Six-cylinder Posted July 17, 2018 Author Posted July 17, 2018 Your electrician needs older diagnostic equipment. Find someone with an original Launch X431. They came in a big case with all the leads, I am 99% certain I have the right one here. I might have to go to Essex this Sunday so might be able to detour on the way back and code read it for you. I am about this weekend planning to visit the Buckingham canal festival which is taking place all weekend so can be free to fit in with you.
Six-cylinder Posted July 17, 2018 Author Posted July 17, 2018 I have a cheap generic OBD2 reader but lack a round 9 pin connector, would this work with a connector? D900 2015 but no make on it.
Conrad D. Conelrad Posted July 18, 2018 Posted July 18, 2018 Does any body know there way round Mercedes W124 heater controls? This morning my Auto sparks came calling, he poked and prodded the heater valve on my W124 200TE and announced the problem was the voltage it was receiving and not the valve itself. It seems if you start the engine with the heater on cold it will stay on cold, but once you move it to hot it will stay activated even if the temp wheels are turned to back to min. The system is designed to fail heater on. He is asking if can I provide a more comprehensive wiring diagram than the Haynes manual and where is the Control unit located? Can anybody find me a heater control unit part number or maybe lend me a control unit to try? If you are thinking why does the Auto sparks not just get on with it, I can't afford just to send it to be fixed so after 20 plus years friendship he will help me as long as I do the background stuff with a minimal cost and lots of tea. Picture is today looking a bit sad standing around to get you sympathy vote. Removing the control unit is a clean and quick interior job, and they're cheap on eBay so I'd just change it before trying to diagnose any further. I screwed around for ages trying to repair the GGG 300D's stuck on heater, a £20 used control panel fixed it. I still kept a length of wire in the car in case I needed to earth the duovalves again! Six-cylinder 1
Six-cylinder Posted July 18, 2018 Author Posted July 18, 2018 Removing the control unit is a clean and quick interior job, and they're cheap on eBay so I'd just change it before trying to diagnose any further. I screwed around for ages trying to repair the GGG 300D's stuck on heater, a £20 used control panel fixed it. I still kept a length of wire in the car in case I needed to earth the duovalves again! Is the control unit the bit that has the temp control rotors in it? https://www.ebay.co.uk/itm/Mercedes-W124-E-Class-coupe-Climate-Heater-Control-Panel-oem-1248302585-oa3c/253573324808?epid=1313909332&hash=item3b0a25e008:g:HO0AAOSwBF1a2dbf
Conrad D. Conelrad Posted July 18, 2018 Posted July 18, 2018 Is the control unit the bit that has the temp control rotors in it? https://www.ebay.co.uk/itm/Mercedes-W124-E-Class-coupe-Climate-Heater-Control-Panel-oem-1248302585-oa3c/253573324808?epid=1313909332&hash=item3b0a25e008:g:HO0AAOSwBF1a2dbf Yes. It doesn't look like much, but if you crack it open there is quite a bit of electro-nonsense inside. Two potentiometers, IC chips... a whole cornucopia of complexity for what was previously achieved with a bowden cable and a valve. Six-cylinder, chodweaver, RayMK and 1 other 4
Six-cylinder Posted July 18, 2018 Author Posted July 18, 2018 Yes. It doesn't look like much, but if you crack it open there is quite a bit of electro-nonsense inside. Two potentiometers, IC chips... a whole cornucopia of complexity for what was previously achieved with a bowden cable and a valve. Advice taken, I have ordered this one that has the correct part number on it. Old one out, just waiting now for Monday delivery. https://www.ebay.co.uk/itm/MERCEDES-E-CLASS-W124-HEATER-CONTROL-PANEL-1248302585/253753606713?epid=1313909332&hash=item3b14e4c239:g:eAoAAOSwOaBbSzdN
