Six Cylinders Motoring Notes - What is it like to drive a pre war car a 1,000 miles in a year.
3 hours ago, ianbmw said:
Such negativity……completely correct and factual in everything you say……but so negative.
If the custodian of the Fuel pump wants to drain if from its diesel bath, we can reinstall it and see if that has brought it back into life before doing anything else.
I suspect any sober assessment will render that unviable for restoration, but if it started and move, it could move stuff around the field.
Assuming my addiction to lemsip has worn off by the weekend, we need to take another gander at that Carlton and put together a plan of attack……bring back the GL…….Bring back the GL…….being back the GL….i hear the AS community chant
You have already pushed me into driving a Carlton 2.0i as my go to car, now you want to downgrade me to a 1.8i!
It was not your Cavalier CDi I popped into a ditch  30+ years ago and lost my freedom to choose my own company car. So in 1993 I ended up with a brand new Carlton 2.0i Club estate in Satin red, that was my boss's doing with the words "I think you will be safer in this!"
So , set out a plan of attack for the GL, sling the carb back on the Royale and see what it does……THEN look at the CF?
Yes I need an upgrade to a Royale then all those other middle managers will know how successful I am!
30 minutes ago, ianbmw said:
So , set out a plan of attack for the GL, sling the carb back on the Royale and see what it does……THEN not look at the CF?
fix nice cars only :D
Thing is, I used to drive that Royale and like the Carlton’s, I feel a little sorry for it.
It is also, 6 cylinder, RWD and MOT and Tax exempt……so it’s time is now!
But I think a day of planning is required to establish what order things need to be done. If the GL needs major engine surgery, then I’m inclined ti focus on the Royale until the weather warms up/ I have source in my garage
55 minutes ago, ianbmw said:
until the weather warms up/ I have hp sauce in my garage
10 hours ago, ianbmw said:
 until the weather warms up/ I have the source in my garage
candi staton would be happy
*nerd/old man
Today another new fuel pump was fitted to the Citroen DS and this time it was successful with no leaks. I guessed the fuel was low but had no idea how low. I decided to test run the car aiming for Tesco petrol 3 miles away.  Luckily I did not get off the drive when the engine stopped and the pump run loud and fast so I guess it is out of petrol. I did not have time to add petrol so that is a job for tomorrow.
@ianbmw volunteered to meet me at the FoD to discuss a plan for the Vauxhalls.
First success to Ian because with the Citroen out of action I had to jump in the Carlton estate  which he fixed.
Next he suspected the fuel leak I had reported from the carburetor was I was using an auxiliary electric pump that was  pushing in petrol at too high a pressure so he reconnected the mechanical pump. The fuel line under the car is hanging down and broken. The fuel tank has not been used for many years so he rigged up a bottle.   It started, did not leak petrol but roared from the blown exhaust.
Next was a plugs out and compression test on the blue Carlton saloon. No.3 plug was sooted up but the compression was good on all four cylinders. We started it and it still smokes.
Ian did an inspection of the Bedford CF but never reported the result!
The other win for the day is while Ian won't sell me his car washing daughter she did volunteered to  wash another couple of cars today. The blue Carlton saloon got a good going over as it was so bad last time and it needed a second wash. The white Sigma also got a wash in preparation for it returning to the road.
It is also, 6 cylinder, RWD and MOT and Tax exempt……so it’s time is now! When it came off the road, there wasn’t anything wrong with it bar a bit crunchy on the back sill. So it’s really a case of reassembling, finding the missing bits and seeing what it does. I will slide under it, address the exhaust and plumb it’s fuel lines back up and let’s go from there.
We can certainly promote it from….shed, to ………drivable shed! Before conquering the heights of…..road legal!
It’s a massive blow to my Carlton domination plans. 1,2,4 have a beautiful burn on the plug, all cylinders have good compression when cold, but plug 3 was wet with oil, so somethings not right and that’s a cylinder head off job, that will need to wait until I can get it back to mine really or warmer weathered……it will be fixed @Mrs6C!!! I’m not giving up!
Bedford CF……I am in no way suggesting any form of restoration, but it’s not as bad as the ones I see now getting done. The front wings , steps are holy, but it’s actually better than i remember……it still slower than a snail and a monster task……I’d still be interested to see what it does with the fuel pump back on, I wouldn’t want to spend any money on it!
car washing duties, it’s the Astra next I’m told! When she runs out of blue Vauxhalls, she may venture into othersIMG_9383.jpeg.b2a487382efcf5d535450bcbed3b50c3.jpegIMG_9385.jpeg.19ec81b80f3207c3bb7c2de0386ed971.jpeg
For a girl to wash all the blue Vauxhalls we have to wake it up as it has not been run for a year now!
Give the success rate of successfully get Vauxhalls to run again in the FOD…….im confident!
It is the how much mould question!
That’s the cleaning department problem, I just make them road legal, not shiny!
Look @Six-cylinder, you can buy the repair panels now for a CF!!
just imagine coughing those 4 aging cylinders into life, before building up the RPMs for a snail pace start, creating your own smoke screen so  the pedestrians and passing traffic are left in utter disbelief and questioning if they have time travelled back to the 80s.IMG_9412.jpeg.fca90d45f3bc48185715cb287d6a8fb3.jpeg
The arches would be handy.
Let’s not limit the panel replacement to just the arches
While we are dreaming why can't you fit a small block Chevy to it!
14 minutes ago, Six-cylinder said:
While were are dreaming why can't you fit a small block Chevy to it!
It’s 2024……we now install BMW M57 engines into EVERYTHING
I guess that is better than what is in there.
Was that the same as was in my 2004 Range Rover?
Yep! And it could be auto…..and it could be re mapped….. 275bhp CF with 500nm of torquey things
  • Agree 1
There is only one proper V8 option for a CF, the one fitted by the factory (in Australia).
I think it’s @Mrs6C you need to convince, @Six-cylinder just hates it on principle.
Not on principle but on experience!
I concur……with experience of this particular vehicle!
I think we should get it running though, just to annoy @Six-cylinder
just watching bangers and cash where they fettle a ds21 pallas
why is the trimmer gadge saying it needs a vinyl roof ffs
1 its french
2 roof is not metal
he said its period - yeah if its english
im hoping they dont
watching them bid on a fergie tractor now
Cor! now we are talking! I had no idea that the Bedford CF got the V8's over there, I know it got the inline 6 holden, but no idea they also got V8's!
@eddyramrod did you know that? imagine a V8 pre-facelift bedford CF with Automatic gearbox, I think that would be the ultimate Bedford CF for you if I am not mistaken? :)
it would be really interesting to do a shootout/comparison between a V8 Beford CF and a V8 Sherpa (did the transit ever get a V8 option in any markets? I know it got the Essex V6, but apart from the Super-van I am not aware of a transit V8?)
