Retroshite
Lovely! I agree SK it looks perfect just as it is. How many miles?
170k
Sent from my G3121 using Tapatalk
That is the kind of car driven in the 1990s by crusty drug dealers with upper middle class parents. He could've had a brand new one courtesy of his grandma but he felt the rust and gaffa tape repairs made him look edgy.
I bet you find a 'Spiral Tribe' tape in the stereo.
Sounds about right. The car is in St Albans and will cost more than the car is worth to bring it here.
Top quality vehicle sir. I know I've got hardly any posts on here but I could probably assist in getting that vehicle a fair bit closer to you if that's of interest.
Edit: just seen no MOT :(
Aye, Hertfordshire was a prime location for 'FakeRastaz' in the 90's.
Local to st Albans if I can be of any help.
Delivery of the car has already been arranged but offers of help are appreciated.
Cheers.
That's good news.
I'm still scratching my head about the sugar in the tank of the Mazda.
I remember being told by my dad's underkeeper in 1978, that if you want to fuck someone's car up, put a bag of sugar in the tank.
Over 40 years later and I've now seen it happen!
I just don't get why some one would want to mess up someone's car like that.
well theres a reason he said "ex"  :mrgreen:
It was a relatively nice day today so spent some time outside trying to improve the Audi 80, first I found a set of wheels that held air then fitted some tyres to them.
32110179397_b474280d14_c.jpgRJC_6708 by srblythe, on Flickr
Next we tried figuring out how to put the front end back together.
46328035404_e49cf87f34_c.jpgRJC_6711 by srblythe, on Flickr
46328033174_66c5dc689c_c.jpgRJC_6714 by srblythe, on Flickr
Ended up having to take the wings back off in order to fit the headlights.
33176702438_16f5884538_c.jpgRJC_6717 by srblythe, on Flickr
Still need to screw the bumper on, lower valance and some bits of trim but it's starting to look like a car again.
Last week my friend brought back the pipe I needed from Hungary to get my w123 running.
46132943415_1bd5d38273_c.jpgDSC_0208 by srblythe, on Flickr
It turned out that it wasn't quite right so I had to bodge an adapter onto it to make it fit the fuel regulator/accumulator
46322707714_85e039feb4_c.jpgDSC_0210 by srblythe, on Flickr
46132942145_185297976e_c.jpgDSC_0211 by srblythe, on Flickr
46322707434_71f04ca244_c.jpgDSC_0213 by srblythe, on Flickr
It turns out that the pipe must be from a similar but slightly different car because when all fitted together the original mounting bracket doesn't really fit onto all of the components. I just bolted it together the best I could and fitted it together.
46132941275_b6a4d7e6af_c.jpgDSC_0214 by srblythe, on Flickr
46322706684_b0f362a534_c.jpgDSC_0216 by srblythe, on Flickr
I put some fuel in the tank and tried starting but it still had the same issue as before where it fired then died two seconds later. On top of that it appeared to be pishing out fuel from what looked like three different locations but might have just been one that was higher up and dripping off the lower points in the system.
Fed up with my lack of good results I pushed it back into its space and left it until today. A couple of people had mentioned that it was probably the fuel pump relay at fault so I bridged pins 30 and 87 and right enough the pump primed continuously, I stuck some more fuel in the tank and it fired into life.
It's still leaking fuel but at least I know what the issue was in the first place. I'm kicking myself a little because I'm only in this position because when it broke down I went for the cheapest/easiest fixes first and decided to change the pump and filter but destroyed all of the original rusty hard fuel lines in the process. If I had just bought a relay then It would have been fixed and I wouldn't be having all this bother with it.
  • Like 8
46171825075_d55326ca5d_c.jpgRJC_6724 by srblythe, on Flickr
Shitey Mercedes has arrived!
It's only around 5 days late...
I'll need to get a better look at it tomorrow in the daylight but I'm pretty happy with it.
Here it is in the daylight!
33220673078_22e571a824_c.jpgRJC_6771 by srblythe, on Flickr
46182234255_5faa4c4903_c.jpgRJC_6772 by srblythe, on Flickr
47043624012_ca77c39783_c.jpgRJC_6745 by srblythe, on Flickr
Now for the bad bits
47043623342_179a90c932_c.jpgRJC_6747 by srblythe, on Flickr
33220705408_85c2501d89_c.jpgRJC_6748 by srblythe, on Flickr
33220704618_7c8e26d00d_c.jpgRJC_6753 by srblythe, on Flickr
47043621492_e6bfc58150_c.jpgRJC_6754 by srblythe, on Flickr
33220702378_e994be992c_c.jpgRJC_6755 by srblythe, on Flickr
33220701328_b99764ab9c_c.jpgRJC_6756 by srblythe, on Flickr
47043620152_4ae2e0dc97_c.jpgRJC_6757 by srblythe, on Flickr
32154090847_5507708ac7_c.jpgRJC_6758 by srblythe, on Flickr
46182257175_1c87461513_c.jpgRJC_6759 by srblythe, on Flickr
46182256625_2ea43a115c_c.jpgRJC_6760 by srblythe, on Flickr
Not too bad really, a rear wheel arch, the jacking points, a front inner arch and a rear corner need welding, I think it's less rusty than the white one.