Mrs6C Posted July 18, 2018 Posted July 18, 2018 Removing the control unit is a clean and quick interior jobYou didn't mention how awkward it was to get the electrical connection block to part company with the controller though! Much close-up squinting with a torch (me) and manipulation (ooh-err missus!) with a dentist's toothpick (Six-cylinder) were needed to prise the two bits apart. Considering that the connection block and heater controller don't actually move once installed in the nice, well-secured environment of the dashboard, I'm amazed at how robustly Mercedes felt the two needed to be clipped together in service... No doubt there is a Mercedes 'Special Tool' that would have done the job in about two seconds... chodweaver and Six-cylinder 2
Conrad D. Conelrad Posted July 18, 2018 Posted July 18, 2018 I'd forgotten about that bit! But I still consider any job where I don't bleed, cry or get marinaded in a known carcinogen as a clean and quick job. Fabergé Greggs, chodweaver, DeeJay and 3 others 6
Six-cylinder Posted July 19, 2018 Author Posted July 19, 2018 Thank you Tickman for my Alfa 156 fuse cover. Thank you beko1987 for transporting my new fuse cover all the way from Scotland. I have managed to find a couple of trim clips that seem to fit and the cover is now in place, we will see if it stays there or if I need to drill a hole to put a screw it in. Tickman and Mrs6C 2
hairnet Posted July 19, 2018 Posted July 19, 2018 You didn't mention how awkward it was to get the electrical connection block to part company with the controller though! Much close-up squinting with a torch (me) and manipulation (ooh-err missus!) with a dentist's toothpick (Six-cylinder) were needed to prise the two bits apart. Considering that the connection block and heater controller don't actually move once installed in the nice, well-secured environment of the dashboard, I'm amazed at how robustly Mercedes felt the two needed to be clipped together in service... No doubt there is a Mercedes 'Special Tool' that would have done the job in about two seconds...chris has big shovels not petite laydeez hands tho Mrs6C 1
Tickman Posted July 19, 2018 Posted July 19, 2018 Thank you Tickman for my Alfa 156 fuse cover. Thank you beko1987 for transporting my new fuse cover all the way from Scotland. I have managed to find a couple of trim clips that seem to fit and the cover is now in place, we will see if it stays there or if I need to drill a hole to put a screw it in.I'm glad it is of use, it was only going in the bin otherwise! Mrs6C and Six-cylinder 2
Six-cylinder Posted July 20, 2018 Author Posted July 20, 2018 I am at Silverstone today with a borrowed MG Metro Turbo, anybody else here today? oldcars, blakey79, Mrs6C and 1 other 4
Mrs6C Posted July 20, 2018 Posted July 20, 2018 ^^^ the arrangement by colour seems to have gone a little astray... Six-cylinder 1
Noel Tidybeard Posted July 20, 2018 Posted July 20, 2018 how is it when you have at least eleventy twelvety cars you still need to borrow one? lol Mrs6C, SiC, richardmorris and 2 others 5
richardmorris Posted July 20, 2018 Posted July 20, 2018 how is it when you have at least eleventy twelvety cars you still need to borrow one? lol He’s not daft enough to take his own cars round the track? Mrs6C 1
Mrs6C Posted July 20, 2018 Posted July 20, 2018 It came with an event ticket and a free pass to the infield parking! Saved him a long walk with a heavy picnic...
Mrs6C Posted July 20, 2018 Posted July 20, 2018 Talking of picnics, I'm spending the weekend on our boat, so needed to do a bit of shopping for that. The S2 Daimler Sovereign stepped up for the Tesco run and received one tank of Super Unleaded as a reward... richardmorris, RobT, Six-cylinder and 1 other 4
richardmorris Posted July 20, 2018 Posted July 20, 2018 It came with an event ticket and a free pass to the infield parking! Saved him a long walk with a heavy picnic... For future reference the trick is to eat the heavy picnic, THEN go for the long walk. Mrs6C and The Moog 2
Six-cylinder Posted July 23, 2018 Author Posted July 23, 2018 I got the replacement W124 heater control unit today and waited for cool air just before dark to fit it. It has not solved the problem start the engine on cold setting and it is fine, move it to hot and you get heat. Move it back to cold and it stays on heat.
