Tickman's stuff.
A little bit of shuffling today as the 205 was blocking the doorway, not anymore.
It looks massive outside next to the tiny cottages.
Now tucked away again.
Started on the Octavia today but I only had a very brief amount of time.
Up in the air and the wheels off.
The right rear caliper is sticking and I went to investigate that first.
With the wheel off the disc wobbled about on the hub as the securing screw had snapped off, this is a pet hate especially when trying to get the wheel back on lining up the holes so out with the drill and tap.
A lot of suspension components are covered in surface rust but it is quite solid.
One rear spring is broken and the front seem to be fine.
Caliper freeing off or replacement of to be decided at the next visit.
Told you it was a brief visit.
I just put a screwdriver through the wheel and the disc and wobble it about until all the holes line up.
/teuchtar
The driveshafts for the 205 arrived, the short one was the problem so jacked up ready and out with the drain plug.
I managed to catch all of it.
I couldn't get the bottom ball joint out of the hub so I had to remove the bottom arm, after I did that it just fell on the floor. That took half an hour of messing about.
New driveshaft fitted.
The wheel trims have a great little design that holds them on, the little wires inside the hole.
Extra shoulder on the bolt for the wheel trim.
The oil that came out was a bit manky so I will pick up two litres for it for next visit.
Ah, I couldn't remember if I'd changed the oil on the 205 or not. That confirms I hadn't. Soz.
I presume the window rail doofer wotsit you need is a different size on 3 doors and 5 doors?
I've just seen a 5 door 205 in Deatons scrapyard in Staveley, it's mostly complete.
I'm sure they'd post a window runner - 01246 474252, they're open tomorrow.
If they won't take it off and post it I might be able to but it'd have to be next week or something
This is gear oil Alex, I've yet to do the engine oil.
Yes I think 3 door and 5 door are different judging by pictures on the internet.
Thanks for the tip off, I shall chase that up.
Some university visits are happening this week but today was local so some work got done after I was told to go away.
I need to do an engine service and the easy way to get the right filter is get the same one.
The gearbox was refilled, 2 litres went in up to the fill level and only 1.2 litres came out. I took it for a quick test drive and it is no longer knocking while driving :)
After the test drive it was spotting the ground, it is coolant from under the foil pipe.
This is the joint.
And the leak.
I am guessing it is the thermostat housing there so a new thermostat may just get ordered up for when I investigate.
Not bad considering it was going to be just wandering around university today.
Oh we went on a lovely romantic drive to tesco in the 205 at shitefest 18! Such a lovely thing! I would have asked for a drive but it started making a funny noise which you've probably just fixed so we made a fag and carried on at a slightly lower speed to be safe
So things have been happening here.
First off Father Jack left with a man who is far more knowledgeable and capable with Land Rovers that I am.
I have been busy since June teaching my youngest to drive and on Friday it was decided that I had done ok.
Today I took a friends Toyota Yaris for MOT. It passed with no advisories as expected but underneath the thin end of the wedge has started. (62 place with under 8,000 miles, the tester looked at the miles and declared a pass then checked the car to confirm)
Time for some 205 time, after the window mechanism was silenced (glove with tissue in to stop the mechanism rattling off the glass as I haven't got round to chasing up the tip from Cobblers yet) it was time to sort the radio as it had slipped back into the dash.
Then it was time to fit the springs to the rear of the Octavia.
That doesn't look the same.
An empty space but you can see a shiny caliper.
To get the handbrake cables off the calipers this needs messed with.
The other side also done.
So I need to bleed the Octavia and get the correct spring then I can hopefully get an MOT test booked.
  • Like 7
I went to the workshop today to bleed the brakes on the Octavia, finding out I had two almost empty bottles of brake fluid caused me to change direction
I did a little on the 205.
Thought I should check the state of the cambelt.
I shall add that to the to do list then.
Next to sort out the leak at the thermostat housing.
The old one had been fitted with a torn seal and silicone. The new one had the ring seal around it so it now appears to seal fine.
As it was up to temperature I dropped the oil and changed the filter. Took ages to get 3 litres back in and I will let it settle and top up as necessary next time.
I will also get some more brake fluid!
Thanks to Nibblet for the rear light lenses for the Clio.
Much better than the horrific after market 'Lexus' style that were on it.
So after the last thrilling* update of the light lenses being fitted to Fren I had a response to the Gumtree advert that had been up for a couple of days.
It had words that had all the letters in so I was off to a good start. A time (6:30) was arranged for a viewing.
Someone came at 6:30 had a look at the car, took it for a brief test drive, pointed out a couple of issues and haggled a bit.
A price was agreed, paperwork done and this happened.
Bye bye Fren.
This enabled the tidy* workshop to have one less car in it.
First fill
One very happy Chuck.
I have no doubt that issues will become apparent, the first of which is the heater doesn't heat. I don't know if it did before but I shall have a look at some point soon ish.
Bye bye Fren.
First fill
Is that Chuck discovering the filler neck is a stupid shape and will sometimes spew fuel back out onto your boots?
Sent from my SM-G935F using Tapatalk
Aye, the heater was always roasty toasty for me. I drive every car (especially those without a temp guage) with the heater on and the window down, so I would have noticed.
That will be my fixing* it.
Off to double check the bleeding proceedure
No spillage but some confusion as to why it just wouldn't go in.
We've all been there - to be fair
Good result on the Gumtree sale, I must get some tips from you!
Write too much information and put a price with room for being beaten down
Post the ad with as many pictures as possible
Sit and wait for a couple of days with no response
Get a typical 'is the car still for sale'
Sigh and reply
Get a follow up 'can I view it tonight'
Reply yes, what time would suit (add rough directions including how to get around the clusterfuck of water main works still going on after 5 weeks)
Get told 6:30.
Reply see you then.
6:30 doorbell goes and dogs go mental.
Show person the car
Get taken on a brief test drive
Get told there is a slight blow from the exhaust and no cambelt history
Agree and invite offers
Get told the price you had in your head straight off
Chance a counter with £25 more
Get agreement and shake hands.
Invite daughter to get all her shit out of the car while paperwork and monies is done
Wave bye to car.
Yeah, I couldn't believe it either :)
My advert already fits those guidelines however maybe I should add "I'll probably just drive to your address, give you the car,and get the bus back".
I might have some of your luck.
Driving the Jag back, I did manage to forget the right turn, ended up drive around the roadworks (wasn't clear that I wasn't supposed to) and end up at the end of the road to turn out. Except I couldn't as there was cones in the way. Was very tempted just drive over them/move them out of the way and carry on.
So the 205 belongs to Chuck and the Clio now belongs to Meg after passing her test so the only vehicle I have that is legal and on the road it the campervan.
This situation has happened before and a bit of a (justified) slagging was received so operation get a car MOTed as you don't have one has been launched.
Obviously as part of this I went to look at a non MOTed car this morning but it didn't give me a good feeling so walked away.
Next on the list is the Octavia which now has a name. This shall be revealed at the end of the post.
First off fit the rear spring:
This done I bled the brakes through again, this may need repeated with the two man method.
I decided to have a look at the usual MOT stuff so checked the lights, all good.
Then the washers and wipers, yes and NO.
Onto the internet and the wiper mechanism seizes up so off with the wiper arms and scuttle.
Yuck.
Wiper mechanism out and trying to move it.
Fuck
Yes the bloody thing broke before it would free off so the car is now called 'ungrateful bastard' no capitals as it doesn't deserve them.
I shall free it off and reassemble and try for a test, if I get one then I can sort it later along with all the other issues the tester will no doubt find.
If I don't get a test then I might just give up.