I was wondering why you had bought this one as the white one looks far fresher. Is the white one hiding rot?
I bought it because Mrs SK wanted another Mercedes and chose this one, the white Mercedes required more welding than I'm anticipating the gold one will.
36754927362_7a95f0870c_c.jpgDSC_0079 by srblythe, on Flickr
Most of the floor on the drivers side needed replaced along with the jacking points and a rear arch. The wings could be doing with being changed but as it wasn't likely to fail an mot on them I've never bothered.
36136756573_e0c7554ac1_c.jpgDSC_0975 by srblythe, on Flickr
36900740036_67813fa02b_c.jpgDSC_0041 by srblythe, on Flickr
37103915505_0267092472_c.jpgDSC_0118 by srblythe, on Flickr
45926317551_954b830ce2_c.jpgOld Mercedes at night by srblythe, on Flickr
Get used to that sort of timescale with a 240d.
Bernadette thought that was very funny. Well done!
I went to the Mercedes dealer yesterday to try and obtain the correct piece of fuel pipe and hose for the white w123. They had them in stock for £105. Bargain!
Only a couple of patches...
46192259225_63479650a4_c.jpgRJC_6835 by srblythe, on Flickr
46192257865_a845a2d556_c.jpgRJC_6842 by srblythe, on Flickr
46192256765_82909358da_c.jpgRJC_6844 by srblythe, on Flickr
46192256295_5f25e4b164_c.jpgRJC_6845 by srblythe, on Flickr
That's the worst of it out of the way but need to wait on a wheel arch repair panel coming to finish off the drivers side. The passenger side has much less rot by the looks of it and should only require a couple of bits at the jacking points.
  • Like 8
I made a little bit more progress on the 240D, I finished the jacking points on the passenger side and welded some new metal into the inner rear arches.
My 110V Angle grinder stopped working recently so when I spotted some locally for sale going cheap I went for a look.
46203392565_b4c588f557_c.jpgDSC_0062 by srblythe, on Flickr
I ended up spending £180 on welding equipment and grinders!
33250959558_bfe696970b_c.jpgRJC_6892 by srblythe, on Flickr
I got a single phase Nexus nxm 170 mig welder, It works really well and is easy to use.
47126292421_ab71165812_c.jpgRJC_6894 by srblythe, on Flickr
I got a Murex tradesmig 263 3 phase machine with a MASSIVE bottle of argoshield heavy. It is pretty much exactly the same as my old Esab welder but works a lot better, I think the Esab had a hard life welding skips back together.
33250958628_559e8cc107_c.jpgRJC_6893 by srblythe, on Flickr
I also got a new arc r1500 110v inverter which can be used for stick and tig, I looked them up and they retail at £1100 new so £50 for it seems like a bit of a bargain. I had a quick go with the stick and it seems to work great.
The guy selling them was a retired engineer and was in the middle of clearing out all of his gear, he chucked in a couple of 110v extensions and some burning gear in for nothing.
I'm probably going to go back and get some more 110v stuff before it's all gone.
Since I had some decent gear I thought it best to clear some of the shite out, I thought 7 welding machines might be a little excessive so sold 3 of them as a job lot for £100
46393530954_965b57ece8_c.jpgDSC_0065 by srblythe, on Flickr
47065000932_75c7daae46_c.jpgDSC_0066 by srblythe, on Flickr
47117239171_befdd9ff58_c.jpgDSC_0064 by srblythe, on Flickr
While I continued to weld the Mercedes, Mrs SK made some stuff out of scrap metal.
47117235621_07c346059a_c.jpgDSC_0070 by srblythe, on Flickr
47117235851_0d729da9cb_c.jpgDSC_0074 by srblythe, on Flickr
A strange looking dog...
33250957658_29d222fb4e_c.jpgRJC_6898 by srblythe, on Flickr
46212288825_485a6ff8d2_c.jpgRJC_6902 by srblythe, on Flickr
I'm not quite sure what it is, some kind of reptile...
Hey, come on now. Your cars aren't that bad.
I know it's not quite the right generation. But close enough.  :)
I enjoyed that, thanks.
