Angrydicky Posted August 28, 2021 Posted August 28, 2021 That Camry looks great, proper old geezer spec. How rusty is it?
DodgyBastard Posted August 28, 2021 Author Posted August 28, 2021 3 hours ago, Angrydicky said: That Camry looks great, proper old geezer spec. How rusty is it? It's less rusty today than it was yesterday but in general it's a typical 90's jap car underneath with surface rust on all of the heavy steel parts and a few scabs here and there. It failed on a small area of rust on the offside rear inner arch and sill. Rust Collector and Angrydicky 2
DodgyBastard Posted August 29, 2021 Author Posted August 29, 2021 On 8/28/2021 at 7:17 PM, Supernaut said: Also, that LDV. I somehow just want to drive it every time I see it. It's terrible by every measurable metric, but so endearing. Supernaut, Coprolalia and Dirk Diggler 3
Noel Tidybeard Posted August 29, 2021 Posted August 29, 2021 On 26/08/2021 at 21:43, DodgyBastard said: the Indenor obvs!🤣 if the MGB comercial was prima that's another story!
DodgyBastard Posted August 31, 2021 Author Posted August 31, 2021 I'm in talks with a friend about giving him the BX plus £800 for a Sierra P100 running a pinto. Should I be ripping his arm off for such a deal?
Split_Pin Posted August 31, 2021 Posted August 31, 2021 The MOT fail list doesn't look brilliant from 2008, I can't imagine it has improved. I reckon it's a decent investment though, aren't these worth a fair bit now?
Barry Cade Posted August 31, 2021 Posted August 31, 2021 I was welding those from arsehole to breakfast time 25 years ago.. the BX might be a minor inconvenience compared to that. If not. DO EEEt.. they look ace when cosseyfied..
big_al_granvia Posted August 31, 2021 Posted August 31, 2021 Ford scene tax, will be rotten as fuk but if your daft or brave enough to weld it then there is coin in a restored one
Mrcento Posted August 31, 2021 Posted August 31, 2021 Speaking purely on an 'if it were me and i had your skills' basis... I'd 100% do the BX and swerve the Ford. Shite Ron 1
Andyrew Posted September 1, 2021 Posted September 1, 2021 Doesnt sound like the deal of a lifetime but Id have the P100. Always like them.
juular Posted September 1, 2021 Posted September 1, 2021 11 hours ago, DodgyBastard said: I'm in talks with a friend about giving him the BX plus £800 for a Sierra P100 running a pinto. Should I be ripping his arm off for such a deal? My dad briefly had one of these from his work and it was epic. I remember him trying to find a way to keep it. On the flipside it will probably definitely look like the Titanic underneath. Not that it should bother someone like yourself to be fair.
DodgyBastard Posted September 2, 2021 Author Posted September 2, 2021 What a honey! Buying this tomorrow... cobblers, DoctorRetro, Mrcento and 22 others 25
big_al_granvia Posted September 2, 2021 Posted September 2, 2021 impressive........fail sheet, get the mig oot
DodgyBastard Posted September 2, 2021 Author Posted September 2, 2021 39 minutes ago, big_al_granvia said: impressive........fail sheet, get the mig oot Can't be any worse than that Sierra pickup. Do not drive until repaired (dangerous defects): Stop lamp(s) all not working (4.3.1 (a) (iii)) Nearside Rear Leaf spring to axle fixings loose to the extent that relative movement is visible nut missing (5.3.1 (a) (ii)) Nearside Rear Brake load sensing valve seized and ABS not fitted or inoperative (1.1.17 (c) (ii)) Repair immediately (major defects): Nearside Rear Seat belt buckle missing (7.1.2 (d)) Offside Rear Seat belt buckle missing (7.1.2 (d)) Nearside Front Position lamp missing (4.2.1 (a) (ii)) Nearside Front Headlamp insecure (4.1.1 (c)) Nearside Front Headlamp aim too high (4.1.2 (a)) Offside Front Headlamp aim too low (4.1.2 (a)) Offside Rear Position lamp showing white light to the rear (4.2.3 (a) (ii)) Offside Rear Position lamp lens seriously defective (4.2.1 (b)) Nearside Front Bumper insecure (6.1.4 (a) (i)) Offside Front Lower Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting (6.2.2 (d) (i)) Front Exhaust has a major leak of exhaust gases (6.1.2 (a)) Emissions not tested (8.2.2.2 (e)) Offside Front Drag link end ball joint has excessive play (2.1.3 (b) (i)) Nearside Front Steering arm deformed (2.1.3 (c) (i)) Power steering malfunctioning (2.1.5 (a)) Nearside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength leaf spring mount inadequate repair (5.3.6 (a) (i)) Nearside Rear Lower Suspension component mounting prescribed area excessively corroded significantly reducing structural strength outer sill (5.3.6 (a) (i)) Offside Rear Lower Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting sill (6.2.2 (d) (i)) Nearside Rear Brake prescribed area is excessively corroded chassis corroded near load valve (1.1.21 (e) (i)) Offside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength chassis (5.3.6 (a) (i)) Offside Front Inner Integral body structure or chassis has excessive corrosion, seriously affecting its strength within 30cm of a body mounting sill (6.2.2 (d) (i)) Nearside Rear Service brake effort inadequate at a wheel (1.2.1 (a) (i)) Offside Rear Service brake effort inadequate at a wheel (1.2.1 (a) (i)) Service brake efficiency below requirements (1.2.2 (a) (i)) Repair as soon as possible (minor defects): Battery insecure but not likely to fall from carrier (4.13 (a) (i)) Monitor and repair if necessary (advisories): Front Registration plate deteriorated but not likely to be misread (0.1 (b)) Nearside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c)) Fuel Pipe/s corroded () Offside Front Wheel bearing has slight play (5.1.3 (a) (i)) Offside Front Wheel bearing slightly noisy (5.1.3 (b) (i)) Offside Front Lower Power steering component has slight seepage from a component (2.1.5 (a)) Oh... davehedgehog31, loserone, Lacquer Peel and 2 others 3 1 1
Angrydicky Posted September 3, 2021 Posted September 3, 2021 If that's the P100, the load sensing valves are totally obsolete as well and may well prove an obstacle to an MoT even if you weld it up and do all the other work. I'd avoid, it doesn't seem especially cheap either.
