Shite in Miniature II
Did that one come from Splitz Carz? I had one just like it but gave it away. Nice to see it getting some love. Corgi Metros are Gr9 esp the 1/36 scale version.
Corgi Die Cast Draughtsman: "What are the 1/1 measurements of that new miniMetro so I can scale them down a 36th?"
Corgi Chief Engineer: "No idea, everything about it is embargoed at Austin-Morris until the car's launched".
Corgi Die Cast Designer: "Fuck it I'll just make all 4 dimensions exactly the same as each other then".
*Finished and gets coat, goes for pint*
Snap, I'll need to look mine out now. I also have the 1/24 Bburago MG version which was a mega-odd choice for an Italian manufacturer IMO.
Me too, I had the Datapost one too but God knows where it went. The larger one I had in blue, red and I think a peculiar pale green although I haven't seen them in a whole either
If that red is original it would have come in the BP Garage gift set.....
I picked up a cracking little Hot Wheels (red Honda CRX) in the local Co-Op type shop this morning. At the till, once the lady reached the car when scanning, she said "make sure they don't leave this lying around on the stairs". OK love, I won't....  :roll:
Thanks Merc, a lovely set, indeed I believe this one to be original. I will look after it! (And get some luggage for it in time)
I've got this Ford Escort MK2. It's a Powertrack slot car by Matchbox. It still works too!
Tyres are perished though...
That escort is really nice!!
I have that CRX too,it really is a good casting.post-5543-0-10342300-1550746014_thumb.jpg
I just keep wishing they will produce the 4th generation Prelude.
Any love for this ugly duckling?
£2.50 posted?
Brake fluid is slowly bringing the wheels back too.post-20084-0-78924300-1550766208_thumb.jpg
There used to be a full size one round our way always seemed to have a ton of sand in the back - probably more as they were rated for that but this thing was always on the bump stops.   It was hand painted in a Vauxhall blue-green colour.   I have a couple of those Matchbox J2s - I must recreate that sand truck!
Top tip:  If you soak the Lesney bases with silver or grey plastic wheels in purple meths for 24-48 hours they go a little soft and can be removed from the axle and cleaned.  You can then push them back on.  BE CAREFUL, they are very easy to accidentally deform.  Usefully, this can allow you to make silver wheels round again if they've gained flat spots.  Rinse them off with water and leave them completely alone for at least 24 hours and they'll return to full hardness again.
I only found it out by accident the other day and I may* have squished a wheel a bit.  Best of all, no need to peen over the axle afterwards providing you remove the wheel from the small rivet side.
If it’s a genuine red one then don’t paint it as they’re quite scarce.
Asda round from work had five HW cars... two were red CRXs.
They only have two HW cars now... (nabbed both CRXs and a KDR30 Skyline RS.
Sent from my SM-G930F using Tapatalk
Speaking of Asda and Hot Wheels. I just picked these up thinking they would be expensive, but the price was 74p old stock I guess. I might go back for some more. they also had a red CRX might get that too.
I've always liked these 57 Plymouths. I can see some modifications happening to these.
Hum... Do I paint one red, or is that too boring/obvious?
Paint it blue and white and pale yellow, make a Cold War Motors tribute out of it.
Be sure to splice something on it too.
Ha good shout!
I'll have to give it some classic tyres and a poodle in the passengers seat.  :mrgreen:
In The California Kid, the sheriff's car was a 57 Plymouth coupe, blue with white doors.  Now there's a project...
On about the Matchbox Fiat 1500.
You've ruined my day.
Red CRXs still look ace. I wish I was still 8.
Junkman: you can get it in Wilkos (née Wilkinsons) in the DIY section.  It might be age restricted so I recommend you take someone that looks like a responsible adult with you, if you can find one.
