Lukas Posted May 15, 2016 Posted May 15, 2016 Hi! Does anyone of you have any tips for me what I might do against martens destroying my Buick from the inside out? The last few days, I found parts of the bonnet-insulation, parts of heat-protection-mats and even parts of the interieur-ventilation-cover on the floor under my Buick. There must be animals that pull those parts our and have fun in the engine bay. The car is parked outside because I dont have a garage for it, so what would you do? I fear that maybe next time, it will not be a insulation-mat but a fuel-line or something like that. Is there anything that works? Thanks a lot! Lukas
castros_bro Posted May 15, 2016 Posted May 15, 2016 Try a chilli pepper spray - it works on motorbike wiring vs rodents.
vulgalour Posted May 15, 2016 Posted May 15, 2016 Find out what they are and then find out what they don't like. Ideally, you need to make a barrier around the car to stop them getting to it. You can use poisoned bait but you've got to be careful it's safe for the animals further up the food chain.
Rocket88 Posted May 16, 2016 Posted May 16, 2016 + I don't think "blowing the bloody doors off" is quite what is intended.............
pshome Posted May 16, 2016 Posted May 16, 2016 mercrocker, Magnificent Rustbucket, Junkman and 2 others 5
pshome Posted May 16, 2016 Posted May 16, 2016 A good hot engine wash may help, worked for me. Reasoning: they mark their territory. If you change location (work to home), another one gets the smells, considers an enemy in his turf and destroys his nest = your engine compartment.
daveb47 Posted May 16, 2016 Posted May 16, 2016 Tie tail with short string under your car,problem solved. pshome, Magnificent Rustbucket and Junkman 3
Six-cylinder Posted May 16, 2016 Posted May 16, 2016 This is my solution that can even do aerial patrols for you! Magnificent Rustbucket 1
Parky Posted May 16, 2016 Posted May 16, 2016 Apparently they like jam sandwiches. Instructions: Placed slice of bread on batteryApply jamRun bare wire between battery terminalsPut other slice of bread on top. Pine Marten rocks up, thinks. "Ooh jam sandwich om nom nom pzzzzzzzzzzt" Problem solved!! Probably best to ensure the vehicle isn't parked too close to the house in case of immolation....
