. This (you) I thought of.... What a beautiful old boat - the glowing chief wins it all!! jumpingjehovahs 1
PhilA Posted September 2, 2018 Author Posted September 2, 2018 I haven't found evidence of screen wash yet. Put it into the garage to dry off. More tomorrow. (Day off). Phil egg, Conrad D. Conelrad, mercrocker and 32 others 35
bigstraight6 Posted September 2, 2018 Posted September 2, 2018 Love the walk-round Phil, I can’t believe how humid it looks there! The car is great, I’m extremely envious... PhilA 1
PhilA Posted September 2, 2018 Author Posted September 2, 2018 It's been on and off but it's hot today, 100% humidity. I took it for a quick spin down the street. Feels like the gearbox to the accelerator linkage is not adjusted correctly because it was revving way up high before changing gear. It also sounds like I have a crazed castanets player under the hood. Valve lash is on the books but it looks like access is crappy because that's under the manifolds. Another thing on the list. I need to buy some grease and a new oil can. This has plenty of grease points, with a 2000 mile regime of adjustment and lubrication to "retain the inbuilt value". Phil Junkman, Squire_Dawson, DeeJay and 2 others 5
Mally Posted September 2, 2018 Posted September 2, 2018 I have worked on a Pontiac.Think it was this one.http://f1stockcars.com/around-the-pits/flashback-friday-2012-brisca-f1-stockcars-through-the-ages-part-3/ Hmmm, not as easy as I thought, page down to racing no 41 and that's it.Edit, think it even says Pontiac on the roof. PhilA 1