Supernaut Posted September 3, 2021 Posted September 3, 2021 My reaction to that Mitsubishi started as "WOW", then went to "oh..." Crackers 1
DodgyBastard Posted September 3, 2021 Author Posted September 3, 2021 Drives fine! Now need to take the Camry for its retest after it failed on some rot on the inner sill and exhaust leak. The manifold to downpipe was hanging on by one bolt and one of the studs was snapped so had a bit of a nightmare drilling the stud out. After I split the exhaust I realized the gaskets were knackered so fitted new gaskets and plastered fuck out of every surface with exhaust paste and started bolting it back together only to find the only remaining stud stripped the nut when I was tightening it together. I had to resort to using a stainless steel nut with a different thread pitch and using a breaker bar to tighten it on. I hope I never have to remove it. Mrcento, Dyslexic Viking, LightBulbFun and 12 others 15
Split_Pin Posted September 3, 2021 Posted September 3, 2021 I don't recall ever seeing one that old before but I do remember the forward control van versions quite well. Nice one on the Camry, it's a fine looking car.
DodgyBastard Posted September 4, 2021 Author Posted September 4, 2021 Sent from my moto g( power using Tapatalk
DodgyBastard Posted September 4, 2021 Author Posted September 4, 2021 TrabbieRonnie and Dirk Diggler 2
DodgyBastard Posted September 5, 2021 Author Posted September 5, 2021 I went to see a car yesterday. Front wheel drive Subaru saloon, off the road since 1986 and sat inside a garage in auchtermuchty since coming off the road. 26k miles... It's on eBay currently at £580 with 2 days to go on the auction, it'll be interesting to see what it makes. greengartside, Joey spud, Brodders and 19 others 22
Barry Cade Posted September 5, 2021 Posted September 5, 2021 31 minutes ago, DodgyBastard said: I went to see a car yesterday. Front wheel drive Subaru saloon, off the road since 1986 and sat inside a garage in auchtermuchty since coming off the road. 26k miles... It's on eBay currently at £580 with 2 days to go on the auction, it'll be interesting to see what it makes. Auchtermuchty.. used to live there and my spidey senses were always tingling.. I reckon there are a few like that tucked away.. Wonder if its a Reekie Motors car..
DodgyBastard Posted September 5, 2021 Author Posted September 5, 2021 7 minutes ago, Barry Cade said: Auchtermuchty.. used to live there and my spidey senses were always tingling.. I reckon there are a few like that tucked away.. Wonder if its a Reekie Motors car.. It says in the eBay advert that it came from Reekie Motors. Barry Cade 1
Cord Fourteener Posted September 5, 2021 Posted September 5, 2021 Great chod tastic saloon, but an even better place name. I hope there's a distillery in that village. Imagine trying to order that when you're a few drams in. Barry Cade 1
Barry Cade Posted September 5, 2021 Posted September 5, 2021 55 minutes ago, DodgyBastard said: It says in the eBay advert that it came from Reekie Motors. 😆 I didn't read the ad..
Barry Cade Posted September 5, 2021 Posted September 5, 2021 47 minutes ago, Cord Fourteener said: Great chod tastic saloon, but an even better place name. I hope there's a distillery in that village. Imagine trying to order that when you're a few drams in. Set in the centre of Auchtermuchty and surrounded by the Lomond Hills, a well-known habitat of smugglers and illegal distillers – local characters include Lady Miller who kept an illicit still in the hills. The distillery was unusually built in the centre of town and pre-dates courtyard-style distilleries. Construction was arduous, the water source, a tributary of the river Eden, channelled from the “Lovers pool” by an aqueduct. The water was extremely soft, with a distinct earthy and salty edge to it. Cord Fourteener 1
Zelandeth Posted September 5, 2021 Posted September 5, 2021 Wow...never even knew they existed. So still nearly new when it was parked up...why? LightBulbFun 1
DodgyBastard Posted September 5, 2021 Author Posted September 5, 2021 I really need to stop looking at cars. Spotted this for sale in Cumbernauld, I went along for a look and it seemed in reasonably good condition especially compared to my other 305's so bought it and will be having it delivered this afternoon. cobblers, Dyslexic Viking, Tickman and 21 others 24