Guest Hooli Posted July 23, 2018 Posted July 23, 2018 Don't move it from cold.... Sounds like a sticky solenoid as I think I recall it having some photographed earlier?
Six-cylinder Posted July 24, 2018 Author Posted July 24, 2018 A new experience, usually when I get a car out of winter storage I take it to a booked MOT but for me getting the 1972 MGB GT out this week and being able to just drive it 15 months since its last MOT felt distinctly odd! The car felt good. I did have to brake heavily on the way home and all was well. I have now put it in my garage to do legals and levels, oil spot on, engine water a pint low. All the lights work. I am now considering whether it needs a garage to lift it but it had only done 448 mile since it was serviced last and 188 miles since the last MOT test. Now for the apology to SiC, I keep nagging you him to get on and use his MGB GT and when I look at the figures for mine I am not much better. I have owned it for 7 years and done 1,836 miles, 262 miles a year! The paint work is old and tired but with a clean and polish it looks ok from 3 yards away so I started to give it a polish, I only managed the top half as it felt very warm in the garage, a look at the thermometer shows 25° C at 9.30pm. If only it could be like that in winter! richardmorris, Bucketeer, Eddie Honda and 5 others 8
SiC Posted July 24, 2018 Posted July 24, 2018 I personally think they're just enjoyable enough to look at and sit in. Tomorrow will be a year since I bought mine. I think I've done about 120miles from the time I started the journey home in it. Oh how much more confidence I had driving it back then, when I bought it! Depressingly that still was the longest journey I did in it. Weston-super-mare to Bristol, through the centre. Anyhow, you're still doing better annually than I am right now! Six-cylinder 1
Six-cylinder Posted July 24, 2018 Author Posted July 24, 2018 I agree they are great looking cars. Silverstone last year, I did enjoy seeing that all lined up. I just will you were local we could go out together with a tow rope and see who needs it! egg, SiC and DeeJay 3
RobT Posted July 24, 2018 Posted July 24, 2018 Talking of picnics, I'm spending the weekend on our boat, so needed to do a bit of shopping for that. The S2 Daimler Sovereign stepped up for the Tesco run and received one tank of Super Unleaded as a reward... I'm so glad you're getting good use out of it, and it was nice to see at the FoD a few weeks ago. Seems a long time ago since I sold it to you both, in a 'requiring chunks of work' state! Mrs6C, Ghosty and Six-cylinder 3
Six-cylinder Posted July 24, 2018 Author Posted July 24, 2018 I'm so glad you're getting good use out of it, and it was nice to see at the FoD a few weeks ago. Seems a long time ago since I sold it to you both, in a 'requiring chunks of work' state! There is still the matter of the paint flaking off the roof and I demand you bring your roller and Dulux round and fix it! RobT 1
Mrs6C Posted July 24, 2018 Posted July 24, 2018 I'm so glad you're getting good use out of it, and it was nice to see at the FoD a few weeks ago. Seems a long time ago since I sold it to you both, in a 'requiring chunks of work' state!Those chunks of work are still flaking off the roof! We'll get around to doing a proper job on that in due course and replace the windscreen rubber at the same time... I suspect that will be an 'in the garage over the winter' type job... It's a lovely old thing for cruising around, that's for sure. RobT and Ghosty 2
RobT Posted July 24, 2018 Posted July 24, 2018 There is still the matter of the paint flaking off the roof and I demand you bring your roller and Dulux round and fix it!I've got some magnolia left over from doing the hallway. Will that do?! Six-cylinder, Mrs6C and chaseracer 3
Six-cylinder Posted July 24, 2018 Author Posted July 24, 2018 A bit of self indulgence, putting up a picture of Daimler Sovereign is very satisfying and far less fattening than eating a biscuit! Skizzer, HMC, Bucketeer and 7 others 10
Tadhg Tiogar Posted July 24, 2018 Posted July 24, 2018 A bit of self indulgence, putting up a picture of Daimler Sovereign is very satisfying and far less fattening than eating a biscuit! The ground's probably as hard as tarmac anyway.
